Old 06-11-2007, 09:28 AM   #1
TXSaturn02
TXSaturn02's Avatar
Default Manual Transmission Fluid Check
Well, thanks to Bigdaddy, I was able to get to find my transmission dip stick and TRY to check it. The color looks pinkish, but it was really hard to determine how high up the level was because it obviously gets moist along the sides when trying to squeeze it back in there. I'm thinking it is OK, but can't be sure. Is there a recommended milage level for changing it on a standard trasnsmission?
New owner As of 01/01/18: 225,000 Miles
As of 03/20/18: 46,135 Miles
Old 06-11-2007, 10:15 AM   #2
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1991 SL2
Default Re: Manual Transmission Fluid Check
I beleive 100k is "by the book", but since it's so easy to do, I've changed mine every 30k, figuring its cheap insurance.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 06-11-2007, 11:45 AM   #3
Corvair
Corvair is on a distinguished road
Wow, I think I've changed mine once in 16 years. I thought they recommended changing it after the first 3,000 miles, but after that, there is no recommended interval to change it again. The transmission hasn't given me one bit of trouble. (Well, the stickshift did flop loose a couple years ago, but that didn't have anything to do with the transmission itself or the fluid level.)
('91 SL - 460,750 miles)
Add to Corvair's Reputation
Rate the quality of this post and help Corvair reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Corvair is offline   Reply With Quote
Old 06-11-2007, 12:45 PM   #4
TXSaturn02
TXSaturn02's Avatar
That is what I always thought also from when I bought my `94, but I believe starting in 2000, that was no longer required for the warrany and so I didn't do it. Well, if you've only done it once in 460K miles, that is good enough proof for me.
Old 06-11-2007, 03:58 PM   #5
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
I did mine at 111,000 miles. When I drained it, it looked like dirty water, it was really thin and dirty. I had planned on putting synthetic in, but somehow ended out putting regular ATF in. It's cheap and easy to do, so in a while I'll change to synthetic.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 06-11-2007, 10:38 PM   #6
S3aturnR
S3aturnR's Avatar
1999 SL1
i replaced mine twice: once a couple years ago when i rebuilt my gearbox and once a month or so ago when i changed my clutch. after 150k miles, i couldn't tell the difference between the old stuff and the new stuff.
my recommendation: change the fluid when you change your clutch. otherwise, you'll be fine...
s3aturnr
Add to S3aturnR's Reputation
Old 06-12-2007, 10:31 PM   #7
eRic 02sc2
eRic 02sc2's Avatar
Saturn says to replace manual transaxle fluid once at 6000 miles. That's it. You could do it every 30,000 miles like an automatic if you wanna.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 35 06-30-2017 06:47 PM
Where's the manual transmission fluid fill/check JeepVuer Vue Tech 9 10-13-2009 10:56 PM
how do i check my manual trans fluid saturncrzy S-Series General 38 04-07-2009 08:07 PM
transmission fluid level check dyycxgm L-Series Tech 2 12-19-2007 10:33 PM
HELP transmission fluid check L 200 auxiliary L-Series Tech 2 09-28-2006 08:56 PM
