Old 12-27-2007, 04:24 PM   #1
Salsa88
Salsa88 is on a distinguished road
Salsa88's Avatar
1999 SC1
Attention Horn not working hlp plz!
So I took my car to get inspected and it failed because my horn want work. I thought it was just a blown fuse so when i got home i checked and the fuse was just fine. i tested a new fuse and still nothing with the horn. What could it be? i heard it could be the relay but i have no idea how or where to check the relay.
Add to Salsa88's Reputation
Rate the quality of this post and help Salsa88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Salsa88 is offline   Reply With Quote
Old 12-27-2007, 04:35 PM   #2
asdf
asdf is on a distinguished road
Default Re: Horn not working hlp plz!
This is for your '99? Just unplug the horn, and test for voltage when someone pushes the button.
If there is voltage, you get a new 96+ horn from the junkyard.
The horn in my '96 didn't work when I got it. Drove me nuts. Some of the pins were corroded from the plug, but once I fixed that still didn't work, the horn was bad.
And yeah, if there is no voltage, and you don't hear a click from the relay when you press the button, its probably either the relay or switch.
Add to asdf's Reputation
Rate the quality of this post and help asdf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
asdf is offline   Reply With Quote
Old 12-27-2007, 04:37 PM   #3
bobfather99
bobfather99 is on a distinguished road
1994 SL1
Could be the relay, or something as simple as a loose connection or ground.
I had a Ford Truck that had a loose mounting point; horn didnt work until I cleaned up the bolt and tightened it down.
Add to bobfather99's Reputation
Rate the quality of this post and help bobfather99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobfather99 is offline   Reply With Quote
Old 12-27-2007, 04:46 PM   #4
asdf
and actually, what you can try first is just switching the horn relay under the hood with the A/C relay, or whatever you know works.
and then just leave the known good relay there for until you find the other problem, in case 2 things are bad.
...or you can just put the horn relay in the A/C and see if the A/C still works
Old 12-27-2007, 06:08 PM   #5
Salsa88
Salsa88's Avatar
1999 SC1
where are the relays?
Old 12-27-2007, 06:10 PM   #6
asdf
Those plastic cubes. Just look under the cover of the underhood fuse panel, the map will tell you what's what.
Old 12-27-2007, 06:21 PM   #7
Salsa88
Salsa88's Avatar
1999 SC1
Thanks i thought so I just didnt want to start pulling things without 100% nowing what i was pulling on
Old 12-27-2007, 06:56 PM   #8
Salsa88
Salsa88's Avatar
1999 SC1
I checked and switched the relays and still nothing. Any ideas?
Old 12-27-2007, 06:59 PM   #9
yazhere
yazhere is on a distinguished road
yazhere's Avatar
Idea courtesy of Richpin06:
http://youtube.com/watch?v=LFpN4oZo_Tg
Add to yazhere's Reputation
Rate the quality of this post and help yazhere reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yazhere is offline   Reply With Quote
Old 12-27-2007, 07:08 PM   #10
That's because there isn't one. The relay is built into the horn.
Unplug the horn. Put a voltmeter between the orange terminal and the "outside" black terminal on the connector. There should be battery voltage at all times. Then put the meter between the orange terminal and the "middle" black terminal. There should be voltage only when someone presses a horn button on the steering wheel.
If the first test fails, something is wrong with the wiring. Check for voltage at the fuse, in this case. If the first test passes and the second test fails, it's either the wiring to the wheel buttons, or the buttons themselves, or the wheel not grounding. If both tests pass, it's gotta be the horn itself. That's the most common one. They tend to just up and fail with the slightest prompting. Mine worked fine up until a deer hit the car. Didn't physically damage the horn. Chafed the wires, and somehow that fried the horn (rather than blowing the fuse). If you're lucky, like me, you'll find a working one at a salvage yard. Otherwise, finding a horn with a built-in relay aftermarket isn't easy. DO NOT just commission a regular two-wire horn; the effect will be that the wire going to the wheel buttons will carry the horn's FULL current, and that would be a Bad Thing.
Add to madpogue's Reputation
Old 12-27-2007, 08:19 PM   #11
Salsa88
Salsa88's Avatar
1999 SC1
I got it to work!
the connector was disconnected from the horn. I had a mechanic do a front end repair and figure he just never plugged it back in.
Old 12-28-2007, 12:33 AM   #12
asdf
Oh yeah duh what was I thinking. Thats why the horn was bad on my '96. My '95 has a horn relay though.
Yeah, there is a relay socket labelled horn but there are no pins in it. Whoops, sorry for the confusion lol.
Old 12-28-2007, 12:38 AM   #13
That vestigial socket makes a great place to store a spare relay.
cooling fans quit working again???? plz help. TheGreenOne S-Series Tech 3 03-24-2008 07:51 PM
Sunroof leaking, hlp plz SimPlyxTriPPiN S-Series Tech 6 02-14-2008 07:51 PM
Horn not working, which fuse is it? bankerbob S-Series Tech 2 08-14-2006 01:48 PM
horn help plz ILMsl1 S-Series Tech 5 07-04-2005 04:04 PM
Horn not working gunny S-Series Tech 10 08-28-2002 01:52 PM
