Old 08-26-2007, 08:03 PM   #1
kbg1
kbg1 is on a distinguished road
2008 Astra XE
2003 ION-2 Sedan
Sad Swaybar/Control arm Bushings Question
hi
our 2005 ion has 50,000kms(canada) on it.
just had the provincial safty inspection done by saturn.
we needed to replace the control arm bushings,and swaybar bushings(4 total).
this is the third time in 2 years that we have needed either individual or sets of these replaced.so far they have all been under warranty.
1st time at 10,000kms 2 replaced.
2nd time at 22,000kms 2 replaced.
3rd time 50,000 kms 4 replaced.
our warranty runs out in 10,000kms and i am really worried as this seems to be an ongoing problem with our ion.this could be a substantial yearly expense.
our 2005 cavalier has 73,000kms on it and has never had any suspension parts replaced(or any parts(except tires/brakes) for that matter).
both are driven over the exact same road(paved) daily.
my questions are:
are these expensive to replace out of warranty?swaybar or control arm?
is there an updated part the has better wear characteristics available?
after a search of the forums,i see this was a problem with 2003/2004 but they were supposed to have an updated part that wears better on the 2005 models,is this true?
thanks as always
jeff
Add to kbg1's Reputation
Rate the quality of this post and help kbg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kbg1 is offline   Reply With Quote
Old 08-26-2007, 09:07 PM   #2
Tethys
Tethys is on a distinguished road
Tethys's Avatar
Default Re: Swaybar/Control arm Bushings Question
Hey Jeff,
I owned a 2004 Ion 2 sedan and now have a 2006 Ion 3 sedan. Sometime in 2005, the plastic bushings in the older models were replaced with metal ones. I had them swapped out 3x on the 2004, so far I've only heard them once squeak once in this car (when it was below 0 C outside) and they've not had to be replaced. I have approximately 38,000 kms on the car at the moment.
You should check into whether the metal parts can be retrofitted to your car. That should save you time and money if you plan on keeping this car for a while.
Hopefully others more technically oriented can provide you with more information.
Chuck
2015 Buick Verano Turbo
5 - 2006 Ion 3 Sedan, Manual, Storm Grey
4 - 2004 Ion 2 Sedan, Manual, Electric Blue
3 - 1996 SL2 Manual, Medium Red
2 - 1991 SL1 Manual, White
1 - 1991 SL Manual, Grey
Add to Tethys's Reputation
Rate the quality of this post and help Tethys reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tethys is offline   Reply With Quote
Old 08-27-2007, 01:40 AM   #3
new_thoughts
new_thoughts is on a distinguished road
new_thoughts's Avatar
2003 ION-3 Sedan
Happy Re: Swaybar/Control arm Bushings Question
you could also just get replacement ones from autozone.com for like $10-$30.
there very simple to remove and replace.
just be sure that you use the proper lube or they will make weird sounds.....
Add to new_thoughts's Reputation
Rate the quality of this post and help new_thoughts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
new_thoughts is offline   Reply With Quote
Old 08-27-2007, 08:34 AM   #4
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
if you're going to all this trouble, just get a redline front sway and those bushings. they've treated me just fine, plus you'll get more responsive cornering out of the car.
+rep always appreciated!
The Procharged Ion - http://kickassion.bc3tech.net
16.317s @ 85.30mph (Nearly stock)
188.28whp / 175.03wtq - SMP Stage 2 - 10psi
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 08-27-2007, 01:28 PM   #5
Nismo
Nismo is on a distinguished road
Nismo's Avatar
2006 ION-2 Sedan
You think that would that cure the massive understeer I have on my sedan? I have 15'' Lightweight drag wheels, Monroe Sensatrac strut/shocks, Springtech Springs, and Progress 22mm RSB. She handles great but my lord if I dont feel like I have to turn the wheel excessively to get her to go where I want.
Add to Nismo's Reputation
Rate the quality of this post and help Nismo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nismo is offline   Reply With Quote
replacing lower control arm bushings mikabl Ion General 36 03-31-2012 05:45 PM
Control Arm bushings - wtf? Bruticus Ion Tech 16 08-01-2009 09:12 PM
lower control arm bushings paulo Ion General 4 02-16-2009 10:57 AM
control arm bushings DHOOP S-Series Tech 7 10-05-2006 08:35 PM
My '94 SL2 eats control arm bushings! RexSpeed S-Series Tech 7 09-27-2005 05:15 PM
