Old 05-23-2007, 11:26 AM   #1
dildog
dildog is on a distinguished road
dildog's Avatar
Default Wheel Bearing/Hub Assembly-Front/Rear
I was going to replace the brake rotors/pads on my 1996 SL2 this weekend so I figured I'd do the bearings as well. I saw on AutoZone's website they sell a complete wheel bearing/hub assembly as well as just the bearing. Does replacing the entire hub eliminate the need to replace the individual bearing? If so, how complicated is replacing the entire hub? Is it even worth replacing the hub? The car has 111,000 miles on it.
Or should I just try to replace the bearings, it's been my experience that bearings are the biggest pain in the @ss ever and rarely come out without a fight.
dildog is offline   Reply With Quote
Old 05-23-2007, 11:30 AM   #2
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Default Re: Wheel Bearing/Hub Assembly-Front/Rear
I'd replace just the bearings. Either way, the bearing has to come out of the knuckle. I'd take the knuckles to either a machine shop or the Saturn service department and have them do it- unless you have a hydrualic press and know how to use it.
Not a Saturn.
Old 05-23-2007, 11:46 AM   #3
eljefino
eljefino's Avatar
1995 SW1
If you are not having problems with the old bearings I would leave them alone and not touch them.
This isn't like the old rear wheel drive days where one would pay attention to the bearings when the rotor was off.
One needs a heavy press and special arbor to do the bearings; I'd get the entire knuckle assembly if I could. You may need an alignment after doing this though.
Old 05-23-2007, 11:58 AM   #4
dildog
dildog's Avatar
Thanks for the info.. I'm going to just do the pads/rotors and forget the bearings for now. There's no reason to change them, I just figured after 110k miles and 10 years it'd be time. But I don't think it's worth the headache if it's not needed.
Thanks.
Stubborn wheel bearing hub assembly 2005 Vue, help! tkearsey Vue General 50 04-26-2019 11:02 PM
Wheel Bearing Hub Assembly Question sledgehammer777 Relay Tech 3 03-08-2010 11:45 PM
front wheel bearing/hub assembly Cowboygrad04 Vue Tech 1 06-25-2006 09:19 PM
Front Wheel Hub/Bearing Assembly JD7 Ion General 2 06-21-2005 05:52 AM
Wheel Bearing/Hub assembly SLeepr S-Series General 9 08-24-2004 10:23 PM
