#1 | ||||
![]() Join Date: Jan 2007
1993 SC2
Could someone please point me in the direction of a how_to bleed the clutch?
Or post a new how-to? ... "it's not that i like to pick on Hondas, but it's so easy..."
#2 | ||||
Not sure if the OEM can be bled, the ones from autozone you need to bleed..Its easier just get the OEM and just bolt it and your ready to go, the OEM is pre bled
... 92 SL2, 5 speed 91 Lx 5.0
#3 | ||||
Try a search. There was a post a ways back from a person who said he was able to bench bleed a system. Not an easy task. If it is not too late, much easier to buy a pre-bled system.
My experience has been that if one cylinder of a master/slave clutch is bad, the other is probably not all that far far behind, at least with '70s vintage Toyotas.
#4 | ||||
![]() Join Date: Jan 2005
If you are talking about the 93 SC-2 you show in your avitar, it can be bled IF it is still the origional master/slave system.
My wife used to have a 93 SC-2 and I bled it. On the side of the slave clyinder on the bell housing, you will find a bleed fitting similiar to the ones on the brakes. It may be partially recessed so you may have to look for it. But you bleed it as you would brakes. The master cylinder has a resevoir on top of it with a removable top. Make sure the resevoir is full. You will need a second person to help. Push the clutch pedal down and HOLD it down. The second person opens the bleeder on the slave. When the fluid flow from the bleeder stops, close the bleeder. The clutch pedal can how be released. Continue to repeat this process untill you have bled the system completely. Every now and then DURING the bleeding, BE SURE to check the fluid level in the resevoir. If it falls too low, you will put air into the system, keep it full during the bleeding. Later models did not have bleeding capability and if the clutch hydraulic system has been replaced, the new one may not have it either. I know our 95 SL-2 does not have the capability to be bled. ... 1999 SC-2 280,000 miles -mine now also dead, RIP 1995 SL-2 296,000 miles - my wifes totaled, RIP 1993 Chevrolet S-10 Pick-up - mine 2003 Harley Davidson Low Rider - mine
#5 | ||||
I think this is the thread DonP mentioned. However, as others have said, you're better off just getting a pre-bled assembly. The bleed fitting Sky King mentioned on early models wasn't actually a bleeder screw. It was actually used to fill the system at the factory.
... There is nothing more frightening than ignorance in action.
#6 | |||||
![]() Join Date: Jun 2009
Bleed Sealed master/slave in-car with no mess!
#7 | ||||
![]() Join Date: May 2010
Worked for me too.
in addition to multiple short quick pumps I would then block the pedal to the floor for 10-15 mins and repeat.
| Thread Tools | |
| Display Modes | |
| How to bleed clutch | Geego | Ion Red Line | 4 | 03-14-2013 10:47 AM |
| How to Bleed the Clutch | BlackPlastic | S-Series Tech | 5 | 06-03-2009 12:39 PM |
| Bleed Clutch | Brock4u | Vue General | 0 | 04-17-2008 01:54 PM |
| Anyone know how to bleed a clutch? | Brock4u | Vue Tech | 0 | 04-16-2008 01:09 PM |
| clutch bleed | redsput | L-Series General | 11 | 02-02-2005 09:36 PM |
