Old 07-31-2007, 04:41 PM   #1
jcm22
jcm22 has a spectacular aura aboutjcm22 has a spectacular aura aboutjcm22 has a spectacular aura about
2002 SL
Default TPS test on 2001 saturn SL1
BarnOwl stated:
That sounds like a problem with the TPS (Throttle Position Sensor) and yes, it will reset when restarted. When it's running badly, try tapping on the TPS with a screwdriver handle and jiggling the wires and see if it changes
Hi BarnOwl,
I took the TPS connector off and started my car. The RPM's raced up and down from 700 - 1000. I shut the car off and plugged the tps connector back on and started the car and the car idled steady at 700rpm.
I am going to replace the gas cap tonight and see if that does anything.
I'll keep you posted - Jim
Add to jcm22's Reputation
Rate the quality of this post and help jcm22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcm22 is offline   Reply With Quote
Old 08-01-2007, 07:25 AM   #2
jcm22
2002 SL
Default Re: TPS test on 2001 saturn SL1
New gas cap didn't solve the problem.
I also want to mention that my car never throws a code with this problem. (Bucking kicking, loss of power)
Old 08-01-2007, 07:32 AM   #3
WingsOfSaturn
WingsOfSaturn's Avatar
Have you done the screwdriver test yet?
A bad gas cap will throw a code.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 08-01-2007, 10:24 AM   #4
eljefino
eljefino's Avatar
1995 SW1
Your diagnostic doesn't show much of anything.
Of course the car will be annoyed when the TP sensor is unplugged, that loping idle is proof. Randomly unplugging sensors is a poor way of finding a problem, as the failsafe you trigger (running rich etc) can mask the real issue.
Hint, a flaky TPS usually leads to an occasional high idle but going great down the road. Any flaky spots are cured by a slight change in accellerator position. Most flaky spots are near idle where the pedal spends most of its time.
Bucking, kicking, and power loss sound like something else. Have you checked the intake gasket yet?
Add to eljefino's Reputation
Old 08-01-2007, 07:11 PM   #5
jcm22
2002 SL
Hi Eljefino and Romzek,
I thought unplugging the tps would at least show that it was working. unplugged then plugged in. I also jiggled the wires around to the tps unit while the car was running and there was no change.
There is never an occasional high idle, idles nice and smooth @ 700rpm
My car never throws a code with this problem. (bucking, kicking, power loss, bogging etc) Just out of the blue it justs starts with the symptoms described above while cruising down the road in town.
I replaced the intake gasket (definitely shot) I sprayed some carb cleaner near the #1 cylinder and sure enough, the rpm's took a nose dive. After replacing the intake gasket, the car ran much better but I still had symptoms of the bucking, kicking, bogging etc. I also replaced the fuel filter, oxygen sensor, ects, cleaned the egr, new pcv, air filter, plugs and wires.
What is the screw driver test that I should perform?
I do want to mention that one code was thrown and that was due to me forgetting to hook up the vacuum line after finishing the intake gasket job. It was code P0440. After hooking it back up, there was no more code. ( Autozone cleared it for me)
Old 08-01-2007, 07:59 PM   #6
Greg1
Greg1's Avatar
1997 SW2
The "screwdriver" test is tapping on the TPS with a screwdriver handle to see if the idle changes which would indicate a flaky sensor.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TPS Replacement on Saturn SL1 SOHC 1.9L RTandall S-Series Tech 6 04-10-2010 10:23 AM
ProScan Saturn SL1 2001 calvintanner S-Series Tech 2 08-08-2009 04:10 PM
how do u test TPS ? brian3222 S-Series Tech 2 05-21-2009 10:52 AM
1996 sl1 - tps krispy1179 S-Series Tech 3 11-04-2008 10:15 PM
2001 Saturn SC2 failed emissions test. irish80ca S-Series General 7 10-21-2008 07:07 AM
