what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn L-Series > L-Series Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 08-22-2007, 03:20 PM   #1
tweeaks
tweeaks is on a distinguished road
Default How To: L300 Spark Plug Replacement
I recently received some help getting an L300 I had running. Here is what I am going to contribute back to this community before I leave. Thanks to everyone that has helped me.
I came across a couple of threads that revealed to me something extremely shocking; people are paying in excess of $500 for a sparkplug change due to the "intensive" labor involved. So I decided to do a spark plug removal how to. It isn't a complete step-by-step guide, but should be complete enough to get the novice through this task.
Tools required:
1 Crescent Wrench
1 "5/8 Spark Plug Socket
1 "3/8 Drive Ratchet
1 "3/8 Drive Extension
1 "1/4 Drive Ratchet
1 Pair of Small Channel Lock Pliers
1 Inverted Torx Socket Set
Even if you do not own any tools at most you should spend about $75 for the tools required to do this task.
Looking down at the engine you will see the two intake manifold runners and four boots for each one. Each boot has two clamps. I found that the easiest way to take them off was to use a pair of small channel lock pliers to squeeze the clamp enough to unlatch the clip. I'm sure they make a special tool for this, but I do not have a Saturn dealer here, and no one locally carried it.
The front manifold is a little easier than the rear one. IIRC there are only three bolts that need to be unbolted and the manifold should slide off.
Now there are two bolts that need to be removed and the coil packs can be slid out.
The front spark plugs are now exposed and can be changed.
Add to tweeaks's Reputation
Rate the quality of this post and help tweeaks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tweeaks is offline   Reply With Quote
Old 08-22-2007, 03:40 PM   #2
tweeaks
Default Re: How To: L300 Spark Plug Replacement
The rear is a little more tricky because there is more that needs to be removed off of the manifold. I have circled things that need to be removed. The solid circles indicates that there is something under that area that needs to be removed. The PCM can either be unbolted or unplugged. Whichever method you choose you may be required to use the re-learn technique for the pass-key system. There are two vacuum hoses that go to a black box that need to be removed. There is a brass fitting that is holding a larger vacuum hose onto the manifold. There is a sensor that needs to be unplugged on the right side of the manifold. IIRC there are four bolts that hold the manifold down. I only have two circled the other two are in the back of the manifold.
This is pretty much what it should look like before you pull off the manifold. Make sure there are no more harnesses or sensors attached to the back of the manifold. I remember there were some, but do not remember where they are. Pull the manifold off and you will expose the coil pack. Unbolt it just like you did the front and pull the coil packs off to expose the rear spark plugs. Change your spark plugs and put everything back!
Old 08-22-2007, 09:16 PM   #3
tomlct
tomlct is on a distinguished road
I have an Ecotec-4, so of course, it was a simpler job, but congrats - that's a really well-done posting.
Were you able to reuse the round clamps?
Add to tomlct's Reputation
Rate the quality of this post and help tomlct reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tomlct is offline   Reply With Quote
Old 08-23-2007, 11:37 AM   #4
tweeaks
Yeah; all I did was squeeze them back on with the channel locks. If I had broke them I would have just used some worm drive clamps. They would have worked just fine.
Old 08-24-2007, 05:24 PM   #5
GregS&L
GregS&L is on a distinguished road
GregS&L's Avatar
2001 L-Series 3.0L Sedan
Nice pictures! Just out of curiosity what type of replacement plugs did you use - OEMs? Any noticeable performance change after replacement?
My 2001 V6 is only at 62,000 miles, but the time will come. Thanks for the pictures and the discussion.
Add to GregS&L's Reputation
Rate the quality of this post and help GregS&L reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GregS&L is offline   Reply With Quote
Old 08-25-2007, 07:26 AM   #6
hufhouse
hufhouse will become famous soon enough
2002 L-Series 3.0L Sedan
2001 SL2
Great post. I did the same repair a few months ago, and I was really worried about those clamps. They aren't nearly as complicated as they look.
BTW, the "proper" tool required to remove those clamps is VERY expensive, I've heard. I removed them with a screwdriver and popped them back on with channel locks.
