Old 09-04-2007, 12:42 PM   #1
lg540
lg540 is on a distinguished road
1996 SL
Default hoping to verify it's my starter that's bad
Hello, My car is a 1996 SL, manual trans with 217k miles. I just got my car on the road again after chasing a problem with EGR/MAp sensor codes that turned out to be electrical - a bad wire between the PCM and fuse box.
I was out driving on the weekend and the car was running fine. then after one stop the car wouldn't start. It had been starting fine, even just minutes before. Of course first thought was battery, alternator but there was power. Starter just clicks away.
Manaul tranny YEAH!!!
The car did pop start.
Seems like a no brainer but after throwing parts at my last problem I'm just looking for a sanity check before I go get a new starter (which has been replaced one in the 217k miles)
Thanks Saturn Fans is the best!
Add to lg540's Reputation
Rate the quality of this post and help lg540 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lg540 is offline   Reply With Quote
Old 09-04-2007, 01:07 PM   #2
Default Re: hoping to verify it's my starter that's bad
I hate you people with manuals.. So easy to pop the clutch when the starter's dead!? Ok, yeah I'm jealous.....
Anyway, have a look to be sure the wirings ok by the starter then be sure the battery's charged and the cables are good and clean, free of corrosion in and under the cable clamps hidden from the heavy insulation before condemning the starter. Remove the cables for examination if necessary. If the battery's older than four years it may be time for replacement, sooner according to the HOT state of Arizona () that likes to cook batteries in the desert sun. Try the starter again after a battery charge but if in doubt take the starter to your favorite store for testing for a final analysis. We all get dizzy sooner or later.
Old 09-04-2007, 01:08 PM   #3
aja8888
aja8888 is on a distinguished road
aja8888's Avatar
Sounds like the starter solinoid is shot.
Add to aja8888's Reputation
Rate the quality of this post and help aja8888 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aja8888 is offline   Reply With Quote
Old 09-04-2007, 01:25 PM   #4
lg540
1996 SL
I was so against a manual tranny when we weref irst choosing a new car since I lived in LA at the time...
Yeah, my battery is about 4 years old. While it seems like the starter solenoid, maybe I'm being fooled into thinking that. Maybe there is enough battery power to turn on the accessories but not enough to start the car.
Definetly worth checking the battery and connections before going for the starter.
THX
Old 09-04-2007, 01:58 PM   #5
oseberg
oseberg is on a distinguished road
Try jump starting it. If that fails, then it's probably not your battery.
I had the same problem. The battery was supplying enough power to run everything, as well as enough to click the solenoid. But not enough to turn the starter even a tiny bit. The actual problem was a negative battery terminal that was corroded through on the inside. I found out when I went to remove the battery and the whole terminal came off with the bolts that screws into it.
Add to oseberg's Reputation
Rate the quality of this post and help oseberg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oseberg is offline   Reply With Quote
Old 09-04-2007, 02:08 PM   #6
Jon Boy
Jon Boy has a spectacular aura aboutJon Boy has a spectacular aura aboutJon Boy has a spectacular aura about
Jon Boy's Avatar
If I understand right, a clicking starter can pretty much only mean a bad solenoid. Does it start fine when the it's cool? In my wife's car, the brushes in the solenoid expand when it gets hot, and then they seize and it clicks once or twice before starting.
Add to Jon Boy's Reputation
Rate the quality of this post and help Jon Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jon Boy is offline   Reply With Quote
Old 09-04-2007, 02:20 PM   #7
oseberg
Well, mine was just clicking (nothing more) and then I replaced the battery, and haven't had a problem with my starter since. It doesn't take much power to make it click, but it does take a lot to make it crank the engine over.
Old 09-06-2007, 09:56 AM   #8
lg540
1996 SL
I was leaning towards battery. I read that that if it clicks only once, it's likely the solenoid. If it keeps clicking, it's likely the battery. But I tried jumping it and it still just kept clicking.
It was warm when this first happened but of course is cool now - no change.
Old 09-06-2007, 10:26 AM   #9
Are the cables in good clean condition on both ends? It can be tricky if the battery connections aren't just right with no visible signs of corrosion with a failure to start using booster cables. If they are you have no choice but to remove the starter and take it to a place for testing. You'll know if its the starter after testing.
Old 09-06-2007, 03:40 PM   #10
kornphlake
kornphlake is on a distinguished road
I've had two starters go bad just like you describe, they only click when the engine is hot. Does the car start once it's cooled down? How about if you reach under the car and tap the starter with a hammer then try starting it? I've got a theory that the bearings in the starter like to bind when they are hot once they get a few thousand miles on them. Have the battery tested first, really it's more likely to fail and it's easier to test.
Add to kornphlake's Reputation
Rate the quality of this post and help kornphlake reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kornphlake is offline   Reply With Quote
Help me diagnose a bad starter or bad battery connections number9 S-Series Tech 15 07-05-2011 11:01 PM
Battery, Alternator or Starter? 94 SC1 - I think battery (here's to hoping!) Mark2000 S-Series Tech 14 12-19-2008 10:01 AM
Bad starter? GlennCoco S-Series General 10 09-07-2008 02:53 PM
bad starter? ever seen this? saturnhouse S-Series Tech 4 06-28-2008 11:42 AM
bad starter? moose27 S-Series Tech 11 12-15-2005 12:59 PM
