Old 08-24-2007, 11:54 AM   #1
peccles
peccles is on a distinguished road
Default HCCI Gas Engine Tested in Aura
GM HCCI Gas Engine
The highlights are 15% mpg improvement and EcoTec 2.2. producing 180HP and 170lbs-ft.
Add to peccles's Reputation
Rate the quality of this post and help peccles reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
peccles is offline   Reply With Quote
Old 08-27-2007, 09:01 AM   #2
peccles
Default Re: HCCI Gas Engine Tested in Aura
Journalists drives the Aura with HCCI engine
Old 08-27-2007, 11:44 AM   #3
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
After reading the lengthy article, I am still not 100% sure on how this engine works.
Does the HCCI engine use a high (20:1) compression ratio to ignite the fuel mixture like a diesel?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 08-27-2007, 01:13 PM   #4
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
High compression (relative to gas engines, not diesels) and a lean air/gas mixture. The spark plugs are only used to ignite the mixture during cold starts, otherwise heat and compression ignite it.
Toyota: Moving Forward... off a cliff at a high rate of speed.
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline   Reply With Quote
Video: Driving the Saturn Aura HCCI Prototype at GM Charlie Aura General 3 09-14-2009 08:36 AM
Kelly Blue Book Tested Astra and Aura NGD Astra General 0 07-06-2008 08:26 AM
First Drive: Saturn Aura and HCCI Charlie Aura General 1 05-20-2008 09:18 AM
Gm Demonstrates Fuel-saving Engine Technology Breakthrough With Hcci-enabled Aura bc3tech Aura General 22 05-07-2008 06:42 AM
GM experiments with new HCCI engine in Aura tackepj Aura General 2 08-28-2007 11:49 AM
