Old 09-14-2007, 02:24 PM   #1
acman
acman has a spectacular aura aboutacman has a spectacular aura aboutacman has a spectacular aura about
1999 SC1
Default Needed: 2005 Chevy Aveo Rear Brake Drum Nut Torque Specification
Needed: 2005 Chevy Aveo Rear Brake Drum Retaining Nut Torque Specification. The nut has a 32 mm head
and holds the brake drum to the stub axle. The rear bearing is a sealed type, therefore, this nut is not used to
set the bearing pre-load. The nut was torqued to at least 150 ft-lbs and required a lot of effort to remove it (I'm
changing the rear brake shoes).
Add to acman's Reputation
Rate the quality of this post and help acman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acman is offline   Reply With Quote
Old 09-14-2007, 05:18 PM   #2
Zzyzx
Zzyzx is on a distinguished road
Zzyzx's Avatar
1995 SW2
Default Re: Needed: 2005 Chevy Aveo Rear Brake Drum Nut Torque Specification
... are you in the right forum?
“Don't lose your mind trying to set it free...”
2005 Silverado 1500CC
1995 SL2 - Gone, but not forgotten.
1995 SW2 - Gone, but not forgotten.
Add to Zzyzx's Reputation
Rate the quality of this post and help Zzyzx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zzyzx is offline   Reply With Quote
Old 09-14-2007, 05:52 PM   #3
mkuz13
mkuz13 is on a distinguished road
2009 AURA XE
148 ft-lbs going by the specs on alldata.
Want more gun control? Then use both hands.
Add to mkuz13's Reputation
Rate the quality of this post and help mkuz13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkuz13 is offline   Reply With Quote
Old 09-14-2007, 05:54 PM   #4
Low Saturn
Low Saturn's Avatar
2008 AURA XE
The tehnical term for it is a Caulking Nut and should be tightened to 148 lb ft or 200 N-m.
And remember to apply the brake 10 times before removing the drum.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
Rear Drum Brake Question Critik S-Series General 3 04-02-2008 09:56 PM
rear axle nut torque set green S-Series Tech 7 09-28-2007 05:51 AM
rear brake drum squeak! SL1commuter S-Series Tech 9 04-08-2007 09:14 AM
Rear Brake Drum Noise hipster35 S-Series Tech 5 02-22-2007 07:51 AM
Help. Torque specification tataat S-Series Tech 3 12-12-2005 02:40 PM
