Old 08-26-2007, 03:55 PM   #1
Ralphs
Ralphs is on a distinguished road
Default Another Saturn for my fleet?
Looked at another Saturn today (this would make #3) for another stepchild. '97 SL2 with 120K. Clean inside, slightly cosmetically challenged outside (few scrapes). Automatic, power door locks, p windows, and remote for both windows and locks. A/C works fine.
Slight oil leak from both valve cover and PCV valve.
I don't have any repair history (I will check dealer with VIN# tomorrow). Oil filler cap was kind of cruddy. No apparent leaks of any kind under engine.
New radiator and major hoses, new exhaust (looks new from cat back).
Typical rust under passenger door sill, not too bad.
Engine runs OK, clunk in front end over bumps.
Pobably needs brake work (soft pedal is identical to other stepdaughter's 96 SL2 problems which were resolved with rear cylinders and front calipers), although stops OK.
Very minor reverse slam.
They are asking $1500. I think I can get for $1000 or less.
Any opinions?
Thank you,
Ralph
Add to Ralphs's Reputation
Rate the quality of this post and help Ralphs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ralphs is offline   Reply With Quote
Old 08-27-2007, 07:36 AM   #2
1999greenSL2
1999greenSL2 is on a distinguished road
1999greenSL2's Avatar
Default Re: Another Saturn for my fleet?
Sounds like an awesome deal to me, even for $1500... I paid way more than that for mine a month and a half ago, and it needed some maintenance.
Add to 1999greenSL2's Reputation
Rate the quality of this post and help 1999greenSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1999greenSL2 is offline   Reply With Quote
Old 08-27-2007, 08:30 PM   #3
redkees@msn.com
redkees@msn.com is on a distinguished road
redkees@msn.com's Avatar
2004 VUE 2.2L
2008 AURA XE
Sounds like a great deal.
You'll probably need a new cam cover gasket, belt tensioner and serp belt.
If it's an auto tranny I'd change the tranny fluid to reduce/eliminate the minor reverse slam.
It's a 97 so I'd drop in a new ECTS and wire connector (get the brass tipped ECTS at saturn dealer).
Look in the How to library and read up on how to do this if you don't know already.
Update the stuff above and that car will run great and be very reliable.
Previously Owned 98 SL2, Sold
98 SL, Sold
When your Saturn is well kept YOU are well kept.
Second Car: Buick LaCrosse 2006
Add to redkees@msn.com's Reputation
Rate the quality of this post and help redkees@msn.com reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
redkees@msn.com is offline   Reply With Quote
Old 08-27-2007, 08:32 PM   #4
redkees@msn.com
2004 VUE 2.2L
2008 AURA XE
I forgot to mention for the clunk sound on the front end you might need new lower engine dogbone mounts.
98 SL, Sold
Fleet Saturns walt General Saturn Discussion 3 11-13-2005 09:30 PM
Saturn Fleet - worth saving ? cstorry S-Series General 8 06-01-2005 10:17 PM
Saturn Fleet - worth saving ? cstorry S-Series General 0 05-31-2005 09:54 PM
The Fleet LynnF L-Series General 21 08-31-2003 08:32 AM
Saturn as a Fleet Car? LoveMySL1s General Saturn Discussion 7 10-23-2000 11:00 AM
