what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 06-26-2002, 10:45 PM   #1
JeffTheJoc
JeffTheJoc is on a distinguished road
JeffTheJoc's Avatar
2002 VUE 3.6L
Question The 12 Volt Outlets in the Vue
Can any small appliance like an electric shaver, hairdryer or fan be plugged into the 12 volt outlets in the VUE? Is some kind of conveter needed, or even available?
Add to JeffTheJoc's Reputation
Rate the quality of this post and help JeffTheJoc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JeffTheJoc is offline
Old 06-27-2002, 12:12 PM   #2
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
Default
There could be a line of under-20 / under-15 amp devices that are included on your list. I have a 12VDC electric ice scraper, car vacuum, and air pump. A shaver could be fesible, perhaps a small fan, but a hair dryer is a bit out of the question.
You could also check into a DC-to-AC power inverter. The higher wattage units (above 150-200 watts) will require a direct connection to the battery. You probably also want to be running the car You would be able to run a small hairdryer from an 800-1000 watt unit..
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline
Old 06-27-2002, 02:07 PM   #3
JeffTheJoc
JeffTheJoc's Avatar
2002 VUE 3.6L
Happy
When camping; I also want to power a Refrigerator, Stove, TV AND Camplight
Old 06-27-2002, 04:13 PM   #4
L300Boy
L300Boy's Avatar
Default
You better just get a small generator then
L300Boy is offline
Old 06-27-2002, 05:27 PM   #5
JeffTheJoc
JeffTheJoc's Avatar
2002 VUE 3.6L
Cool
Wow... I can run a generator off the 12 volt outlets too?
Old 06-27-2002, 05:33 PM   #6
L300Boy
L300Boy's Avatar
Default
Nah, you'll need gas for that
Ive operated a small TV, VCR, and boombox off of a 150 watt inverter and a deep cycle battery. Perfect for those 20-miles-away-from-electricity camping trips.
L300Boy is offline
Old 06-28-2002, 01:13 PM   #7
JeffTheJoc
JeffTheJoc's Avatar
2002 VUE 3.6L
Cool Mr
I found an automotive DC to AC Converter at Crutchfield.com for $39.95. I wonder if I could hook-up my lawn mower to that.
Constant 12 volt to radio is reading under 1 volt? Plz help HockeyZ39 S-Series Tech 15 10-11-2006 05:02 PM
Dead power outlets??? tominsky Vue General 11 04-28-2006 03:47 PM
Vue 04 Accessory Power Outlets don't work barrymis Vue General 6 12-15-2004 12:00 AM
Adding new 12 Volt DC Plugs in the Vue UCSBJONES Vue General 19 03-04-2004 03:44 PM
Dual Exhaust Outlets silverplum General Saturn Discussion 7 03-11-2002 03:04 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
