Old 10-18-2007, 04:21 PM   #1
fusion61
fusion61 is on a distinguished road
1998 SL1
Default installing a quarter glass window
Does anyone know how to install the rear passanger side small window i think they call it quarter glass window. I have a 1998 sl1 but i dont know how to install the quarter window can anyone help. Is their diagrams on the net.
Add to fusion61's Reputation
Rate the quality of this post and help fusion61 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fusion61 is offline   Reply With Quote
Old 10-18-2007, 04:48 PM   #2
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
Default Re: installing a quarter glass window
Don't know about the 98 ,but on my 92 S L 2 ......
it is made attached to the window guide ect.
just take off the outer door panel,and unbolt the guide .
the assembly should come out pretty easy .
to remove the outside door handle ,you need to push the core
of the retainer in ,then pull the rest out ,then slide the handle
sideways to release from mounting stubs.
find the core inside the handle ,to be reused.
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 10-18-2007, 05:03 PM   #3
Originally Posted by Dr B View Post
to remove the outside door handle ,you need to push the core of the retainer in ,then pull the rest out ,
On gen-2s, it's the opposite. You PULL the center-pin out, to "unlock" the rivet, then pull the whole rivet out. If you're really good, you won't bugger it up and can re-use it. AFAIK, everything else works the same as gen-1, even though it looks a lot diff.
For a "model" of the center-pin rivet, look at the rivets holding some of the bumper cover on, or the inner wheel wells. This is a mini version of that rivet.
Add to madpogue's Reputation
Smashed Rear Quarter Window saquib Miscellaneous Tech 11 02-06-2015 08:42 AM
quarter panel window seal 93SC2'in S-Series General 2 10-22-2008 03:07 PM
Installing a rear quarter window 1985 SL2 Ramjet1997 S-Series General 1 05-22-2006 12:27 PM
Rear quarter window (help) patcal S-Series General 0 11-05-2005 10:08 AM
how to replace quarter window on 92 SC? DJboozeAlot S-Series Tech 4 03-30-2005 10:38 PM
