Old 08-28-2007, 12:27 AM   #1
oseberg
oseberg is on a distinguished road
Default 95 SL2 just started running funny.
When I got about a block from home tonight on my way home from work my 95 SL2 started to run a bit funny.
It seems to run fine when I tried to accelerate, but when I pressed the gas just enough to keep the engine running at the same speed I was traveling (around 35 mph in 4th gear) it seemed like the engine was loosing and regaining power.
The check engine light has not turned on yet, so there are no codes. Also the engine now dies when idling. The temperature was just below 1/2 on the gauge. I pulled the plug wires and they weren't wet or oily. The engine was hot so I didn't remove the plugs yet to look at them. The ECTS was replaced a few years ago before the car was mine and before I knew the difference between the plastic and brass ones. It was obtained from a Saturn dealer for $19.
I'm about to go remove the plugs to take a look at them. The auto parts stores around here are closed right now so I can't pick up new plugs and wires until tomorrow.
Any guesses as to what might be wrong?
Add to oseberg's Reputation
Rate the quality of this post and help oseberg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oseberg is offline   Reply With Quote
Old 08-28-2007, 01:31 AM   #2
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
Default Re: 95 SL2 just started running funny.
Disconnect the EGR and if the problem goes away you have identified the source! Make sure you drive it to normal operating temps so it goes out of open loop mode when you test it.
Add to plastic torpedo's Reputation
Rate the quality of this post and help plastic torpedo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plastic torpedo is offline   Reply With Quote
Old 08-28-2007, 01:56 AM   #3
oseberg
I should have thought of that. Good idea. I'll give it a try.
I removed the plugs, and 3 of them are covered in a thin coating of black soot. One is white. The black ones look like they're either fouled or getting fouled.
Old 08-28-2007, 11:31 AM   #4
oseberg
I regapped my plugs and reinstalled them, and it ran exactly the same. Then while it was running I went and unplugged the EGR and there was no change. Then I reved the engine up to 2000 rpm. It slowly dropped down to 1200 and ran much better. As it warmed up it gradually dropped down to 900 and continued to run fine.
So I guess it's time to start cleaning out my EGR valve.
Boy do my plugs look bad, I'm supprised they're not the problem.
Old 08-28-2007, 11:35 AM   #5
kornphlake
kornphlake is on a distinguished road
In other car forums the first suggestion would be to replace the fuel filter, if that doesn't help or if you know the filter is fairly new I'd start looking for vacuum leaks, Saturns are weird though when it comes to sluggish or surging accleration, people never seem to have the problems common to other vehicles, it's usually some sensor completely unrelated to fuel delivery, oxygen intake or spark but the PCM goofs up everything else because the one sensor is giving incorrect information.
Add to kornphlake's Reputation
Rate the quality of this post and help kornphlake reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kornphlake is offline   Reply With Quote
Old 08-28-2007, 12:15 PM   #6
adhsc2
adhsc2 is on a distinguished road
adhsc2's Avatar
welcome to saturn! even odd ball fuses that are not in line with many things can make lots of things stop working.
1995 Saturn SC2
Screw engines...I R HAVS A POWER MODULE!
Member of: Saturn Tuners Club - Southeast
Add to adhsc2's Reputation
Rate the quality of this post and help adhsc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adhsc2 is offline   Reply With Quote
Old 08-28-2007, 01:08 PM   #7
BarnOwl
BarnOwl's Avatar
I like the chime fuse. Who'd have thought that one fuse would stop the radio, the dome light, and the rear window defogger.
Add to BarnOwl's Reputation
Old 08-28-2007, 01:47 PM   #8
Luke
Luke's Avatar
Fm > Plastic Torpedo
Additionally, though, if there is any small pieces of carbon, lodging open the central pintle, disconnecting the EGR will not absolve the issue.
It would be better to take the unit off, and examine it -- while at the same time, cleaning it.
I am somewhat surprised that the SES light did not come on, thus setting a code into memory [#39].
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 08-28-2007, 02:00 PM   #9
oseberg
I believe something caused my EGR valve to stick open. Removing the cable didn't do anything since it was still stuck open. Revving the engine seemed to break it loose, so now it's shut so that the engine can idle fine.
The EGR is still disconnected and the engine is running fine, but now the SES light is on.
Of course the problem isn't solved. It has just been isolated to the EGR valve. And of course I'll be removing and cleaning it as soon as I get a chance. Also while I have it off I'll be cleaning out the ducting in the head and intake manifold as best I can.
In any case, now that I think about it, if the EGR were permanently lodged open, removing the cable to it might have had no effect incorrectly leading me to believe that the EGR was not the problem. Luckily that wasn't the case or I might have wasted a ton of money and time replacing my plugs, wires, and every sensor in the engine trying to locate this problem.
still running funny cocacolacowboy S-Series Tech 26 03-23-2009 11:05 AM
93 sl2 really rough running daddio S-Series Tech 8 04-12-2008 01:41 PM
running temparture for 94 sl2 zoso007 S-Series General 12 07-13-2007 05:17 PM
Tranny acting funny on 99 SL2 angusW S-Series General 3 05-23-2005 07:14 PM
94 SL2 running bad chris94sl2 S-Series Tech 2 05-12-2005 04:46 AM
