Old 05-28-2007, 11:13 AM   #1
sicksat
sicksat is on a distinguished road
Default black emblems?
ok so i just ordered some black emblems for my 1996 sc2 i was just wondering how would you go about putting them on? and what is the easiest way to take the old ones off thanks!
Add to sicksat's Reputation
Rate the quality of this post and help sicksat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sicksat is offline   Reply With Quote
Old 05-28-2007, 11:20 AM   #2
travistuttle
travistuttle is on a distinguished road
travistuttle's Avatar
Default Re: black emblems?
on the sc2 I cant remember but I know on my sl2 I have to take a few clips off the fender liner and there is a 10mm nut holding them on
My street legal go-kart will kick you in the face...
Parting out an 98 sl2, pm me if you need anything
http://s176.photobucket.com/albums/w193/travisatuttle/wrecked%20car/
Add to travistuttle's Reputation
Rate the quality of this post and help travistuttle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
travistuttle is offline   Reply With Quote
Old 05-28-2007, 11:34 AM   #3
sicksat
so its not that hard to do?
Old 05-28-2007, 11:41 AM   #4
travistuttle
maybe 10 mins/ emblem
Old 05-28-2007, 11:51 AM   #5
sicksat
ill have to see if i can find that strip thng since i have a sc2. where did you get yours from?
Old 05-28-2007, 11:56 AM   #6
travistuttle
spswebpage.com
Old 05-28-2007, 12:00 PM   #7
sicksat
ya same here
Old 05-28-2007, 12:25 PM   #8
Amatricis
Amatricis is on a distinguished road
Amatricis's Avatar
What about the back emblem? Is it stuck on or is it held on by another nut?
Add to Amatricis's Reputation
Rate the quality of this post and help Amatricis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Amatricis is offline   Reply With Quote
Old 05-28-2007, 12:35 PM   #9
sicksat
from what he said it is just held on by a screw. i was just wondering how to take them off in the first place and i guess it can not be to hard to do
Old 05-28-2007, 01:12 PM   #10
SpeedPlayer 97sl2
SpeedPlayer 97sl2 is on a distinguished road
SpeedPlayer 97sl2's Avatar
Front emblems and side emblems for the S-series are held on by plastic retaining nuts.
Rear emblems for the 1997+ SC and 2000-2002 L-Series reflex panels are adhered to the panel. A thin screwdriver or (to be safe) plastic putty knife will pop it off.
For more specific instructions:
SPS Webpage
My reality check bounced.
Add to SpeedPlayer 97sl2's Reputation
Rate the quality of this post and help SpeedPlayer 97sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SpeedPlayer 97sl2 is offline   Reply With Quote
Old 05-28-2007, 04:03 PM   #11
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
SPS Webpage
Using a heat gun will probably help loosen the glue, too.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 05-28-2007, 04:57 PM   #12
travistuttle
Thats Right I Forgot About That One... I Just Have The Big Saturn Imprinted On My Bumper
Old 05-28-2007, 05:05 PM   #13
sicksat
ya the heating gun is a no go
Old 05-28-2007, 10:22 PM   #14
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: black emblems?
Removal of stock emblems on front and sides:
To remove the front emblem, open the hood and reach behind the fascia to the rear of the stock emblem. To remove the side emblems, remove the fender liners from the inside of the wheel wells.
Locate the pinch nut on the rear side of the emblem.
Using a pair of pliers, twist and pull the nut away from the emblem.
Once started, the nut can be removed by hand.
Pull the emblem from its position.
To install the new emblems:
Insert the new emblem into position.
Reinstall the original pinch nut by pressing and twisting the nut against the body panel until it is tight and the emblem is secure.
To remove the stock emblem from the rear of 97+ coupes:
Pry the original emblem from the rear reflector using a small flathead screwdriver or other prying tool.
To install the new emblem onto the rear of 97+ coupes:
Thoroughly clean the area beneath the emblem using Goo-Gone or other cleaning agent.
Before applying the new emblem, be sure that the surface of the carís reflector panel is clean and dry.
Remove the backing paper from the rear of the new emblem.
Make sure the emblem is right-side-up and press the emblem firmly into place.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 05-29-2007, 03:50 AM   #15
quiksc2
quiksc2's Avatar
Hahahahaha. Put on all the emblems, upside down.
DCS
Old 05-31-2007, 07:09 PM   #16
eRic 02sc2
eRic 02sc2's Avatar
funny thing is it's not possible to mount them upside down. there's a big hole for the post and a little hole for the pin that only allows them to be mounted one way.
eRic 02sc2
Old 06-01-2007, 09:53 AM   #17
02SatSC2
02SatSC2 is on a distinguished road
02SatSC2's Avatar
Yeah there is that post, but you could always cut it off and have a "unique" saturn badge scheme lol.
Use to be rugerSC2, now 02SatSC2
"Live like the word will end tomorrow, Drive like the world will end tomorrow"- Me
2002 Saturn SC2- Daily Driver until I get a real job.
www.StreetDesignAuto.com
Add to 02SatSC2's Reputation
Rate the quality of this post and help 02SatSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
02SatSC2 is offline   Reply With Quote
black emblems.. sicksat S-Series Mods 19 01-02-2007 08:43 AM
black emblems 04Vuesilver Vue General 6 06-14-2005 06:39 AM
black emblems SexyMexi02SC2 S-Series General 8 12-12-2003 02:44 PM
Black Emblems IONicSaturn General Saturn Discussion 5 05-17-2003 11:14 PM
NEW Black Emblems thatjerryguy General Saturn Discussion 20 12-18-2001 11:55 PM
