Old 10-14-2007, 03:02 PM   #1
bnavarre
bnavarre is on a distinguished road
Thumbs Up Changing a starter on 97 Saturn
I looked for how-to on changing a starter on a 97 saturn before I tackled this job. I found a good description, but thought the below pictures and descriptions may help.
The steps I took to remove the starter were as follows:
1. Disconnect negative battery wire with 1/4" ratchet and 8mm socket.
2. Remove purple wire nut with 1/4" ratchet and 10mm deep socket.
3. Remove solenoid wires (2 of them) nut with 3/8" ratchet and 13mm deep socket.
4. Loosen bottom mounting bolt with 3/8" ratchet and 13mm deep socket.
5. Loosen and remove top mounting bolt with 3/8" ratchet, 13mm std. socket and 6" extension.
6. Hold on to starter and remove bottom mounting bolt.
7. Remove starter.
To install the new starter,
1. Hold starter in place and hand install bottom mounting bolt.
2. Adjust starter position to install and start top mounting bolt.
3. Tighten both mounting bolts.
4. Connect purple wire to starter and tighten 10mm nut.
5. Connect two solenoid wires and tighten 13mm nut.
6. Reconnect negative battery wire and tighten 8mm bolt.
Hope this helps. This job took me about 25 minutes to remove the starter and 10 minutes to install the new one. It took longer to remove because I tried several different sockets/ratchets to figure what was easiest.
PICTURES
Add to bnavarre's Reputation
Rate the quality of this post and help bnavarre reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bnavarre is offline   Reply With Quote
Old 10-14-2007, 03:58 PM   #2
1999greenSL2
1999greenSL2 is on a distinguished road
1999greenSL2's Avatar
Default Re: Changing a starter on 97 Saturn
This is excellent, thank you. I'm sure it will be moved to the How-To section.
Add to 1999greenSL2's Reputation
Rate the quality of this post and help 1999greenSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1999greenSL2 is offline   Reply With Quote
Old 10-14-2007, 04:13 PM   #3
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Here is a link to a you tube video replacing a saturn starter.
http://www.youtube.com/watch?v=teATcqz8uJ0
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 10-14-2007, 07:50 PM   #4
bnavarre
That video is awesome. Had I seen that before hand, it would have been a lot easier. He makes it look a little TOO easy though.
Old 10-15-2007, 11:07 AM   #5
Luke
Luke's Avatar
Words cannot express the true value of that video
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 10-15-2007, 07:54 PM   #6
93goldsl2
93goldsl2 is on a distinguished road
1993 SL2
I think the alternator is out of the way. (And the bolts have been broken loose already!) It's a nice vid.
Add to 93goldsl2's Reputation
Rate the quality of this post and help 93goldsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93goldsl2 is offline   Reply With Quote
Old 10-15-2007, 08:18 PM   #7
eljefino
eljefino's Avatar
1995 SW1
The right length of extention makes all the difference up top.
Even the 3/4" difference between a shallow and deep socket can save an hour of headache, b/c you get clearance for a longer lever to break that top bolt loose.
Otherwise as starters go, about the same as any other car.
Add to eljefino's Reputation
Old 10-15-2007, 08:57 PM   #8
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
If you look closely i think you can see the edge of the alternator in the vid.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-05-2016, 09:13 PM   #9
green1foru
green1foru is on a distinguished road
can I get a pic of the actual starter? I would like to see exactly where that upper bolt is located that mysteriously eludes me.
Add to green1foru's Reputation
Rate the quality of this post and help green1foru reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
green1foru is offline   Reply With Quote
Old 08-05-2016, 09:17 PM   #10
trottida
trottida's Avatar
Watch this video >> How to change the starter on an Saturn S Series
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 08-05-2016, 09:36 PM   #11
it's pretty well hidden when in place
some pics in this thread
http://www.saturnfans.com/forums/sho...d.php?t=170034
This shows the location pretty well, but also shows one of Low Saturn's great tips - after removing the starter bolts, toss them out and replace them with studs - he used IIRC the studs and nuts from the intake manifold
I flipped Hunt4Steve's engine photo here
Old 08-05-2016, 10:06 PM   #12
green1foru
you guys are awesome!! thanks!!
Old 08-05-2016, 11:28 PM   #13
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
That diagram in reply #11 is backwards (mirror image?), I suggest it be removed so as not to confuse a future reader.
Add to billr's Reputation
Old 08-06-2016, 12:43 AM   #14
Greg1
Greg1's Avatar
1997 SW2
It appears to be upside down.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-06-2016, 01:06 AM   #15
You mean it should be less confusing than Chilton's/Haynes showing a V6 engine and 5 lug wheels in it's '91-'98 S-Series book? lol
Old 08-06-2016, 06:04 PM   #16
billr
Turning it upside-down doesn't fix it either. Frankly, it doesn't even look like any of the S-series starters I have seen. Regardless of other reference sources having errors, why add our own here? Just delete the diagram.
Changing a Starter G20_Greenless S-Series General 8 05-02-2008 03:08 PM
SATURN starter problems 99 saurn SC2 S-Series Tech 3 12-05-2007 11:45 PM
changing a starter usmc4life79 S-Series Tech 18 01-30-2007 05:54 AM
Changing a starter SwampLaw Ion Tech 4 09-18-2006 11:44 AM
Changing a Starter on a 1997 SC1 georgiesweep How-To Library 4 12-08-2004 08:51 PM
