Old 12-26-2007, 01:54 PM   #1
BASL2
BASL2 is on a distinguished road
Default Oxygen sensor removal - engine hot or cold?
I need to remove the old front oxygen sensor on my 1996 SL2. Should the engine be hot, warm or cold in order to make removal easier? I tried a bit with the engine cold, but didn't want to force it for fear of breaking something. Thanks!
Add to BASL2's Reputation
Rate the quality of this post and help BASL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BASL2 is offline   Reply With Quote
Old 12-26-2007, 01:58 PM   #2
92SC2
92SC2 is on a distinguished road
Default Re: Oxygen sensor removal - engine hot or cold?
COLD! You'll likely burn the snot out of yourself if you do it hot. If you can squirt it with PB Blaster one evening and pull it out the next morning/day. That will give the PB Blaster a chance to creep in and loosen things up a bit.
Add to 92SC2's Reputation
Rate the quality of this post and help 92SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92SC2 is offline   Reply With Quote
Old 12-26-2007, 02:24 PM   #3
richpin06
richpin06 has a spectacular aura aboutrichpin06 has a spectacular aura aboutrichpin06 has a spectacular aura about
richpin06's Avatar
Warming up the cold engine for 2 minutes expands the manifold a little to help in removal.
http://www.youtube.com/watch?v=ttUHqVz-sL0
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-26-2007, 02:29 PM   #4
92SC2
Which will most likely end up tightening the manifold on the sensor. It's not like freezing a wheel bearing and heating the race or freezing a 10/22 bbl and heating the receiver. If you fire up the car you're heating both the O2 sensor and the manifold causing both to expand.
Old 12-26-2007, 04:13 PM   #5
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Which one expands more depends on the coefficient of expansion of the two materials (the thread base of the sensor and the manifold).
Add to madpogue's Reputation
Old 12-26-2007, 04:32 PM   #6
Signmaster
Signmaster is just really niceSignmaster is just really niceSignmaster is just really niceSignmaster is just really nice
If the sensor expands quicker with heat, it should also cool quicker when the engine is turned off.
Sounds to me like a good argument towards heating the engine some first.
I've never had to pull one on the Satty yet, but most of the time exhaust sensors have come out better when the engine is warmed first.
Old 12-26-2007, 05:45 PM   #7
92SC2
Have fun heating your manifolds to remove your O2 sensors. If you insist on heating them first spray with a penetrating oil so it will be drawn into the threads. Caveat emptor, wear your waders.
Old 12-26-2007, 06:06 PM   #8
1999greenSL2
1999greenSL2 is on a distinguished road
1999greenSL2's Avatar
From a different perspective here, just give it all you've got. You're not going to break anything.
Add to 1999greenSL2's Reputation
Rate the quality of this post and help 1999greenSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1999greenSL2 is offline   Reply With Quote
Old 12-26-2007, 08:08 PM   #9
amazinghl
amazinghl is on a distinguished road
I only remove o2 when it is cold. Use the correct size wrench and PB blaster.
89 CSX 99.7 mph trap and climbing
85 GLH 102 mph trap
94 855
Add to amazinghl's Reputation
Old 12-26-2007, 08:42 PM   #10
TwinRevver
TwinRevver is on a distinguished road
crescent wrench with cheater bar and warm motor will do it. Just did on today
now with problems and getting a newer car but not a saturn :(
My 95 SL2 white top of the line car Priceless..
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
Old 12-26-2007, 08:51 PM   #11
denisond3
denisond3 is on a distinguished road
1996 SL1
The penetrating oil is a good idea - especially if you can spray it on twice a day for a few days - without driving the car in the meantime. That just vaporizesd the penetrating oil.
Try hitting the O2 sensor on its side a few times, close to where it threads into the manifold. This will help to shock the threads loose. Use a 6 point wrench when you are trying to turn it - not a 12 point. They make deep sockets that have a notch cut out of them, so it will go down over the wires. I would estimate it might take 100 -120 lb-ft of torque to get the thing to unscrew. It should only be tightened up about as much as a spark plug - maybe 20 lbs-ft.
If you run the engine to get thing warm, you could then dribble water on the O2 sensor just before you try to unscrew it.
The ultimate technique is to heat the manifold 'bung' with an oxy-acetylene torch, to expand the threads on the manifold. This usually requires removal of the radiator fan, to have clearance for the torch and its 4000° flame.
