#1 | ||||
![]() Join Date: Mar 2000
Ok, anyone know where I can get a list of Saturn specific OBD II codes?
Specifically code P1404. ![]() - W
#2 | ||||
um...the Saturn service manuals. have a tech copy the pages with them on them for you.
#3 | ||||
code 1404 is a egr valve pindle . this means that you more than likely have corbon build in your egr valve and is causeing the pindle to either stick open or stick closed. you can try to take off the egr valve and clean it off with carb cleaner but that normally doesnt work too well. if that doesnt work then you need to get a new one .
#4 | ||||
![]() Join Date: Feb 2000
Bulletin 97-T-20A may give you some information on this. But like Saturn Guy said you may find a problem with the EGR pintle. the pintle is the part in the center of the valve that opens and closes to regulate exhaust gas flow. The pintle may stick in the fully open or fully closed position. To inspect, remove the EGR valve invert it and push on the pintle. It should move freely from the fully closed to the fully open position. Then should close with spring pressure.
| Thread Tools | |
| Display Modes | |
| OBD I codes | sat-vic | S-Series Tech | 19 | 12-06-2008 11:14 PM |
| obd codes | SWargy | S-Series General | 20 | 10-15-2008 04:13 PM |
| Beating a dead horse - Saturn roof racks revisited revisited | jonny boy | Outlook General | 1 | 01-14-2008 03:53 PM |
| OBD II codes | santro | L-Series General | 6 | 09-27-2005 09:33 PM |
| Getting Codes from a OBD I Saturn | amazinghl | How-To Library | 7 | 02-05-2005 07:41 PM |