Add to hufhouse's Reputation
Rate the quality of this post and help hufhouse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hufhouse is offline   Reply With Quote
Old 08-28-2007, 11:17 AM   #7
bryanv
bryanv is on a distinguished road
I've used channel locks to remove and replace those stupid clamps more times than I care to admit.
I've recently started replacing any that I encounter while working on my 2003 V6 with worm-gear clamps. It's a fairly cheap change and they're so much easier to work with. I figure with the money I'm saving doing things myself, I can afford to make it a little easier next time.
I'm at 72k on my 2003 and haven't needed to change the plugs yet, but I'm sure the time is coming.
I'm curious as to what gap was set on the new plugs...
Add to bryanv's Reputation
Rate the quality of this post and help bryanv reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bryanv is offline   Reply With Quote
Old 05-19-2009, 09:47 AM   #8
ThosJ
ThosJ is on a distinguished road
Nice work! Thanks a bundle ($).
ThosJ
Add to ThosJ's Reputation
Rate the quality of this post and help ThosJ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ThosJ is offline   Reply With Quote
Old 05-21-2009, 01:53 PM   #9
beensmoked
beensmoked will become famous soon enough
2002 L-Series 2.2L Sedan
just use a flathead to pop them off and flat channel locks to close them back up. Make sure though! when you remove the runners! Slide THEM OUT! Do not pull them up to get them out. You will rip the rubber boots. Which cost 15 dollars each. And cause a Leak
Add to beensmoked's Reputation
Rate the quality of this post and help beensmoked reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
beensmoked is offline   Reply With Quote
Old 05-21-2009, 03:37 PM   #10
unkle bik
unkle bik has a spectacular aura aboutunkle bik has a spectacular aura aboutunkle bik has a spectacular aura about
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
I have the 2.2L as well. Did you have any problem removing the plugs?
I tried mine 2 years ago and had no luck. I squirted PB blaster and waited overnite and they still wouldn't turn using a breaker bar.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 08-05-2009, 05:13 PM   #11
WEL300
WEL300 is on a distinguished road
How do I see the pictures?
Add to WEL300's Reputation
Rate the quality of this post and help WEL300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WEL300 is offline   Reply With Quote
Old 08-14-2009, 07:34 AM   #12
fanboy375
fanboy375 is on a distinguished road
Yeah, I cant see the pictures either
Add to fanboy375's Reputation
Rate the quality of this post and help fanboy375 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fanboy375 is offline   Reply With Quote
Old 04-12-2010, 07:30 AM   #13
mharris73
mharris73 is on a distinguished road
To the original poster, please repost the pics or check the format/source they are under. They would make this process immensely easier.
Thanks
Add to mharris73's Reputation
Rate the quality of this post and help mharris73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mharris73 is offline   Reply With Quote
Old 04-16-2010, 12:06 PM   #14
greymink79
greymink79 is on a distinguished road
Where are the pictures for this?
Add to greymink79's Reputation
Rate the quality of this post and help greymink79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
greymink79 is offline   Reply With Quote
Old 04-16-2010, 03:42 PM   #15
carbon
carbon is on a distinguished road
carbon's Avatar
2003 L-Series 3.0L Wagon
Thumbs Down Re: How To: L300 Spark Plug Replacement
Gone.
2003 Saturn LW300 V6
2001 Chevy Prizm (Int. Wipers and A/C... Fleet baby!)
1988 Pontiac Fiero GT
Add to carbon's Reputation
Rate the quality of this post and help carbon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carbon is offline   Reply With Quote
Spark Plug Replacement? navcanman Astra Tech 7 09-12-2009 02:21 PM
1998 sl2- oil where the spark plug boot meets the spark plug in 1st cylender scrapmedallord S-Series Tech 7 08-14-2009 11:31 PM
Radiator replacement and strange spark plug rejection KingRex S-Series Tech 6 03-31-2008 09:25 PM
vue 2004 3.5L spark plug replacement alram Vue General 10 10-18-2007 10:53 AM
V-6 Spark Plug Replacement jlettiere L-Series General 3 08-27-2004 08:52 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
