Old 11-07-2007, 06:13 PM   #1
Cheekz185
Cheekz185 is on a distinguished road
Default 1997 Saturn SL Heat problem....
OK So I have a 1997 Saturn SL and my heat "stopped" working at the end of last winter. SO i pushed it off and now that winter is coming i need to fix it. SO basically my Saturn SL blows lukewarm air and not hot air. What could be the possible problem could it be the heater core? Thermostat? Where is the heater core located and thermostat located? Any help would be greatly appreciated.
Add to Cheekz185's Reputation
Rate the quality of this post and help Cheekz185 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheekz185 is offline   Reply With Quote
Old 11-07-2007, 06:22 PM   #2
Phredawgy
Phredawgy's Avatar
Default Re: 1997 Saturn SL Heat problem....
My guess is your thermostat is stuck open ..... it is located at the end of the lower radiator hose(left hand bottom side when facing the engine compartment)
Add to Phredawgy's Reputation
Old 11-07-2007, 06:25 PM   #3
nivlem7
nivlem7 is on a distinguished road
Sounds like a thermostat, although you'll want to replace the original ECTS with a brass one if you never have. It's about $15 and takes about 15 minutes or less to do.
http://www.saturnfans.com/forums/showthread.php?t=37884
Add to nivlem7's Reputation
Rate the quality of this post and help nivlem7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nivlem7 is offline   Reply With Quote
Old 11-07-2007, 06:51 PM   #4
What does the temp gauge read? Is your fuel economy okay? Do you ever get an SES light? If you leave the car idling, parked, does the radiator fan eventually come on?
Find the two heater hoses that go into the firewall. Warm up the engine and grab each heater hose. If one is warm and the other not-so-warm, that indicates a clogged heater core.
Another possibility is the temp "blend" control on the HVAC panel. When you slide the temp knob, does it feel normal? Or is it harder / easier to move than you would expect?
Add to madpogue's Reputation
Old 11-07-2007, 08:53 PM   #5
Cheekz185
Fuel economy is still going good! And the slider is normal, its not easier/harder to slide. NO SES lights...I am going to try replacing my ECTS and take a look at my thermostat. Now, where can i but an ECTS, at a local autoparts store or is it dealer only? Is that the real name for the part or is it something different?
Old 11-07-2007, 09:17 PM   #6
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
Coolant temperature sensor. You can get them at any parts store just make sure it all brass.
03 GMC Envoy XL
99 Isuzu Rodeo V-6, 4WD, Rebuilt 3.2L with 3.5L internals
63 Mercury Comet Convertible
Add to Cat Fuzz's Reputation
Rate the quality of this post and help Cat Fuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cat Fuzz is offline   Reply With Quote
Old 11-07-2007, 09:18 PM   #7
Phredawgy
Phredawgy's Avatar
What does your temp gauge read when the car warms up?
Also try madpogues suggestion about the heater core, if that's it you probably won't have to mess with the thermostat.
Autozone, Checker those stores all carry the ECTS or should. But they'll probably understand you better if you ask for the Engine Coolant Temperature Sensor
Old 11-07-2007, 10:15 PM   #8
Cheekz185
OK so lets say it is a clogged heater core, what do I do after that? Buy a new heater core? Where is the heater core located? Under the dashboard?
Also some1 said check the thermostat to see if it is stuck open (post #2). What do i do if it it is "stuck open"
I dont know if this means anything but I am having no with the the HVAC system lol. IN Mid august my cold air went also. BUT i took it to a place and they said that the ac compressor is working. SO what can that be now...
Old 11-07-2007, 10:45 PM   #9
yazhere
yazhere is on a distinguished road
yazhere's Avatar
For your reading enjoyment from the Forum How-To Library as posted by two prominent advisers.
http://www.saturnfans.com/forums/sho...ght=thermostat
Add to yazhere's Reputation
Rate the quality of this post and help yazhere reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yazhere is offline   Reply With Quote
Old 05-23-2014, 11:17 PM   #10
yamomee
yamomee is on a distinguished road
One somewhat related success story.......I had an '94 SL1 that did not heat up (temp sender never read above 1/4, and little heat came from the heater). I replaced the t/stat, but still had the same problem. Then, I picked up a tip from another thread to order a t/stat housing with the t/stat already installed - in case I screwed up installing the t/stat. When I received the new housing assembly, I noticed that there was a brass orificed fitting in the bleed hole that wasn't in the old housing. The bleed hole in the old housing, without the orificed fitting, was now 1/8-1/4" in diameter. So coolant was by-passing the t/stat through this bigger-than-normal hole. I can only assume that the brass fitting fell out of the old housing, since it worked fine for 19+ years. I never did find the brass fitting in the system.
Add to yamomee's Reputation
Rate the quality of this post and help yamomee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yamomee is offline   Reply With Quote
Old 05-24-2014, 01:21 AM   #11
Signmaster
Good catch. I would imagine this causes more of a problem on the SOHC engines, since they really don't produce all that much heat. Getting the thermostat with the housing seems the easier approach than chasing down the OEM style housing.
On a side note, which thermostat/housing did you get, and what is your gauge showing now? I wanted to go back to the cooler OEM type temp thermostat when I switched my water pump the other day, and couldn't find any locally. It looks like all the cooler units now come with housings. Just curious what your replacement was and how it affected temps, along with what type of thermostat came out so I have a reference for where your gauge reads for a given unit.
Signmaster is online now   Reply With Quote
no heat/lack of heat problem mr18436572 S-Series Tech 7 04-16-2015 10:01 PM
1997 Saturn SW2 Shifting Problem SaxJazz12 S-Series Tech 9 02-18-2014 08:19 PM
1997 Saturn SL2 A/C curious, yet annoying problem - HeLp! Shawnr001 S-Series Tech 7 08-20-2009 01:25 AM
1997 SL1 Will not heat & it Over heats! saltfishnguy Community Center 5 11-24-2005 03:37 PM
94 Saturn Sl1 heat problem sloppyo S-Series Tech 11 01-24-2004 01:09 AM
