Aura General Photos |
· · · AURA - Member Photos 588 photos 198 comments |
· · · 2007 - AURA Green Line Hybrid 16 photos 0 comments | ||||||||
Thread Tools | Display Modes | |||
#1 | ||||
hey all
does anyone know if the is an easy way to have the power outlets (in the dash and in the storage compartment under the arm rest) shut off when the car isnt running or in accessory mode? J
#2 | |||||
![]() Join Date: May 2006
2007 AURA XR
Good luck!
#3 | ||||
Sure! Wire up a standard 87 relay or a heavy duty relay that will conduct the 10amps or so from the ACCESSORY or ON/RUN position, if you know how to wire up electrical circuits. The signal wire would come off the ignition switch to power the relay on only when the ignition is ON, closing a set of heavy duty electrical contacts that supplies fused power to the outlets. I don't have a drawing tablet to sketch a circuit quickly and it takes too long to draw in MS Paint. This type of circuit is one of the easiest to make, similar to adding fog lights.
... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
| Thread Tools | |
| Display Modes | |
| constant/switched power adapter | rglr | S-Series Tech | 13 | 09-04-2009 02:11 PM |
| power outlets | bigdude2468 | 2008 Vue | 6 | 12-08-2007 03:23 AM |
| Dead power outlets??? | tominsky | Vue General | 11 | 04-28-2006 02:47 PM |
| Where are the two 12V DC power outlets located? | mapleflag | Ion Mods | 7 | 01-03-2006 04:41 PM |
| Vue 04 Accessory Power Outlets don't work | barrymis | Vue General | 6 | 12-14-2004 11:00 PM |
