Old 06-27-2007, 04:19 PM   #1
gfreek1
gfreek1 is on a distinguished road
Default Cruise Control not working
02 SL2, switch lite on steering wheel is on, but no cruise. checked all fuses and they are good. Last time this happened, when I bought the car, they replaced the brake pedal switch. Could it be this again and is there a test to be sure that's whats wrong ?
Add to gfreek1's Reputation
Rate the quality of this post and help gfreek1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gfreek1 is offline   Reply With Quote
Old 06-27-2007, 05:55 PM   #2
Default Re: Cruise Control not working
Usually, if it's the brake pedal switch that's failed, it's failed "closed", so the brake lights will be on all the time. Are they?
Add to madpogue's Reputation
Old 06-27-2007, 08:50 PM   #3
gfreek1
No they are not on all the time.
Old 06-28-2007, 05:43 AM   #4
BarnOwl
BarnOwl's Avatar
I would say that if the brake lights work right then it's not the brake light switch. Are there any other driveability issues with the car? Is the SES light on? The reason I'm asking is that I don't believe the cruise control will work if you aren't going into closed loop.
Add to BarnOwl's Reputation
Old 06-28-2007, 11:34 AM   #5
gfreek1
After driving for awhile the service wrench & security lite comes on. Check engine lite not on. They are off after restart. My son took it to a dealer in Michigan, they had no answers. Don't get me started on that ...... Can you explain to me what you mean by "closed loop"
Old 06-28-2007, 09:38 PM   #6
When driving try carefully pulling up on the brake pedal (with your foot) while trying to set the cruise. If it now works adjust the brake pedal switch.
Add to ssicarman's Reputation
Old 06-29-2007, 10:55 AM   #7
gfreek1
ssicarman, I tried pulling up on the pedal, cruise still did not work, Any other ideas??
Old 06-29-2007, 11:07 AM   #8
hit_n_run
hit_n_run is on a distinguished road
My vote is the BCM. I'm having similar issues with the cruise control on my 93 SC2 auto. Sometimes CC works, sometimes it doesn't. Sometimes it will work, then stop working after a very short period of time.
As for the brake pedal switch, how does one adjust that if that is my problem?
Add to hit_n_run's Reputation
Rate the quality of this post and help hit_n_run reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hit_n_run is offline   Reply With Quote
cruise control not working xraytec1 Ion General 15 03-08-2018 03:38 PM
Cruise control no longer working SL1Guy S-Series Tech 3 10-01-2009 07:21 PM
Cruise control, A/C not working Scout238 S-Series Tech 8 08-20-2008 10:42 PM
Cruise control upgrade - now AC is not working kodok S-Series Tech 7 07-18-2006 08:22 AM
Cruise Control Is Working!!! BarnOwl S-Series Tech 2 11-10-2005 10:43 AM
