Old 12-14-2007, 03:15 PM   #1
blabmouth02
blabmouth02 is on a distinguished road
1997 SL
Default Coolant Type
Hey does anybody know the coolant I need. My car was getting pretty hot with that snow storm and the fan had to come on multiple times, right as the need was 3/4 the way to the red. Also I was sitting in traffic for about an hour and a half, stop n stop in the storm. Bought my Saturn from a family friend but never got the manual. It's a '97 SL, 5 speed, 4 cyl. Hope the info helps.
Edit: should it be Dexcool?
Add to blabmouth02's Reputation
Rate the quality of this post and help blabmouth02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blabmouth02 is offline   Reply With Quote
Old 12-14-2007, 03:21 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Coolant Type
It should have an orange or green dot on the center of the cap for the coolant. It should be dexcool on a '97. However, I don't think you're overheating. It's not abnormal for the fan to come on in stop 'n stop traffic. That's what it's there for.
Add to BarnOwl's Reputation
Old 12-14-2007, 04:20 PM   #3
blabmouth02
1997 SL
I know it's not over heating, but it just seems really close to it. I tried to look inside of the reservoir to see how much is in there. It's really hard to see but looks like it is running out. Is it a big deal if I just put more in for now and not drain it? Or is it "required"?
Old 12-14-2007, 04:39 PM   #4
oseberg
oseberg is on a distinguished road
You can just add more, but make sure it's the same type you already have in there.
You can get coolant that claims to be compatible with all cars and all coolant types. I'd use that one since it won't turn to gel or otherwise gunk up like it would if you mixed the two wrong types.
I flushed the cooling system in my 95 SL2, then replaced it with the compatible type so that I wouldn't have to worry about what I had available in case of a breakdown.
Also, the Dexcool that was originally in the car gunked up on me before, so I don't like it any more.
Add to oseberg's Reputation
Rate the quality of this post and help oseberg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oseberg is offline   Reply With Quote
Old 12-14-2007, 07:44 PM   #5
BarnOwl
BarnOwl's Avatar
If you're talking about the '95, it didn't come with dexcool.
Old 12-14-2007, 07:50 PM   #6
oseberg
It's the 95, and I don't know if it came with Dexcool or not, but that's what it had in it when I got it (it was pinkish orange), and it was gunked up. When I removed it, I collected it in a bucket and after sitting for a few days it turned to jello. Maybe someone else mixed something in with it, and that's what caused it to turn to jello. Or maybe it turned to jello on it's own. I have no idea. But I figured the stuff that claimed to be compatible with all cars and all other coolants should be OK in my 95 SL2.
Old 12-14-2007, 08:10 PM   #7
blabmouth02
1997 SL
first off that gunk or jello is the right stuff. Its meant to be used in the sealed cooling systems, ie Saturns. When it gets exposed to air, it oxidizes and turns into the clumpy jello stuff.
Anyways I just went over to Walmart to get the universal stuff and also picked a tester. Put the tester in and it said that my range was very good, more than they recommended (good job saturn lol). So I thought every should then be fine, but I noticed on the end of the tube that there was some of that gunk there. So there must be more in there. Thus I probably will need to do a full flush.
I know it isn't that hard but how much would you say it should cost a mechanic to do (not including the antifreeze, that I just got). Thanks guys. ooh and please somebody help me out on my other thread http://www.saturnfans.com/forums/sho...83#post1167283
Old 12-14-2007, 09:02 PM   #8
oseberg
That's the dumbest idea I've ever heard. A coolant that turns to jello when exposed to air, why? So that it can clog your entire system making it harder to flush it out? I think they should waterboard the chemical engineer who designed that crap, and all the execs that decided to sell it and all the auto company execs who decided to recommend it for their cars! Because that's just plain retarded!
Old 12-14-2007, 09:07 PM   #9
oseberg
Ok, maybe that was a bit excessive, but it's still a dumb idea.
Old 12-15-2007, 04:00 AM   #10
bobfather99
bobfather99 is on a distinguished road
1994 SL1
You can always get the "all makes/all models" coolant from most major companies (Peak, Prestone, etc)
I usually get it already 50/50 mixed, just to make life easy...
