Old 06-26-2007, 02:00 PM   #1
stick86
stick86 is on a distinguished road
2003 ION-1 Sedan
Default Back-up lights
I have an '03 5-speed Ion and both of my back-up lights are not working.
The bulbs are good. With the car in reverse, I unplugged the bulb and tested the contact points on the tail light assembly and only got 0.4 volts with my multimeter. Then when I unpluged the whole tail light assembly and tested the voltage of the back-up power and ground wires that run back to the front of the car and I got 12 volts.
With my little electrical knowledge, it seems like the back up light power is shorting to ground some where in the tail light assembly, but the wires look fine to me. And if it was shorting to ground, wouldn't that blow a fuse and then there would be no power going to it at all?
I read the past posts on how alot of 5-speed Ions have faulty back-up switches. What I explained here, is that something that is caused by a bad back-up switch?
Thanks for your help
-Isaac
Add to stick86's Reputation
Rate the quality of this post and help stick86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stick86 is offline   Reply With Quote
Old 06-26-2007, 09:43 PM   #2
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
Default Re: Back-up lights
its about a $30 part and most likely its the reverse light switch.. it shouldn't be that hard to replace..
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 06-26-2007, 11:12 PM   #3
Welcome to the Board.
The most common cause of inop reverse lights in a manual ION is the reverse switch. It is best gotten to through the LF wheel well. Two wire connector to the switch near the top of the trans.
Add to ssicarman's Reputation
Old 06-27-2007, 10:12 AM   #4
stick86
2003 ION-1 Sedan
Thanks for your help, I'll replace it this weekend, and tell you how it goes.
Old 07-01-2007, 05:05 PM   #5
stick86
2003 ION-1 Sedan
Just to let you guys know, replacing the back-up switch fixed my problem. It was easy to replace and it was only $37.
Isaac
Back up lights chillin05VUE Vue Tech 2 09-22-2009 09:42 PM
Corner lights are back!!!! redlineit Vue Red Line 2 12-10-2008 03:11 PM
back up lights gronz S-Series Tech 5 04-05-2006 09:12 PM
Back-up lights (sometimes) Mr Mike S-Series Tech 4 08-20-2004 07:57 AM
back up lights beasjd S-Series Tech 3 07-11-2001 02:57 PM
