Old 05-19-2007, 04:28 PM   #1
Drew Fiedler
Drew Fiedler is on a distinguished road
Attention Transmission shift cable help!
I'm currently in the process of taking out the motor of my 1995 SC2 manual.
I need advice on how to remove the shift cables from the trans housing.
The linkage is disconnected but I can't get the part where the housing wraps around further down the line.
Any help is apreciated,
Thanks.
Add to Drew Fiedler's Reputation
Rate the quality of this post and help Drew Fiedler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Drew Fiedler is offline   Reply With Quote
Old 05-19-2007, 04:42 PM   #2
yazhere
yazhere is on a distinguished road
yazhere's Avatar
Default Re: Transmission shift cable help!
AS I recall, there is a plastic part with ears near the metal part of the transmission holding the cable. You need to squeeze the ears and turn the plastic part to the opening in the metal housing allowing the cables to get out. I do not recall if the ears are on the right or left of the metal housing. When you see it out, you realize how it works however it is a "stumper" until then.
Add to yazhere's Reputation
Rate the quality of this post and help yazhere reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yazhere is offline   Reply With Quote
Old 05-19-2007, 04:42 PM   #3
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
This guy on post #3 knows how to do it............
http://www.saturnfans.com/forums/sho...ht=shift+cable
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-19-2007, 05:09 PM   #4
Manual trans cables are held to the trans by u shaped clips that fit over the cable and against the tab that the cables go through. Lift/pry the clips up to get them off of the cables.
If it is the clips that hold the cables to the shifter linkage then lift the center tab on the clip up enough to clear the post and slide the clip off of the linkage post.
Add to ssicarman's Reputation
Old 05-19-2007, 05:20 PM   #5
Drew Fiedler
A 'stumper' indeed. I looked at the car and even have the motor raised up so I can see them semi-clearly. All of the parts in there are metal. There is no plastic any where I can see. Nothing resembling earred-tabs. Maybe I'm just too tired after working on it all day
Old 05-19-2007, 05:26 PM   #6
There are no eared tabs to release the cables on the manual trans. They are all held in with metal clips.
Old 05-19-2007, 05:34 PM   #7
yazhere
yazhere's Avatar
Drew... ssicarman is correct. They are metal clips that need to be pried up.
I was thinking about the auto trans. Thanks for the follow-up ssicarman..
Last edited by yazhere; 05-19-2007 at 05:36 PM.. Reason: Hello Richpin.. raining like hell here
Old 05-19-2007, 05:41 PM   #8
Drew Fiedler
Okay...so once the U clip is off. Then what? The line is still very much stuck in there.
Thanks
No harm done Yazhere
Old 05-19-2007, 06:05 PM   #9
Low Saturn
Low Saturn's Avatar
2000 SC2
Thanks
Push it back then up. After the first time, you dont even need to see them to take them out.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 05-19-2007, 06:30 PM   #10
Drew Fiedler
Alright, Thanks Mike, I'll give it a try.
Old 05-19-2007, 09:02 PM   #11
Drew Fiedler
Thanks for all the help guys! I got them off.
The first was easy and came right out but the lower one took a good 30 minutes. lol You'd figure in 8 and a half hours of work, three guys could get a motor out,
Another shift cable nightmare (at the transmission end this time)... SaturnSpouse S-Series Tech 8 08-27-2011 02:18 PM
S-Series Shift Cable Solution (Manual Transmission) cazzylee S-Series Tech 15 06-23-2007 03:33 PM
Help removing transmission shift cable strianse S-Series Tech 11 04-09-2007 09:29 PM
shift cable?? silversc2 4sale S-Series Tech 2 04-03-2007 05:38 PM
97 sl shift cable heyokey L-Series Tech 1 09-03-2006 07:36 PM
