Old 09-13-2007, 06:20 AM   #1
adamsaulnier
adamsaulnier is on a distinguished road
2002 SC1
Default Changing rear brake shoes
How difficult is it to change these yourself? My friend said its only an easy job that can be done without a lot of tools. I don't want to discount his knowledge (he's not an auto mechanic but knows a lot of stuff) but I'm a little skeptical on how simple this job is supposed to be. I searched the how-to section for this and nothing came up, so if someone can help me I'll be glad.
Add to adamsaulnier's Reputation
Rate the quality of this post and help adamsaulnier reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adamsaulnier is offline   Reply With Quote
Old 09-13-2007, 07:49 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Changing rear brake shoes
It's not too hard. It's just a bunch of springs holding things together. Take the drums off both sides but, work on one side at a time. That way you can go over to the other side and use it for a reference when you forget where something goes. If your friend has ever done a drum brake, he can probably do these. The basic design hasn't changed in well over 50 years. Here's a couple pics that might help.
Add to BarnOwl's Reputation
Old 09-13-2007, 08:02 AM   #3
Ls1Junky
Ls1Junky is on a distinguished road
It's not too bad, figuring out how to get it back together can be a little tricky if you don't get it right the first time, but at least the other side goes smooth. Only problem I have till this day is that the drums grab harder in one spot? giving the car that warped rotors feel under cterain conditions. Kind of annoying but better then a shaking wheel from bad rotors...
Blue 2002 sl2 52k
2001 Trans Am Ws6 340 rwhp 360rwtq
Past: Gold 1997 Sl2 125k...totaled :(
Add to Ls1Junky's Reputation
Rate the quality of this post and help Ls1Junky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ls1Junky is offline   Reply With Quote
Old 09-13-2007, 08:02 AM   #4
denisond3
denisond3 is on a distinguished road
1996 SL1
I just did the rear brakes on the 92 SL2 we just bought. The car spent its early life in Ohio, where they use lots of salt on roads in the winter. I scraped a coating of rust off of the outside of the drums and repainted them with rustoleum. I also bought a new set of the little springs, and new wheel cylinders since I always do that when a car is 12-15 years old, and new shoes of course. The cylinders, shoes and springs were inexpensive. They were about the easiest brakes to fix that I can recall. The advice to only dismantle the springs and shoes from one side at a time is important.
Be sure to use a 6 point metric wrench on the bleeder screw, and if you replace the wheel cylinders, be sure to also use only 6 point metric wrenches on the wheel cylinder bolts and the brake hose 'banjo' bolt.
Add to denisond3's Reputation
Rate the quality of this post and help denisond3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
denisond3 is offline   Reply With Quote
Old 09-13-2007, 08:15 AM   #5
adamsaulnier
2002 SC1
I only intend to replace the shoes, so what is the process?
Push down on the shoes, then unclip the spring from the unit and they should easily come off? Is there anything else I should be aware of that I should check on when I'm inside the assembly?
Thanks for the input so far, I appreciate it a lot.
Old 09-13-2007, 08:40 AM   #6
denisond3
1996 SL1
I am going by the rear brakes on my 92, so I hope yours arent different. You will need to undo two springs mounted horizontally, and the two springs that are coils, and hold the shoes to the brake backing plate. I use pliers for these 4 springs. There is another spring having to do with the self-adjusters. The hardest spring to work with is the one on the end on the handbrake cable. You have to get that cable off, or else you have to try to change the rear brake shoe right there at the rear axle. This is because the handbrake cable pulls on a lever that is pivoted on the rear brake shoe. Its about the same as on any car with drum brakes made in the last 50 years though. There is a "C" clip you have to 'expand' to remove it, and to re-squeeze it after you put the new shoe on the actuating lever. Make sure the lever will swing back and forth without much effort.
With new brake shoes, you always run the self-adjuster 'star wheel' fully back into its housing before you reassemble. Dont worry if the drum wont turn freely when you put it back onto the hub. As long as you can turn it by hand at all, it will settle in when you first take the car out for a test drive.
P.S. When I work on my brakes on any car, the first test drive involves an 'emergency stop', where I purposely try to push the brake pedal to the floor. If you dont have ABS brakes, the wheels should lock up, and the car should stop in a straight line with your hands off the steering wheel. If anything is going to go wrong, I want it to happen on a deserted side road, not when someone steps off a curb in front of me. Once when I did this, I had to repair the seat track mechanism.
What you look for inside there, is any sign of fluid leakage from the rubber seals on the end of the wheel cylinders.
