Old 08-28-2007, 11:09 AM   #1
tackepj
tackepj will become famous soon enough
tackepj's Avatar
2008 Astra XE
Default GM experiments with new HCCI engine in Aura
Follow the link to an interesting article from Inside Line:
http://www.edmunds.com/insideline/do...ticleId=122346
Here is the text:
"DETROIT While the Volt plug-in hybrid has made lots of headlines for General Motors, the company wants us to know that it's still busily refining gasoline and diesel engine technology.
Its latest effort is the HCCI internal combustion engine, a spark-ignition piston engine that can operate as a compression ignition motor, similar to a diesel. GM installed a version of the engine in both a Saturn Aura and an Opel Vectra and let us drive them around its proving grounds in Milford, Michigan.
General Motors says HCCI (Homogeneous Charge Compression Ignition) can yield a 15 percent improvement in fuel economy. But there are a few caveats. First, GM Powertrain Chief Tom Stephens says the technology won't likely reach production before 2015. And second, this impressive number includes the cumulative efficiency of variable valve timing and lift as well as direct injection, both of which must be in place for compression ignition to operate.
Compression ignition is all about the temperature inside the combustion chamber. In compression-ignition mode, the exhaust valves close earlier, trapping some of the heated air from the previous combustion cycle. This warms the incoming fuel mixture sufficiently to produce ignition once it's compressed by the piston. Clever stuff. But when the engine is under load while accelerating, for example the engine must transition back into spark mode to make full power.
This translates into a very narrow window of operation for compression ignition. Both light and heavy throttle applications sent the Ecotech four-cylinder into its default spark ignition mode. In fact, we were seldom able to keep the engine running on compression ignition mode. There's no mystery about the onset of compression ignition, as the engine starts knocking like an ancient diesel.
At this point, HCCI attracts far more attention from the driver than it should, and we're not yet persuaded that its effect will be greater than simple cylinder deactivation. Still, the gasoline engine clearly has a future, and we give General Motors credit for giving us a run in what is still a laboratory rat.
What this means to you: Mercedes-Benz is about to announce this technology at the 2007 Frankfurt Auto Show, so count this as one way in which the General is leading the way into the future."
Add to tackepj's Reputation
Rate the quality of this post and help tackepj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tackepj is offline   Reply With Quote
Old 08-28-2007, 11:31 AM   #2
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Default Re: GM experiments with new HCCI engine in Aura
Peccles posted this in the "general" Saturn a while back (http://www.saturnfans.com/forums/sho...d.php?t=105159). This is interesting technology, but has its place -just like hybrids. Paricularly; it's back to spark ignition with speeds over 55. No doubt, those city drivers would see the most benefits. It would probably be some interesting employment if combined with a hybrid.
Old 08-28-2007, 11:49 AM   #3
zielinab
zielinab is on a distinguished road
2008 Outlook XR
Or with the E-Flex system (a la Chevrolet Volt concept), where it could be optimized to run in the sweet spot in HCCI mode to recharge the batteries...
Add to zielinab's Reputation
Rate the quality of this post and help zielinab reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zielinab is offline   Reply With Quote
Video: Driving the Saturn Aura HCCI Prototype at GM Charlie Aura General 3 09-14-2009 08:36 AM
First Drive: Saturn Aura and HCCI Charlie Aura General 1 05-20-2008 09:18 AM
Gm Demonstrates Fuel-saving Engine Technology Breakthrough With Hcci-enabled Aura bc3tech Aura General 22 05-07-2008 06:42 AM
GMs new Homogeneous Charge Compression Ignition (HCCI) engine platform BobbyP Aura General 17 09-08-2007 09:47 AM
HCCI Gas Engine Tested in Aura peccles Aura General 3 08-27-2007 01:13 PM
