Old 09-06-2007, 06:53 PM   #1
sl2gold
sl2gold is on a distinguished road
sl2gold's Avatar
Default When to change the fuel filter?
I'm wondering how often it should be changed, my '99 has 60k on it now even though I've ckept up on the maintenance stuff, it seems to be slowly getting lees responsive. The clutch isn't slipping, I cleaned the t/b and injectors last Nov., new NGK plugs and wires in Jan. and oil changes roughly every 3k give or take. But I'm having to mash on the gas and wait for it hit 4k to get moving with traffic so I'm wondering if there's anything I missed like the fuel filter. I was told that the fuel pressure regulator and the fuel filter are the same thing, could that be the problem ? How often do you guys change yours? BTW could it be my exhaust leak ?
Add to sl2gold's Reputation
Rate the quality of this post and help sl2gold reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl2gold is offline   Reply With Quote
Old 09-06-2007, 07:59 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: When to change the fuel filter?
check your Saturn Owner's Handbook -- my 92 SC and 96 SC2 fuel filters were replaced every 48, or 60,000 miles. my 2002 SC2 is 100,000 miles.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 09-06-2007, 07:59 PM   #3
edlee
edlee will become famous soon enough
1999 SL1
I changed my fuel filter after I had trouble starting my car unless I primed the fuel pump first. The problem happened after I used this gasoline additive called MotorSilk which uses fine boron particles which I suspect clogged the fuel filter. An independent tester whose results are posted on the company's site also noticed a reduction in fuel flow after using the product and had to replace the fuel filter. My 1999 SL1 had less than 35,000 miles on it at the time. I have had no trouble starting the car since I replaced the fuel filter/pressure regulator.
Add to edlee's Reputation
Rate the quality of this post and help edlee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edlee is offline   Reply With Quote
Old 09-06-2007, 10:12 PM   #4
adhsc2
adhsc2 is on a distinguished road
adhsc2's Avatar
if its a 99 with 60k on the clock, change it up, just for good measure. then, change it again at about 125-150k.
1995 Saturn SC2
Screw engines...I R HAVS A POWER MODULE!
Member of: Saturn Tuners Club - Southeast
Add to adhsc2's Reputation
Rate the quality of this post and help adhsc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adhsc2 is offline   Reply With Quote
Old 09-07-2007, 08:29 AM   #5
BarnOwl
BarnOwl's Avatar
Actually in '98 the fuel pressure regulator was made part of the fuel filter and the manufacturer recommended change interval went to 100K. So, you have a ways to go.
Add to BarnOwl's Reputation
Old 09-07-2007, 08:53 AM   #6
TXSaturn02
TXSaturn02 will become famous soon enoughTXSaturn02 will become famous soon enough
TXSaturn02's Avatar
Lots of responses, but no solution. Keep us posted on what you try and if it helps or not. My car has 85K and it is still on original everything except PCV, belt, battery (2), tires, plugs and wires (at 60K). Still runs like new, but it is 3 years newer so...........
Good luck with your troubleshooting.
Sticker: $13,995
As of 06/13/13: 181,311 Miles
Old 09-07-2007, 12:17 PM   #7
BarnOwl
BarnOwl's Avatar
Hmmm I thought I gave him the solution.
To make it real clear. On a '99, go with Saturn's recommendation 100,000 miles.
Old 09-07-2007, 12:54 PM   #8
sl2gold
sl2gold's Avatar
Sounds like I still have ways to go before replacing that then. But if I still can't get to the bottom of this mystery, I may have it looked at later. It's not a clogged cat, the guy at the muffler shop checked. The oil was just changed, maybe it's the EGR valve. I'll mayget to that next week.
To be continued.....
Old 09-07-2007, 01:02 PM   #9
TXSaturn02
TXSaturn02's Avatar
No offense Barnowl. You made that part clear, but as he said it doesn't resolve the problem he is having with the poor performance of his car - which is what I was getting at.
Sticker: $13,995
Old 09-07-2007, 01:16 PM   #10
AJT_Leo
AJT_Leo is on a distinguished road
AJT_Leo's Avatar
I say change the filter now. But then again, maybe he should wait and follow the factory timeline.
Now how's that for a solution.
The bureaucracy is expanding to meet the needs of the expanding bureaucracy.
Add to AJT_Leo's Reputation
Rate the quality of this post and help AJT_Leo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AJT_Leo is offline   Reply With Quote
Old 09-07-2007, 11:07 PM   #11
eRic 02sc2
eRic 02sc2's Avatar
Lots of responses, but no solution. .
reading the Saturn S-Series Owner's Handbook is a solution my 2002 maintenance schedule says replace the engine fuel filter at 100,000 miles. 1992 and 1996 had different mileages listed since they had the old style fuel filter that was separate from the fuel pressure regulator.
eRic 02sc2
Old 09-08-2007, 12:07 AM   #12
bskicrash1
bskicrash1 is on a distinguished road
bskicrash1's Avatar
Location: Norwich NY 1993 Sukuki GSX-R 750 2002 Kawasaki Ninja 250r
2000 SC2
I know you stated that you cleaned the injectors... but when I get those same symptoms on my saturn, I add a full bottle of fuel injector/carberator cleaner to a 1/4 tank of gas and then will run that tank to almost empty, add just enough gas to get it back to a 1/4 tank and run another bottle of fuel injector/carb cleaner through...
My symptoms go away after this.
I use the cheap 3 for $2.50 supertech brand available at walmart... i've also used the stp brand also, but with supertech I can get 3 for the same price as one bottle of stp.
Robert
Add to bskicrash1's Reputation
Rate the quality of this post and help bskicrash1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bskicrash1 is offline   Reply With Quote
Old 09-08-2007, 06:44 AM   #13
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1997 SW2
I changed my fuel filter at 116k miles. Dunno if it had been changed before, the one I put on looked a lot different then the one I took off.
Made about the same difference upgrading the ECTS did...none.
I bet if it had been clogged before I replaced it it would have made a difference but it wasn't and didn't.
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 09-08-2007, 08:06 AM   #14
dcp
dcp is on a distinguished road
dcp's Avatar
I waited for 100,000 like the book says.Be ready to pay 100 dollars or more.It is $.That might make you wait like I did.
Add to dcp's Reputation
Rate the quality of this post and help dcp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcp is offline   Reply With Quote
Old 09-08-2007, 03:40 PM   #15
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
Did you replace the ECTS??????
If it ain't broke it's over designed.
Add to alleninpa's Reputation
?'s about serpentine belt change and fuel filter change on '94 SL2 demontrace S-Series Tech 8 07-03-2008 02:48 PM
Fuel filter change. mpbrown18 Vue General 0 04-28-2006 10:15 AM
Change fuel filter? 94SW2 S-Series Tech 7 01-22-2006 07:12 PM
Change fuel filter on 97 SL1 tataat S-Series General 0 07-17-2005 08:46 PM
Should I change the fuel filter? BullyCanadian S-Series General 3 06-20-2005 09:14 PM