Add to denisond3's Reputation
Rate the quality of this post and help denisond3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
denisond3 is offline   Reply With Quote
Old 12-26-2007, 08:52 PM   #12
wolfman
wolfman's Avatar
One word for ya....and its not COLD
Or HOT
But WARM.
As in run the engine for 1~2 minutes (from a cold start) The Manifold will heat faster than the sensor expanding ever so slightly around it, making the sensor easier to remove.
Add to wolfman's Reputation
Old 12-26-2007, 09:18 PM   #13
geartooth94
geartooth94's Avatar
nah don't worry about changing it hot. the manifold only gets up to like 100 degrees with the engine on!
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 12-27-2007, 12:54 AM   #14
1999greenSL2
Honestly, it can be done with hand tools without days of soaking in PB blaster. Just force it. Mechanics don't have all that time to fool around, so thats their only option.
Old 12-27-2007, 05:47 AM   #15
92SC2
Are you talking about the exhaust manifold or degrees celsius?
Old 12-27-2007, 09:52 AM   #16
Mechanics have the option of breaking off (or rounding off) the sensor, replacing the manifold and charging the customer. DIYers have that option, too, of course, but they're not spending somebody else's money.
I think s/he was joking...
Old 12-27-2007, 10:21 PM   #17
1999greenSL2
I think dirty shops like you're describing are much more rare than the stories about them. I can't even imagine that happening where I work. Shops have to sell jobs. Not just get the car, do whatever the hell they want and give it back to you with an invoice. Get the car, diagnose it, call customer to sell the job... anything that goes wrong - like needing a new manifold after trying to replace the o2 sensor - would have to be paid for by the shop.
Old 12-27-2007, 10:43 PM   #18
I'm not saying that they would intentionally, or even negligently, break the sensor. I'm just saying that, even with the best of intentions and the most careful preparation, if a mechanic breaks a part off in another part, the customer pays to replace it. That's not "dirty", that's just the breaks. How many times has a $20 brake bleed job turned into a $100 bill for a new wheel cylinder, that was perfectly serviceable until the mechanic, doing her/his level best, breaks the bleeder off? When you're spending your own money, you're less likely to simply follow the step-by-step instructions, and more likely to try an extra step or two to avoid breaking, or rounding, or otherwise damaging something.
Old 12-28-2007, 06:27 AM   #19
L100andSW2
L100andSW2 is on a distinguished road
L100andSW2's Avatar
2002 L-Series 2.2L Sedan
1995 SW2
This way worked for me. Plus it seemed a little reluctant after the sensor first loosened so again sprayed PB where the threads meet the manifold, worked it back and forth a bit and then did a nice clean wrench turn to the left. Another short PB spray...reposition the wrench...work it...turn. Didn't want to break anything, but slow and steady will do it.
Add to L100andSW2's Reputation
Rate the quality of this post and help L100andSW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L100andSW2 is offline   Reply With Quote
Old 12-28-2007, 08:58 AM   #20
eljefino
eljefino's Avatar
1995 SW1
Not a fan of all this PB blaster advice.
I've used it on the manifold studs which are little and brittle and need all the help they can get.
The o2 sensor has anti-sieze on it and seems to be of a sturdy enough stainless-type metal. Plus it's BIGGER than the outer diameter of a lugnut!
Throw a foot long open end wrench on it, or disconnect the wire and feed a box end wrench over it if you're paranoid.
Tap the other end of the wrench counterclockwise with a sledgehammer. Start with small taps.
So why am I not a fan of liberally soaking the exhaust manifold in PB blaster? The smell and the smoke! You'll think your car is on fire the first time you do this.
Might as well put some MMO down your spark plug holes at the same time, so you can fog for mosquitoes from the front and the rear all at once!
Add to eljefino's Reputation
1995 SL2.. oxygen sensor removal Denis Twosaturn S-Series General 8 07-29-2009 09:48 PM
Oxygen sensor replacement service engine light on dddaaa S-Series Tech 11 04-09-2009 02:25 PM
MMO/Seafoam soak- hot or cold engine? spencerforhire S-Series Tech 3 10-21-2007 11:02 AM
Quick question...compression test on cold, warm or hot engine? flyhop S-Series General 1 02-19-2006 11:27 AM
Check oil when engine is hot or cold? willfxp S-Series General 9 12-12-2005 11:29 PM
