Old 06-04-2007, 10:08 PM   #1
fosgate3
fosgate3 is on a distinguished road
2007 ION-3 Sedan
Default 2007 Ion: looking for wiring info
I'm looking for the wiring information for a 2007 Ion so that I can install a remote start alarm system.
Add to fosgate3's Reputation
Rate the quality of this post and help fosgate3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fosgate3 is offline   Reply With Quote
Old 06-04-2007, 11:11 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: 2007 Ion: looking for wiring info
12volts red (40A), red (30A) + pins 37 and 34, BCM C1
Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly. It has the following connectors: C1-37 pin black plug, C2-38 pin gray plug, C3-56 pin black plug, C4-56 pin gray plug, and C5-6 pin gray plug.
Starter yellow (not for remote start) - pin 48 or 46, blue plug, ECM
Notes: The ECM (Engine Control Module) is on the driver side of engine compartment, near coolant over flow container.
There is a white wire and a white/black wire at the ignition harness that performs the following: key sense, second ignition, starter, and Passlock resistance. Refer to DirectFax document 1610 for remote start interface information.
Second Starter N/A
Ignition dk. blue + ign harn or pin 7, BCM C4
Second Ignition see starter wire notes
Third Ignition N/A
Accessory brown + ign harn or pin 6, BCM C4
Second Accessory N/A
Keysense see starter wire notes
Power Lock white - pin 33, BCM C3
Notes: Lock is a straight negative trigger. Unlock is negative trigger thru a 1.5K ohm resistor. MUST use relays.
Power Unlock same as power lock wire
Lock Motor gray 5wi pin 51, BCM C3
Unlock Motor tan 5wi pin 2, BCM C3
Parking Lights+ brown + switch or pin 2, BCM C4
Parking Lights- N/A
Hazards lt. blue - switch or pin 40, BCM C4
Turn Signal(L) lt. blue (F), yellow (R) + pins 44 and 43, BCM C3
Turn Signal(R) dk. blue (F), dk. green (R) + pins 46 and 45, BCM C3
Reverse Light lt. green + harness under driver seat
Door Trigger lt. grn/blk (D), lt. blue (P) - pins 45 and 44, BCM C4
Notes: Use both wires and diode isolate each.
Dome Supervision white - pin 11, BCM C3
Trunk/Hatch Pin orange/black - light in trunk
Notes: On models with keyless entry it is also dk. green, pin 35, in the BCM C3.
Hood Pin N/A
Trunk/Hatch Release black/white + switch or pin 1, BCM C3
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Passlock
Tachometer NOT pink or pink/black ac any fuel injector
Wait to start N/A
Brake Wire lt. blue + switch or pin 8, BCM C2
Parking Brake lt. blue - switch or pin 43, BCM C4
Horn Trigger black - switch or pin 33, BCM C4
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock
Part #: 556LW
Alternate Part1 #: 555LW
Notes: Refer to DirectFax document 1610 for remote start interface information.
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 06-05-2007, 05:22 AM   #3
fosgate3
2007 ION-3 Sedan
thanks a million. That was a fast reply. you're great.
G
Wiring diagram for mirror in 2007 Vue? 07VUE Vue Tech 4 07-12-2009 12:47 PM
Need 2007 wiring help soaranator Vue Tech 0 04-10-2007 06:34 PM
need info on wiring???? please help! rapidion Ion Mods 7 01-29-2007 08:32 PM
2007 ION 3... Any info? went_postal Ion General 24 08-27-2006 05:01 AM
New 2006-2007 Saturn release info (Any info I could gather from other sites) TBone1082 General Saturn Discussion 11 12-03-2004 11:19 PM