Old 09-13-2007, 09:30 AM   #7
BarnOwl
BarnOwl's Avatar
Personally I always replace the wheel cylinders when I do the rear brakes but, it's your choice. It's a little more complicated than you are saying and it's not near as easy as disk brakes. There are pins that come through the backing plate that go through the brake shoes, then through a spring, and then through a round doodad. In the exploded diagram I posted, these are labeled pin, hold down spring, and cup. The pin has a kind of shovel end and the cup has a slot where it goes through. You have to push in the cup and turn it so the shovel end of the pin lines up with the slot. Then the cup and spring can be removed. Once you get them both off, you can pull the shoes out but, there are three or four springs and some other parts that will come with them. It's not going to be a bit obvious how to get it all back together. That's why you need to have the other side to look at.
You sound like you expect this to be like changing the plugs. It's not too terrible but, it's more complicated than you make it sound.
Old 09-13-2007, 11:49 AM   #8
adamsaulnier
2002 SC1
Thats the thing, my friend said it was easy. I'm considering getting the work done at a garage because I don't know if its as easy as he says it is.. hence why I'm asking the question now to find out if he's right
Old 09-13-2007, 12:24 PM   #9
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
Truely ;
The hardest drum brakes i've ever encountered ,NOT that the design is any different from other cars ............
It is getting all those springs in behind the plate the lugs are in ect.
maybe the view is different ,when the car is on a lift !
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 09-13-2007, 09:10 PM   #10
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
See if this might help make up your mind.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-13-2007, 09:22 PM   #11
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Hey Barn owl, where did you purchase that puller drum tool to pull off the drum? What size is it?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 09-13-2007, 09:44 PM   #12
Greg1
Greg1's Avatar
1997 SW2
I'm really impressed with your video. Hopefully it ends up in the How To library.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-13-2007, 10:08 PM   #13
eljefino
eljefino's Avatar
1995 SW1
Once you do one set of drum brakes you have a skill that will follow you forever.
They don't look that likely to change much in the future either.
That stupid little nail in the middle of each shoe is what holds it in, but the heavy duty springs that hold the front shoes to the rear shoes lock various tabs against other immovable objects. Then the drum itself really makes sure nothing falls out. When it comes time, push in on that nickel sized spring cap with a pliers and you'll feel a nail poking out of the backing plate. Hold that with your other hand and you can compress the little spring, twist, and the spring "hat" will come off along with all the junk behind it.
My advice is to get both drums off then just go nuts removing springs on one side. Eventually you'll have a huge pile of curvy levers and springs that all fall off at once.
If you have a digital camera take lots of pics as you dismantle. Use flash as the shadows help determine what goes on top of what else.
Add to eljefino's Reputation
Old 09-14-2007, 09:51 AM   #14
BarnOwl
BarnOwl's Avatar
That's just a three finger gear puller. It's not made specifically for brake drums. I've had it for years. I either bought it at a parts store or a flea market. I really don't remember.
You usually don't need a puller. Usually banging in around the edges of the drum with a hammer will get it loose enough to come off.
Old 09-14-2007, 12:31 PM   #15
Ls1Junky
Does anybody have any ideas as to the problem I mentioned earlier? The way the drums catch harder in one spot causing a pulsating effect.
Blue 2002 sl2 52k
Old 09-14-2007, 12:46 PM   #16
richpin06
richpin06's Avatar
Your drums are running out.You will have to turn them or replace them with new.
Old 09-14-2007, 12:55 PM   #17
Ls1Junky
^^Drums and shoes are new.
Blue 2002 sl2 52k
Old 09-14-2007, 01:20 PM   #18
adamsaulnier
2002 SC1
Wow thanks for that great video, it really made me feel more confident about doing it.. at least I have something to follow now.
Old 09-14-2007, 01:29 PM   #19
TXSaturn02
TXSaturn02's Avatar
Could this be the dreaded condition caused by not breaking in your pads correctly when new?
New owner As of 01/01/18: 225,000 Miles
As of 06/15/18: 49,365 Miles
Old 09-14-2007, 01:32 PM   #20
richpin...of course you get to simply pull the drum off. Me, on the other hand spend 30+ minutes with a 12lb hammer and a huge freaking screwdriver attempting to pry it off w/o screwing the backing plate. Guess thats because the cars I've done it on sat for at least a year but still.
Once I get around to doing the rear brakes on mine I'll just beat the $h1t out of the drum/hub/crossmember just because I can as a new (painted black) setup is going in with disk brakes and a sway bar
Saved the video anyway...never done drum brakes before so seeing it done might be helpful, thanks.
Rear brake shoes, yes or no? BryanF Vue General 7 07-26-2009 10:46 AM
I need help fast(changing rear shoes/drums 2003 saturn ion) ionracing1979 Ion Tech 3 12-08-2008 08:40 PM
Replaced Rear Brake Shoes vue04 Vue Tech 3 07-23-2008 11:06 AM
Question about rear brake shoes Phredawgy S-Series Tech 2 02-23-2007 09:26 AM
rear brake shoes homieg9999 S-Series General 4 11-19-2006 11:54 AM
