Old 05-20-2007, 07:44 PM   #1
saturnsctwo
Default wheel cover lug nut plastic caps
i got a 2001 sc2 with the factory steel wheels with the wheel covers. are those plastic lug nut covers replaceable in the wheel covers? some of mine mostly the front ones are fading & cracking from the heat of the front disc brakes. because of this their strength is questionable & i might lose my wheel covers because these hold on the covers. i know some of them are cracking & stripped. is there some kind of service bulletin on this problem anyway?
Old 05-20-2007, 07:55 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: wheel cover lug nut plastic caps
you should be able to pop them loose from the wheel cover.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Lug Nut Cover Removal Tool??? GM Sky Man Astra General 44 04-23-2009 09:25 PM
wheel cover nut tightness saturnsctwo S-Series General 8 08-14-2007 08:51 PM
97 saturn sc2 instrument cluster, 15" aluminum wheel center caps/lug covers cheap! monger Classifieds 0 01-29-2006 10:50 PM
Ion-2 Wheel Lug Nut Torque?? billc Ion General 3 06-09-2005 12:16 PM
Steel Wheel lug nut / bolt question... skijay Vue General 4 02-17-2004 09:39 AM
