Old 08-06-2007, 08:48 PM   #1
marx404
marx404 will become famous soon enough
marx404's Avatar
2008 Astra XE
Dizzy 07 ION rear pass door rattles
My brand new '07 ION.3 Sedan has a rattling noise that seems to come from the rear passenger door at 40 - 45 mph.
I have eliminated the typical "wind reverberation" or whatever you call it, that shuddering noise when the window is down. Thats NOT it. This happens with the windows up and it's a definitive rattling noise.
Any ideas what could be causing this? My mechanic says "it's normal" I say no, as I can hop into any ION on the lot and only 1 out of 20 may make this sound.
The rattle sound only happens at between 40 and 45 mph. Does anyone have a clue what may be loose, broken or bad? TIA
marx404
Add to marx404's Reputation
Rate the quality of this post and help marx404 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marx404 is offline   Reply With Quote
Old 08-06-2007, 10:58 PM   #2
snobrdrdan
snobrdrdan is on a distinguished road
snobrdrdan's Avatar
2009
2007 ION-3 Quad Coupe
Default Re: 07 ION rear pass door rattles
My RL Coupe rear passenger (half) door rattles a little too.
Don't know what it is though & never bothered to take it to the dealer either.
It's a cheap car....it's gonna rattle....sorry to say that man
2009 VW GTI
FRO: 2007 Ion REDLINE -- 8/06-3/08
2008 Aura XR -- 3/08-8/08
Add to snobrdrdan's Reputation
Rate the quality of this post and help snobrdrdan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snobrdrdan is offline   Reply With Quote
Old 08-06-2007, 11:39 PM   #3
ottmwz_finest
ottmwz_finest is on a distinguished road
ottmwz_finest's Avatar
2004 ION-2 Sedan
I have said it before and I will say it again: the ION is clipped and bolted together...some of them are bound to get loose...just ask SaturnSdn...he's got a few loose himself.
My advice: just invest in some better audio components and the squeaks and rattles will soon be a thing of the past...
hundred miles an hour switching lanes like WHOA
Add to ottmwz_finest's Reputation
Rate the quality of this post and help ottmwz_finest reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ottmwz_finest is offline   Reply With Quote
Old 08-07-2007, 06:07 AM   #4
Diesel_Clatter
Diesel_Clatter is on a distinguished road
2007 ION-2 Sedan
I noticed a bit of a rattly sound coming from upper drivers side window area of my ion. It turned out to be trim noise from the rear drivers door and went away when I lubed the trim and areas the trim rubbed with silicone.
Add to Diesel_Clatter's Reputation
Rate the quality of this post and help Diesel_Clatter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Diesel_Clatter is offline   Reply With Quote
Old 08-07-2007, 07:09 AM   #5
marx404
marx404's Avatar
2008 Astra XE
This is not the typical saturn rattling or clatter, it can get pretty loud, loud enough that one wonders if the door will come loose.
snobrdn, there IS a TSB on your QC on the rear door rattle, it is the door bolts or something. The same does not apply to the sedan.
D.C., good suggestion, I will have the trim checked out.
marx404
Old 08-07-2007, 11:29 AM   #6
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
As always Ottumwawa the pretender, pozer.
Ok here is the deal..............you have a rattle. We can't hear is from where we sit. You find it and fix it or take it to the dealer and have them do it under warranty. That door as every door on every car has alot of moving parts I don't think anyone can tell you for certain what the rattle is.
Add to SaturnSdn's Reputation
Rate the quality of this post and help SaturnSdn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnSdn is offline   Reply With Quote
Old 08-07-2007, 02:20 PM   #7
youngion2
youngion2 is on a distinguished road
2006 ION-2 Sedan
hey guys out there with a sedan most of the time the issue is there are black molding on the upper back of front doors and upper front of back doors each one has screws on the back once you open the door and most of the time those screws come loose. All you need to do is simply tighten it up. this was the issue with mine and my sisters.... it fixed ours and hopefully it fixes yours
"Cam's Auto Detail"
Add to youngion2's Reputation
Rate the quality of this post and help youngion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
youngion2 is offline   Reply With Quote
Old 08-07-2007, 02:23 PM   #8
SaturnSdn
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
Those black things are called applique's......... they can and do come loose. Never had the problem on any of my three ION sedans.
Old 08-07-2007, 04:34 PM   #9
youngion2
2006 ION-2 Sedan
alright sorry that i didnt know the exact name of them.... but i have had that problem and a few of my other ion buddies have had that problem also so i figured it was worth a shot.
"Cam's Auto Detail"
Old 08-07-2007, 04:43 PM   #10
snobrdrdan
snobrdrdan's Avatar
2009
Really???
Hmm...it's not bothering me THAT bad, but if I get time I might have them check it out
Do you know what the TSB consists of???
thanks for mentioning that BTW
2009 VW GTI
Old 08-07-2007, 04:44 PM   #11
SaturnSdn
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
No reason to be sorry James..............just passing on the name of the fool things.
Old 09-06-2007, 04:37 PM   #12
marx404
marx404's Avatar
2008 Astra XE
Resolved! It WAS the rear pass door applique, the adhesive underneath had given and the applique was rattling.
marx404
marx404
It's not a Saturn. It's an Opel, dammit.
2007 ION.3
2008 Astra XE
04 Ion Rear Door Window Replacement saturnion Ion Tech 2 03-02-2009 07:05 PM
'07 ION rear door loose? marx404 Ion Tech 3 09-04-2007 09:32 AM
Door rattles. Anyone else fix? JerryHughes S-Series General 3 11-15-2005 10:15 AM
Interior door on sunroof rattles denclar S-Series General 6 04-03-2005 12:53 PM
Front door speaker rattles? RedHotChiliQC Ion General 7 07-21-2004 01:05 AM