Add to bobfather99's Reputation
Rate the quality of this post and help bobfather99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobfather99 is offline   Reply With Quote
Old 12-15-2007, 07:54 AM   #11
BarnOwl
BarnOwl's Avatar
Actually, I've read something along those lines too. Not sure how it works though. My understanding is that in systems that have an overflow tank Dexcool is bad news. Our plastic tank is part of the pressurized cooling system. So, it's not a problem.
Old 12-15-2007, 03:31 PM   #12
Oseberg, maybe your coolant was gunked up because the previous owner mixed conventional with dex-cool. Maybe.
Add to madpogue's Reputation
Old 12-15-2007, 06:17 PM   #13
PurdueGuy
PurdueGuy's Avatar
1999 SC1
My advice: top it off with that "goes with everything" coolant you just got, and keep it topped off until warm weather comes around. Keep an eye on the coolant level, note how much you're losing, and watch to see if you can spot where you're losing it (if you are). If you can figure out what's leaking, then it's best to fix that along with doing the flush & fill. The flush & fill is so easy to do, I recommend for most people to do it themselves. DIY job will cost you about $5 for some flush chemicals, and the coolant (which you already have some of, so just add the cost of another jug probably). If you're going to pay someone else to do it, add $50-100 onto that cost.
Add to PurdueGuy's Reputation
Old 12-17-2007, 09:02 PM   #14
blabmouth02
1997 SL
Yeah Purdue thats what I ended up doing, topping off all makes/models that is. Will keep an eye on it. I don't think it's leaking or anything but like you said once it gets warmer is when I will do the flush. Thanks for the help everyone, I appreciate it. Have a good, safe and, hopefully for you, warm holiday.
Old 12-17-2007, 09:15 PM   #15
Uzzy
Uzzy's Avatar
2002 SC1
I didn't read every word of this thread, but did I miss it, or did nobody mention a manual fan switch? The car was not overheating (well it was close, right?) It got almost to the red before the fan came on. that's how it's designed to work. Kinda stupid, but that's they way they are up until 2000, I think. Some people have put manual fan siwtches in, so that they can turn the fans on earlier if they sit in traffic a lot and don't want to wait until it's almost in the red for the fans to kick in. There is a How-To by wolfman, and it's supposed to work, so that the system will work automatically, or you can over-ride it and turn them on at will.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 12-17-2007, 10:08 PM   #16
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Add a bottle of Redline Wetter solution. One of the few things in a bottle that I add to an engine that works.
http://www.rvtransmissions.com/water_wetter.htm
Add to BobbyP's Reputation
Old 12-18-2007, 09:20 PM   #17
virnin
virnin is on a distinguished road
virnin's Avatar
The advantage of Dexcool is that it is much kinder to aluminium than "green stuff". The flip side is that it had unexpected interaction with other stuff, like plastic intake manifold gaskets on GM V-6's that end up causing problems. In an overflow or expansion tank, the relatively small surface area exposed to air doesn't lead to the whole system turning to jell. Other contaminates, however, can catalyze that reaction as happened in that bucket.
I'm not necessarily a fan of Dexcool and am happy my '95 has "green stuff" but it wasn't necessarily just a bean-counter driven choice.
Add to virnin's Reputation
Rate the quality of this post and help virnin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
virnin is offline   Reply With Quote
Old 12-19-2007, 08:27 AM   #18
1999greenSL2
1999greenSL2 is on a distinguished road
1999greenSL2's Avatar
I tested my coolant yesterday with a voltmeter, and it's a little acidic so I'm changing it sometime this week before I go out of town for Christmas.
My car came with green stuff in it, so I'm doing a flush and switching to Dex-Cool.
I wouldn't recommend using the flush chemicals because they're really corrosive... I don't know that from experience but 1) it makes sense and 2) all the more knowledgeable people at work agree.
Add to 1999greenSL2's Reputation
Rate the quality of this post and help 1999greenSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1999greenSL2 is offline   Reply With Quote
Strange observation upon changing coolant type ShuttlecraftX47 S-Series General 5 07-14-2009 11:27 AM
LS1 coolant sensor type gnat L-Series Tech 3 09-21-2008 03:17 PM
where to find the right type of coolant for 01' SL2? palbuddy S-Series Tech 7 05-01-2007 12:30 AM
Coolant type? smull333 S-Series General 2 12-29-2005 08:10 PM
Type of coolant for 97 SL2 gary078 S-Series Tech 3 03-06-2004 02:20 PM
