Old 11-10-2007, 03:17 PM   #1
bkbertollini
bkbertollini is on a distinguished road
Default Saturn Vue Clutch Problem
Ok, so this one makes no sense to me. I have a 2004 Vue, 57,500 miles. Everything was fine. It got chilly one night, in the 40's, and the next day the car is really hard to get into gear, both arms on the gear shift hard. No clashing of gears just really hard, till the air temp warmed up, then acted like nothing was wrong. Shifted smooth as silk. Everyday it has been like that. So, I went to Mitchell Manuals Online. Everthing I read pointed to air in the line. So, here I am trying to bleed the stupid clutch and it won't bleed. I have tried with a vacumn bleeder and with the old pedal method. Now it has no pressure and I can't drive the car. So, I need some suggestions as to how to bleed it and any ideas as to what caused all this. Thanks,
Add to bkbertollini's Reputation
Rate the quality of this post and help bkbertollini reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bkbertollini is offline   Reply With Quote
Old 11-10-2007, 06:11 PM   #2
IMkenNY
IMkenNY is on a distinguished road
Default Re: Saturn Vue Clutch Problem
The only method that that seems to work is vacuum bleeding at the master cylinder fill.
With the bleed screw closed and a stopper replacing the master cylinder fill cap apply a vacuum to the reservoir and hold for 20 minutes.
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline   Reply With Quote
Saturn Vue 05 clutch replacement norwch Vue General 1 09-09-2009 04:53 PM
SL2 Clutch problem. I am breaking up with Saturn! Traysee S-Series General 32 10-14-2005 10:21 PM
VUE Clutch Problem Maggie_124 Vue General 35 03-09-2005 09:14 PM
VUE Clutch Problem? jmatero Vue Tech 2 05-07-2003 05:43 PM
Help! Vue clutch problem waffler62 Vue Tech 4 07-01-2002 12:04 AM
