Old 10-15-2007, 05:31 PM   #1
Jerz3455
Jerz3455 is on a distinguished road
1998 SC1
Default 98 Saturn SC1 SOHC, HIGH IDLE
Alright, this car has been kicking my butt all week. I have just recently aquired this car from someone, and ended up havin to change the motor. I put another one in, but when I start it up, it idles at 4500 rpm. At first she would idle at about 3000 rpm, and then I replaced the throttle body with the old one, and then it began idling at 5000. (just before redlining) So then I went ahead and replaced it back with the new one (that which came with the new motor from the junk yard), and it idles at 4000 now.. I dont know what esle to check. I removed the egr valve, sprayed some cleaner in it, and still havent helped much. And now, im starting to feel like cleaning the egr didnt help because I got a code 4 it now. But, im pulling three different codes. P0507:Engine RPM is higher than expected for the current operating conditions; P0122:Throttle positioning Sensor Circuit Low Input, and of course P0405: EGR Flow Sensor A Circuit Low Input. Im stuck. Please give me a solution.
Add to Jerz3455's Reputation
Rate the quality of this post and help Jerz3455 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jerz3455 is offline   Reply With Quote
Old 10-15-2007, 05:37 PM   #2
Default Re: 98 Saturn SC1 SOHC, HIGH IDLE
Really screamin' idle usually means a bigeffin' vacuum leak. Power brake booster hose, PCV valve hose, intake manifold gasket, something like that.
'Course, that 122 points to the TPS. Try tapping it with the handle of a screwdriver. If that settles the idle down, either the wire connection to the TPS is hinky, or the sensor itself is done for.
Add to madpogue's Reputation
Old 10-15-2007, 05:42 PM   #3
Jerz3455
1998 SC1
Alright... Because I want to say that I hear a little hissing sound when I shut it off.. Like when its shutting down, it sounded like it was an untightened hose, but I didnt want to make it worse than it already was.. Now out of the too sensors (on the throttle body), which one is the throttle positioning sensor?
Old 10-15-2007, 06:10 PM   #4
The TPS is the only sensor on the throttle body. It's on the end of the throttle plate shaft, on the back of the TB. The other connector on the TB is the IAC solenoid, which is toward the bottom of the TB.
Old 10-15-2007, 06:48 PM   #5
Jerz3455
1998 SC1
Well. U said towards the back of the the throtte body?? Because there are actually two sensors on it. Right before it bolts onto the intake manifold, there are two different sensors. I dont know which one is which. I even started the car without them connected, and it still idles very high.. BUT... As soon as I connect them, it instantaneously drops the idle speed for a split millisecond, and then continues to idle high..
Old 10-16-2007, 12:21 PM   #6
To repeat: there are two connectors. The "higher" one, right behind the throttle plate itself, is the TPS (throttle position sensor). The "lower" one is the IAC (idle air contro) solenoid.
Two connectors, one for a sensor, one for a solenoid.
Old 10-17-2007, 09:38 AM   #7
BarnOwl
BarnOwl's Avatar
+1 on the vacuum leak. Check your hoses for cracks and get some carb or brake cleaner and spray around the manifold gasket while the engine's running. If you hear a change in the idle, you've found the leak.
Add to BarnOwl's Reputation
Old 10-31-2007, 07:29 PM   #8
nivlem7
nivlem7 is on a distinguished road
How about the EGR valve? When I took mine off to clean it, I ran the car for about 5 seconds, and it really screamed, right up to the rev limit.
My car idles at about 2k when the car's warm and it's cold outside. Did it for the first time in about 6 months this morning. Replaced the ECTS about 6 weeks ago. This only happens after driving for at least a few minutes, then stopping and putting it in park or neutral. If I shut it off, then restart, it's fine.
Add to nivlem7's Reputation
Rate the quality of this post and help nivlem7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nivlem7 is offline   Reply With Quote
Old 11-01-2007, 10:37 AM   #9
That's because it was removed, which, by definition, constitutes a GI-NORMOUS vacuum leak (open port to the intake manifold). The EGR valve would have to be broken physically, structurally, as in cracked, and leaking vacuum to the atmosphere to do this. 'Course, the "spray something" vacuum leak test would reveal this.
Old 11-01-2007, 11:45 AM   #10
webbkarz
webbkarz is on a distinguished road
SOHC's are notorious for intake leaks right at the #1 cyl. Spray some carb clnr. there and you'll probably find it.
Del
'95 SC2
'93 BMW 325is
Tulsa, OK
Add to webbkarz's Reputation
Rate the quality of this post and help webbkarz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
webbkarz is offline   Reply With Quote
Old 11-26-2007, 02:48 PM   #11
Blammer
Blammer is on a distinguished road
1997 SW2
anybody got a pic of the TPS? that would help me!
97 SW2 270,000 miles and died when a tree fell on it.
Never argue with an idiot, they will only bring you down to their level and beat you with experience.
Add to Blammer's Reputation
Rate the quality of this post and help Blammer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blammer is offline   Reply With Quote
Old 11-26-2007, 03:13 PM   #12
jnk111
jnk111 is on a distinguished road
This is going to show my stupidity in trying to replace the IAC in a quick fashion. I had the exact same problem after replacing the IAC. Remove the IAC and pull the spring down, twist the rod so that is comes out further, then put it back in. I had to do this a couple of times, mine ended up so that I could not see the head looking through the throttle body. I tried to get it close to seated but not touching. I don't think this moves a whole lot after it is installed. It gives you a lot more air than needed at idle if it is not within specs. That's what I get for not reading the notes that came with the valve.
Just an FYI, This also cured my slow to return to idle and High revs, at least so far. I think that the IAC was not properly adjusted on the old one I removed, just a little too far out.
Add to jnk111's Reputation
Rate the quality of this post and help jnk111 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jnk111 is offline   Reply With Quote
Old 11-26-2007, 03:16 PM   #13
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
http://www.youtube.com/watch?v=KD51U5eofqo
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-26-2007, 05:25 PM   #14
Blammer
1997 SW2
thanks!
2000 SC1 High Idle & Misfire Gold Saturn S-Series Tech 4 06-01-2009 09:27 AM
99 SC1 High Idle jpleech S-Series Tech 6 01-12-2009 07:53 PM
high idle sc1-93 mobs241 S-Series Tech 1 10-22-2007 04:59 AM
High idle on 1996 SC1 frankk S-Series Tech 11 05-02-2007 07:37 AM
2002 SL 1.9L SOHC - High Idle Killjoy S-Series General 9 04-17-2006 07:35 PM
