Old 12-25-2007, 05:52 PM   #1
2002SaturnMan
2002SaturnMan is on a distinguished road
2002 SL1
Default Please help. Daughters 1998 SL2 has "dim headlights"
My daughters 1998 SL2 has very dim low beams and hi beams (only on the drivers side). Even when I replaced both bulbs with new ones the same thing happens.
I swapped the nice bright ones from the passenger side to the drivers side and they are dim on the drivers side. When I put them back on the passenger side they are as bright as usual.
Is this an electrical problem?
Is it something I can fix?
2002 SL1, manual, SOHC (VIN 8) with 144,000 miles as of 10/01/11.
Former - 1994 SL 212,000 miles (great car!)
Step daughter HAD 1998 SL1, Wife HAD 1999 DOHC (VIN 7) SL2
Add to 2002SaturnMan's Reputation
Rate the quality of this post and help 2002SaturnMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2002SaturnMan is offline   Reply With Quote
Old 12-25-2007, 06:08 PM   #2
mgordon1100
mgordon1100 will become famous soon enough
mgordon1100's Avatar
Default Re: Please help. Daughters 1998 SL2 has "dim headlights"
This is just a guess, but I think the alignment of the drivers side light is off. Or, perhaps, the alignment of the passenger side is off, making it look brighter than it should be. I don't know much about fixing cars, but I sure know quite a bit about light bulbs.
Question: Did you get down on your knees and stare straight into the lights to actually see that one was dimmer than the other?
Add to mgordon1100's Reputation
Rate the quality of this post and help mgordon1100 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mgordon1100 is offline   Reply With Quote
Old 12-25-2007, 06:24 PM   #3
techsista
techsista is on a distinguished road
techsista's Avatar
check your fuses? not sure about saturns but on one of my hondas if the fuse was blown the light would be very dim, like almost running on a dead battery.
Add to techsista's Reputation
Rate the quality of this post and help techsista reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
techsista is offline   Reply With Quote
Old 12-25-2007, 08:20 PM   #4
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
As mentioned the place to start is the fuses. The headlamp fuses are in the under hood fuse block.
Add to ssicarman's Reputation
Old 12-25-2007, 08:40 PM   #5
GS Jon
GS Jon is on a distinguished road
GS Jon's Avatar
I'd assume that if a fuse was blown you'd have no current and therefore no light.
Check your grounds first.
1999 Saturn SL2, Auto
1997 Pontiac Grand Prix GTP, a few mods
1998 Buick Regal GS
Add to GS Jon's Reputation
Rate the quality of this post and help GS Jon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GS Jon is offline   Reply With Quote
Old 12-25-2007, 08:46 PM   #6
saturnsctwo
saturnsctwo is on a distinguished road
as suggested i would check the grounds first & then the plug connections. probably a bad connection somewhere there....
Old 12-25-2007, 10:15 PM   #7
techsista
techsista's Avatar
i've had blown headlight fuses and had light, just very very dim light (or what I could only describe as a "brown" light)
Old 12-25-2007, 10:48 PM   #8
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
^^^^ Yup, something to do with the fact that our headlights are switched on the negative side of the circuit. When the fuse blows, IIRC, the circuit completes via some other path, and at half voltage, sorta the way the DRLs work.
Add to madpogue's Reputation
madpogue is online now   Reply With Quote
Old 12-25-2007, 10:57 PM   #9
GS Jon
GS Jon's Avatar
Well hot dang, that's good info. Thanks!
1998 Buick Regal GS
Old 12-26-2007, 07:34 AM   #10
2002SaturnMan
2002 SL1
Thank you very much. It turned out to be a missing fuse???? Not sure how that could have happened, but it did.
Replaced the fuse and the lights work fine! :-)
Old 12-26-2007, 08:58 AM   #11
mgordon1100
The fuse was missing all together? Has the car been in a shop recently? The reason I suggested looking at the alignment, is because that happened to my car. For the longest time, while driving the car, it looked like I only had one light working. I adjusted the aiming on my drivers side, then I had more light.
Old 12-26-2007, 11:36 AM   #12
92SC2
92SC2 is on a distinguished road
When I had problems with dim headlights on my 92 Saturn it was shortly after I had submerged the alternator.
Add to 92SC2's Reputation
Rate the quality of this post and help 92SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92SC2 is offline   Reply With Quote
Old 12-27-2007, 08:17 AM   #13
2002SaturnMan
2002 SL1
Yep. The fuse was totally missing.
I'm thinking that while at college one of her friends might have tried to look at it and didn't have a clue what they were doing, or just didn't push the fuse all the way back in.
Anyway, it's fixed now. Thank you very much!
Old 12-27-2007, 08:25 AM   #14
97coupe
97coupe is on a distinguished road
I think this person is the only one that has it right here. This is not a fuse issue.
Add to 97coupe's Reputation
Rate the quality of this post and help 97coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97coupe is offline   Reply With Quote
Old 12-27-2007, 10:02 AM   #15
BarnOwl
BarnOwl's Avatar
Speed reading again...I've been guilty of this myself. The OP found that a fuse was missing and replaced it.
Add to BarnOwl's Reputation
Old 04-11-2013, 05:53 PM   #16
Capt. Dan
Capt. Dan is on a distinguished road
techsista was right on the fuse. My 2001 Saturn SC2 has a 10amp fuse for each headlight. Problem solved.
Thanks,
Capt. Dan
Add to Capt. Dan's Reputation
Rate the quality of this post and help Capt. Dan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Capt. Dan is offline   Reply With Quote
Former Saturn Owner Struck by "Unresponsive" and "Inattentive" Treatment from Toyota Charlie General Saturn Discussion 20 02-25-2011 03:11 PM
1998 SW-2: Liftback lock "stutters" Oldgeezer67 S-Series Tech 3 08-23-2007 03:12 PM
Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door???? Token S-Series General 21 09-08-2005 09:14 PM
"blue headlights" brianottis S-Series General 20 02-28-2005 11:28 PM
This week's VUE glitch (or "My service dept is nice but dim") wmacblue Vue General 4 05-24-2002 02:40 PM
