#1 | ||||
![]() Join Date: Nov 2004
My vehicle has rear drums no ABS. Brakes stop good, the brake light does NOT show up after releasing parking brake. It's low on power steering fluid. I added brake fluid and it remains at the H mark for couple of weeks.
So why: after turning off engine have to pump pedal 4 times to get a hard pedal. it's somewhat low an spongy when hitting brakes at traffic light. park in a downhill rear brakes skip just slightly sometimes. On my mother's Toyota I've got hard pedal at all times. WEIRD.
#2 | ||||
![]() ![]() Join Date: Oct 2002
2008 Astra XR
2008 SKY Red Line
Most likely is that the master cylinder is leaking. Look at the back of the master for brake fluid running down the front of the booster. If you don't see any evidence, then you need to thoroughly inspect the rest of the hydraulic system for signs of the leak. You have to be leaking the fluid since it's not consumed.
If you don't know how to work on brakes, you need to have the work done by a professional.
#3 | ||||
The power steering fluid is a red herring, has no relation to the brakes.
If you're adding brake fluid and it's disappearing, you have a leak. Most likely you have a mostly rusted out line that could blow completely tomorrow. One thing you can do is park on a huge sheet of cardboard then go stand on the pedal hard, and see where wetness is coming from. Fix this, as it is never normal to go through brake fluid!
#4 | ||||
The hard pedal after four pumps is just the reserve vacuum of the power brake booster being exhausted. Perfectly normal.
Perhaps the Toyota doesn't have power brakes. A soft pedal (esp. if you report rear brakes "skipping" [whatever that is]) commonly means the rear brakes are out of adjustment. They're _supposed_ to self-adjust whenever you brake in reverse, but the self-adjusters aren't terribly reliable, and if you don't use reverse much, you won't get much adjustment. You should adjust the rear brakes to where they JUST start to drag, just EVER so slightly. You'll probably also notice improved parking brake performance when you do this.
#5 | ||||
When I replenished the master cylinder it was at the L mark. After adding fluid it hasn't gone down at all. I don't see any leaks at master cylinder.
Could the wheel cylinder be slightly leaking? The Toyota has power brakes and ABS.
#6 | ||||
All the suggestions are for you either to actually examine the entire braking system at each wheel well to determine if there are any mechanical problems or to bring your car to a brake repair shop for expert diagnosis. Filling the master cylinder from the 'Low" mark can mean that the brakes are worn and need inspection, a leak occurred (potential danger if not looked into), and/or the brakes need adjustment. Any or all of this should be part of a regular maintenance routine whether done at 5-mile intervals or 5,000 miles. Part of car ownership with record keeping for reference.
Just to throw you a curve on brake maintenance, someone recently had a similar situation just like you with rear drums but his poor braking was from lack of maintenance on the front disc brakes. He had already replaced the pads and rotors and a few thousand miles later found the brake pedal going soft. It turned out that he never removed the calipers to expose the two slide pins allowing the calipers to self align with the rotor/pads. The pins were rusted/corroded in place causing uneven wear, ruining the rotors and only one disc pad wore instead of both evenly. He wound up replacing everything again but made sure the slide pins allowed the calipers to self align for even wear and perfect braking again. Overlooking one part of brake maintenance cost him time and money to do it right the second time and share his experience with us. ... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
#7 | ||||
^^^+1
... Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place
#8 | ||||
![]() Join Date: Sep 2007
Hmmm.... maybe it (the toyota) has a leaky booster diaphragm. As someone mentioned earlier, it's completely normal to get "hard" pedal after the engine is shut off. This is because power brakes are powered by the vacuum in the intake manifold. I believe brakes can also be powered by the power steering pump, but not on your S-car.
| Thread Tools | |
| Display Modes | |
| A/C new install from dealer and acting weird | norkahinz | S-Series Tech | 8 | 12-10-2009 11:36 AM |
| speedometer acting weird | betax4 | S-Series General | 1 | 09-08-2005 01:51 AM |
| 99 SL2 is acting weird | Klutz_33 | S-Series Tech | 3 | 07-18-2004 11:05 PM |
| 1996 SL1 Acting Weird | IONicSaturn | S-Series Tech | 8 | 03-26-2003 07:52 PM |
| Fuel gauge is acting weird, Saturn tech? | Qlara | Miscellaneous Tech | 7 | 08-24-2001 08:50 AM |
