Old 11-07-2007, 01:12 PM   #1
Blammer
Blammer is on a distinguished road
1997 SW2
Default Different Timing Chain cover bolts?
I have a 97 SW2 DOHC.
I have two different type bolts that hold it on.
There are 4 of them that are directly below the crankshaft gear on the bottom of the timing chain cover.
They are different sized from the other bolts that hold on the timing chain cover. I need 3 new ones as these, the bolt head is stripped or damaged.
The dealership doesn't show a different bolt.
Are they oil pan cover bolts that happen to attatch to the timing chain cover?
Here is a pic of the timing chain, and the bolts go into the bottom of the timing chain. Not a great pic but you get the idea
The bolts themselves are 8mm bolt head, flanged, approx 3/4 of inch long, medium to fine thread I'd guess. 9.8 is on the top of the bolt.
Any suggestions on replacing them would be very much appreciated.
97 SW2 270,000 miles and died when a tree fell on it.
Never argue with an idiot, they will only bring you down to their level and beat you with experience.
Add to Blammer's Reputation
Rate the quality of this post and help Blammer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blammer is offline   Reply With Quote
Old 11-07-2007, 01:24 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: Different Timing Chain cover bolts?
They are oil pan bolts.
I have some you can have for postage, PM me.
Add to eljefino's Reputation
Old 11-07-2007, 05:20 PM   #3
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
looks like there is some problem with (wordwrap ) here as well !(anyone?)
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 11-07-2007, 05:24 PM   #4
wolfman
wolfman's Avatar
All of the cover to block bolts are the same size. The 4 different sized ones are OIL PAN bolts. Take the best one you have to your local HARDWARE STORE and match them up....and pay less than 1/2 as much.
Add to wolfman's Reputation
Old 11-07-2007, 05:34 PM   #5
eljefino
eljefino's Avatar
1995 SW1
Offtopic, but word wrap and page width gets screwed up with inline images. Making inline images 550 px wide or less is helpful for those on dialup etc.
Old 11-07-2007, 06:22 PM   #6
Blammer
1997 SW2
wolfman thanks for the tip
eljefino, incoming PM!
timing chain cover help 93SC2'in S-Series Tech 3 10-30-2008 09:12 AM
Timing chain cover, sohc duganator9 S-Series Tech 2 11-12-2007 10:33 PM
Behind the timing chain cover My95Sat S-Series Tech 19 12-18-2004 12:48 PM
thread pitch of timing cover bolts geartooth94 Miscellaneous Tech 4 10-20-2004 05:07 PM
Timing chain cover gasket? Mog Miscellaneous Tech 5 05-24-2004 08:51 PM
