Old 07-23-2002, 07:08 PM   #1
SaturnSC1Freak
SaturnSC1Freak is on a distinguished road
Default 99 Saturn SC1 Coupe Problems
Sup?
I had some problems today. First of my car wouldnt start, which is a manual car. My battery was fine, but when i started to crank the car up, it wouldnt, all i got is the speedometer needles going up and down, but then i heard a weired noise. Its like something is stuck inside it. Could it be that i need a new starter? or some other problem. Please advice soon =D.
Add to SaturnSC1Freak's Reputation
Rate the quality of this post and help SaturnSC1Freak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnSC1Freak is offline
Old 07-23-2002, 09:07 PM   #2
Default
What kind of weird noise? A fast clicking? Then most likely the battery is gone or on has a low charge. So bad battery or bad alternator. Could a bad starter but that is not real common.
Add to ssicarman's Reputation
ssicarman is offline
Old 07-23-2002, 10:28 PM   #3
workin man
workin man is on a distinguished road
Default
Being a manual trans, it could also be the clutch safety switch. This will not allow the starter to engage unless you have the clutch pedal in ( failure of these switches are common to most makes)
Add to workin man's Reputation
Rate the quality of this post and help workin man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
workin man is offline
Old 07-23-2002, 11:33 PM   #4
HumpMan
HumpMan will become famous soon enough
Default
Do you have the Saturn Security System (Remote Keyless Entry)?
If that module has problems or there are some bad or corroded connections, it can prevent clean starting, as it has ignition kill as part of the security stuff.
My '97 SC1 had an intermittent starting problem that was solved by replacing the SSS module.
the HumpMan
Add to HumpMan's Reputation
Rate the quality of this post and help HumpMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HumpMan is offline
Old 07-24-2002, 06:34 AM   #5
HBII
HBII is on a distinguished road
Default
I'm curious about your problem with the SSS. My daughter's SC2 is experiencing intermittent problems too. One thing is that with the key in the "run" position (not "start") it starts every time with a push (manual transmission). Did you experience that, or even have the opportunity to do so? This problem is whipping a lot of folks here. I just want to get the car fixed.
Thanks in advance for your time.
-HBII
Add to HBII's Reputation
Rate the quality of this post and help HBII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HBII is offline
Saturn 97 Coupe SC1 - Speakers & Bass Sir Saula S-Series Tech 1 10-29-2008 05:15 AM
Fs: 96 Sc1 Coupe fracas Classifieds 2 12-27-2005 09:51 AM
99 Saturn SC1 3D Coupe CronStudio S-Series Mods 3 01-02-2003 05:25 PM
1999 Saturn SC1 3D Coupe Mods SaturnSC1Freak S-Series Mods 5 05-24-2002 12:58 PM
