Old 11-15-2007, 02:40 PM   #1
jsdailey
jsdailey is on a distinguished road
Default Timing Belt Replacement
My 03 Vue is in for repair to the Oil Cooler and the dealer suggested I get ready to replace the Timing Belt at 100,000 miles. I am now at 84,700! Dealer says they charge a flat rate of $995.00. Is this a fair price?
Add to jsdailey's Reputation
Rate the quality of this post and help jsdailey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jsdailey is offline   Reply With Quote
Old 11-15-2007, 02:59 PM   #2
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Default Re: Timing Belt Replacement
I thought the 03 V6 VUEs had a timing chain.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 11-15-2007, 03:30 PM   #3
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
It's a belt. You don't need to do it right now as there is nothing in common with the oil cooler fix. It won't cost you more to do it later unless they're willing to offer you some special deal, and $995.00 is at the high end of this job. You can probably get the belt, pulleys, and water pump replaced for a lot less at other dealers or independent shops. It's nothing that requires special "Saturn" expertise. Pretty straight forward job.
And the belt doesn't break at 100k miles. That just a suggested replacement interval. It may go 150k or more before it breaks. Though if you let it go to failure, it will wipe out the valves, which will be very expensive.
Old 11-15-2007, 03:55 PM   #4
mr weather
mr weather is on a distinguished road
So the L81 motor is an "interference" style?
Add to mr weather's Reputation
Rate the quality of this post and help mr weather reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr weather is offline   Reply With Quote
Old 11-15-2007, 03:59 PM   #5
jsdailey
Yes, according to my dealer.
Old 11-15-2007, 08:29 PM   #6
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
With the move toward higher compression ratios, I think it's darn near impossible to build a non-interference DOHC engine these days.
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-16-2007, 06:22 PM   #7
jsdailey
The dealer called today to inform me my Vue would be ready until tomorrow, unless I wanted to go ahead with the timing belt, then it would be Monday. I questioned the $995.00 charge and they said the 03 doesn't require new tensioner's (lifetime), so the actual cost is $650, plus another $70.00 for the water pump. I am going to wait on this, we don't drive the Vue much!
ps. the dealer is Saturn of Indianapolis at Pike Plaza.
Old 11-16-2007, 08:51 PM   #8
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
The engine in my 2003 Mazda Protege is non-interference.
Not a Saturn.
Old 11-17-2007, 01:00 PM   #9
jsdailey
Quick follow up to this post and the Oil Cooler Leak, Saturn of Indianapolis has had my 03 Vue since Thursday morning and they're saying they may not get it done today, (Saturday) because they're really slammed over there. Is this a 3+ day job, or is this dealer just that bad? This is my first interaction with a Saturn dealer, just purchased the Vue a few months ago. So far, not impressed!
Old 11-17-2007, 01:57 PM   #10
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
The only thing I would check is that the timing belt did not become contaminated with coolant. If the timing belt is contaminated, its days are numbered.
~D.J.~
OhioVueBoy is offline   Reply With Quote
timing belt replacement marathoner Vue Tech 29 09-28-2011 09:17 PM
Log: Timing belt replacement s3nfo L-Series Tech 20 04-06-2009 12:50 PM
Timing belt replacement. VueGuy168 Vue Tech 15 03-03-2009 09:17 AM
Timing Belt Replacement hugh S-Series Tech 13 06-15-2001 11:15 AM
Timing belt replacement-help- t3junkie S-Series Tech 5 03-08-2001 02:43 AM
