Old 05-20-2007, 09:20 AM   #1
joebear1
joebear1 is on a distinguished road
Dizzy how to reset oil life
has any one done an oil change yet,how do you reset the oil life.thanks in advance
Add to joebear1's Reputation
Rate the quality of this post and help joebear1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joebear1 is offline   Reply With Quote
Old 05-20-2007, 10:40 AM   #2
Boltbacker
Boltbacker is on a distinguished road
Boltbacker's Avatar
2007 Outlook XR
Default Re: how to reset oil life
Through the DIC. Read the manual and it tells you a lot about the vehicle.
Danger: High Voltage!!!
07' XR FWD Ocean Mist, Grey Leather, everything else but Nav. Added 3M clear bra, tinted front windows.
Add to Boltbacker's Reputation
Rate the quality of this post and help Boltbacker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Boltbacker is offline   Reply With Quote
Old 05-20-2007, 07:46 PM   #3
BrightOutlook
BrightOutlook is on a distinguished road
BrightOutlook's Avatar
2007 Outlook XR
2001 L-Series 2.2L Wagon
If you have the four-button DIC (Driver Information Center), you press and hold the (left) check (set/reset) button to reset the value while any resettable item is displayed.
If you don't have the four buttons, you reset it with the same trip odometer reset stem that you use to display the Oil life remaining.
2007 Outlook XR FWD
Ocean Mist / Grey Int
Enhanced Convenience Pkg / HID
Over 5,000 miles already! Awesome ride. Love it!
Gorgeous! Gutsy! Glorious!
Add to BrightOutlook's Reputation
Rate the quality of this post and help BrightOutlook reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BrightOutlook is offline   Reply With Quote
Old 05-21-2007, 06:09 AM   #4
joebear1
thanks,that what i tought but did not want try it until after an oil change
Old 05-21-2007, 03:20 PM   #5
ThePlainsman
ThePlainsman is on a distinguished road
ThePlainsman's Avatar
I got an oil change. When I got the vehicle back it was already reset at 100%. Isn't it reset automatically?
2007 Saturn Outlook XR AWD, loaded, including HIDs and heated leather
2008 Acura RDX-Tech, loaded, including HIDs and heated leather
2002 Nissan Altiima V6, loaded, including HIDs and heated leather
Add to ThePlainsman's Reputation
Rate the quality of this post and help ThePlainsman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ThePlainsman is offline   Reply With Quote
Old 05-21-2007, 03:23 PM   #6
Uzzy
Uzzy's Avatar
2002 SC1
No, it's not reset automatically. How could the car know the oil was changed? There are no sensors to detect that. Normally the place where you get the service done will do it, but sometimes they forget. Or if you do it yourself, you need to reset it yourself.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 05-22-2007, 06:49 AM   #7
N9GUX
N9GUX is on a distinguished road
2007 Outlook XR
Actually there is a very easy way the car could know you have had an oil change. All the manufacturer would have to do is put a reset switch on the oil filter. When the oil filter was removed it could reset the system. I don't know why this is not being done. The Outlook reset is relatively easy but it is amazing what you have to go through on some vehicles to reset the oil life system.
Add to N9GUX's Reputation
Rate the quality of this post and help N9GUX reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
N9GUX is offline   Reply With Quote
Old 05-22-2007, 08:09 AM   #8
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
Would you really want sensor/switch/etc. near the seal of the filter?
Toyota: Moving Forward... off a cliff at a high rate of speed.
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline   Reply With Quote
Old 05-22-2007, 04:05 PM   #9
Uzzy
Uzzy's Avatar
2002 SC1
Exactly. It's only going to cause problems, or just fail. I know of my SC1 had one, I would have busted it off by now, trying to get the filter in the proper position, when you can't see a damn thing, and you're upside down It's so worth it to go in through the wheel well, I've recently discovered.
Old 11-23-2009, 06:24 PM   #10
chiefton
chiefton is on a distinguished road
I found that on my 2008 saturn Aura (4 button DIC) that the following steps must take place to reset the oil life:
1) place ignition swith in run position
2) cycle through features by pressing the info button until the oil life is illuminated
3) depress all 4 DIC buttons at the same time; instrument panel will read "reset oil life"
4) release all buttons
5) depress bottom button (w/left pointing arrow) and oil life will read "acknowledged"
Add to chiefton's Reputation
Rate the quality of this post and help chiefton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chiefton is offline   Reply With Quote
Old 11-23-2009, 08:41 PM   #11
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
on the 08 aura with ignition on just push bottom 2 buttons. it will say reset oil life. then push bottom button. or even easier ignition on then push accelerator three times
Add to onefunkar's Reputation
Old 11-24-2009, 09:41 PM   #12
Accordionjohn
Accordionjohn is on a distinguished road
2009 Outlook XE
On our '09 Outlook without the 4 button DIC: to reset the oil life turn ignition switch to the "on" position - digital displays will come up on the dash. Next, depress the odometer switch in and out until the "oil life" percentage is displayed and at that point, keep the odometer switch depressed until the display goes from whatever percentage of life was displayed originally to 100% remaining. Release the odometer switch and turn the ignition switch to the "off" position. Reset of oil life percentage accomplished. I double checked by repeating the above procedure to ensure that the oil life percentage this time displayed 100%.
Add to Accordionjohn's Reputation
Rate the quality of this post and help Accordionjohn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Accordionjohn is offline   Reply With Quote
Old 09-06-2012, 06:48 AM   #13
alkspa
alkspa is on a distinguished road
alkspa's Avatar
This worked well with my '07 Aura ("Penske"). Simple and sweet! Thanks onefunkar.
Add to alkspa's Reputation
Rate the quality of this post and help alkspa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alkspa is offline   Reply With Quote
Oil change, Tools Required, Oil Life Monitor Reset Instructions emg77 Astra Tech 57 04-24-2015 01:43 PM
How do you reset the oil life monitor? blkprl Vue General 20 01-01-2015 07:48 PM
Help: Oil Life Reset dmoser Astra Tech 10 12-03-2010 08:59 PM
how to reset oil life etovar 2008 Vue 3 02-23-2009 04:52 PM
04 oil life monitor reset gaurdien Vue Tech 3 11-01-2006 11:01 PM
