Old 06-27-2002, 06:37 AM   #1
TIMSPEED
TIMSPEED is on a distinguished road
TIMSPEED's Avatar
1998 SW2
Default Front Suspension "clunk"/Wobbly Drivers Side front tire feeling
Anyone else have this problem? My car seems to be amazingly.."clunky". When I'm driving over a rough road, it seems like the front end of my saturn makes a weird "clunking" sound. It makes this same sound when the car is off and I rock the steering wheel left to right (Steering wheel must be centered and then rocked a little left and a little right.) My guess is a bad wheel bearing...but when I changed the brake pads a month ago, I didn't really notice it to be shaky. NOW...the previous owner of this Saturn put a towing system on it...which basically looks like another sway bar and has like extensions on the front frame. (Could this be the noise?) The car actually handles perfectly fine, I've out driven a NUMBER of cars with it. (in AutoX events)
Add to TIMSPEED's Reputation
Rate the quality of this post and help TIMSPEED reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TIMSPEED is offline
Old 06-29-2002, 01:16 AM   #2
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default
Bad wheel bearings usually make noise regardless of steering input, so my guess is that it's steering linkage, like tie rod ends. Might want to crawl underneath and start grabbing things to see if you notice any play, including to see if there's any side-to-side movement with the wheels, which would indicate a bad bearing. While underneath, take a close look at the towing package to see if everything looks okey-dokey.
Add to Heartbeat - '95 SL2's Reputation
Rate the quality of this post and help Heartbeat - '95 SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Heartbeat - '95 SL2 is offline
Old 06-29-2002, 11:18 PM   #3
ChriSL2
ChriSL2 is on a distinguished road
Idea
Strut Mounts, I had a Very simular prob like yours a 'good' mechanic told me about the strut mount , I thought he was trying to make a few bucks offa me, I was desprate so i tried it and the Klunking was gone.
THE END
Add to ChriSL2's Reputation
Rate the quality of this post and help ChriSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ChriSL2 is offline
Old 07-02-2002, 05:57 PM   #4
SilverPlumGirl
SilverPlumGirl is on a distinguished road
Dazed Clunking
I have heard a clunking sound after driving over un-even roads...and thought it was just dusty struts...etc...
or something loose/rattling under the car
took her in for the 20,000 change today to find out
the car is totally out of alignment...AND the whole
steering column has to be replaced!! $$$$$$$$
(under warranty!!!) along with a few things "loose" underneath the car.
I would have never noticed all this stuff!!
Who would have thought all that work needed to be
done from just an oil change!....I am glad my Saturn Techs
have good ears!!
Add to SilverPlumGirl's Reputation
Rate the quality of this post and help SilverPlumGirl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilverPlumGirl is offline
Old 07-03-2002, 04:40 AM   #5
jackhammer
jackhammer is on a distinguished road
jackhammer's Avatar
Question
THE END
What do you mean by the strut mounts ChriSL2? I believe that could be my problem. I get a clunking noise coming from the left front drivers side of the vehicle. Usally only happens when going over a speed bump uneven or when I first move the car after it has been parked.
Add to jackhammer's Reputation
Rate the quality of this post and help jackhammer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jackhammer is offline
Old 07-03-2002, 03:02 PM   #6
TIMSPEED
TIMSPEED's Avatar
1998 SW2
Default
That sounds about right. It also does it when I go over a rough road...clunk clunk clunk.
TIMSPEED is offline
Old 07-03-2002, 09:03 PM   #7
Heartbeat - '95 SL2
Default
Strut mounts are round bearing plates which go between the front struts' upper mounting flange and the body's strut tower. The bearings allow for the spring to rotate as the front wheels turn.
Old 07-04-2002, 02:43 AM   #8
jackhammer
jackhammer's Avatar
Question
To fix the strut mount if that is what the problem is, how would you go about fixing it? Tightening the bolts on the top of the strut housing?
Old 07-04-2002, 02:24 PM   #9
Heartbeat - '95 SL2
Default
Oops, small correction: the strut mount bearing plate and rubber bushing go between the spring and top mounting flange (with the 3 studs which poke through the strut tower). Bearings are integral to the top plate. If the strut mounts or bushings are shot, then they need to be replaced, which entails removing the struts and reinstalling. With all the labor involved, a good time to think about replacing the strut cartridges if necessary. An alignment is also needed after removal of the struts.
Old 07-05-2002, 12:54 PM   #10
R.J.Barnett
R.J.Barnett is on a distinguished road
R.J.Barnett's Avatar
Default
You need to remove the strut(s), use a spring clamp to relieve the spring tension and remove the nut at the top of the strut rod. Not too big a job.
Add to R.J.Barnett's Reputation
Rate the quality of this post and help R.J.Barnett reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
R.J.Barnett is offline
Old 07-06-2002, 05:38 AM   #11
therapist
therapist is on a distinguished road
Default
for all the trouble and expense you're going to have to do to get rid of the clunk (if indeed it's the strut mount) i'd say live with the clunk until you need to replace the strut or springs. since the whole procedure means you have to remove the strut and spring from the car. then the alignment. as long as your car handles ok just live with it. now if you really want to do so, i suggest you replace the struts at least since that will just add another $100 to your expense and will give you that over rails feeling again. goodluck.
Add to therapist's Reputation
Rate the quality of this post and help therapist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
therapist is offline
front drivers side tire is worn sc2dohc94 S-Series Tech 5 07-24-2009 12:39 AM
Front suspension clunk and slllllllow hvac controls mangler66 Vue Tech 2 03-02-2008 04:11 PM
"Clunk" Sound under left front floor board? karenfromidaho Ion General 2 06-18-2005 11:00 PM
"CLUNK" up front? Source? jmatero Vue General 3 05-14-2003 09:42 AM
"crackling" noise in front suspension 100KSW2 S-Series Tech 7 07-25-2002 08:18 PM
