what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 06-22-2002, 11:03 AM   #1
davidjw
davidjw is on a distinguished road
Default VUE-loss of electrical power when starting
Hello,
I have a weird problem that occurs very intermittantly on my VUE. Sometimes (once or twice a week) when I turn the key to start the engine, it begins to crank, but then there is a split-second loss of electrical power. The engine stops cranking, and the dashboard lights go out, but it happens so quickly that while you're still holding the key, it all comes back to life, and starts back up just fine.
I have been sure to have the clutch fully pressed, in case there was a faulty switch...but this reminds me of an older car that has battery terminal corrosion... However, I don't know how that could be the case with a brand new car.
Like I said, it happens only occasionally. The retailer tried starting it 30-40 times when I was in for an oil change, and it would never happen for them. I cannot find any patterns with the problem (starting with the a/c on, when it's cold, warm, whatever...), so it is really baffling me.
Has this happened to anyone else???
David
'02 VUE SP, Red
Ohio "NICE VUE" plates
Add to davidjw's Reputation
Rate the quality of this post and help davidjw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davidjw is offline
Old 06-22-2002, 11:52 AM   #2
ricksLS1
ricksLS1 is on a distinguished road
ricksLS1's Avatar
Default Re: VUE-loss of electrical power when starting
Originally posted by davidjw
Hello,
David
'02 VUE SP, Red
How old and # of miles? Maybe turn it in if you can if under 30 days and 1,500 miles.
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline
Old 06-22-2002, 01:08 PM   #3
BeausoleilRacin
BeausoleilRacin is on a distinguished road
Default
Sounds like a battery cable problem, like they're not tight enough. But I am not very familiar with anything beyond 1996 yet.
Add to BeausoleilRacin's Reputation
Rate the quality of this post and help BeausoleilRacin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BeausoleilRacin is offline
Old 06-23-2002, 12:51 PM   #4
davidjw
Default
I've had it since February, and I have about 6500 miles on it... So returning it is not an option. I figure the problem will either get worse (happen enough for the retailer to see the problem), or else stay the same, which is simply an annoyance right now. It NEVER fails to start... Just a little embarassing at times when it happens... For instance, my neighbors had just asked how I liked my new VUE, and I said that I love it (which is still true)... But then, I turned the key to start it, and the problem happened... Yeah... heheheee
David
David
davidjw is offline
Old 06-23-2002, 01:11 PM   #5
ricksLS1
ricksLS1's Avatar
Default
Hope they fix it for you soon. I had a problem with an older car when I would stop after driving for a long time and restart again would just click. Wait 5 minutes and then no problem. Was loose connection on starter. This would drive me crazy
ricksLS1 is offline
Electrical Power Loss From Shifting Gears? DecayingOmega S-Series General 8 06-27-2006 11:08 AM
electrical power loss Zorak S-Series Tech 5 10-19-2005 08:17 PM
Starting/Electrical Problems germy78 S-Series Tech 7 09-23-2004 10:31 PM
Loss of power THX712517 S-Series Tech 5 05-30-2003 07:34 PM
Starting problem/electrical paul123 S-Series Tech 2 01-02-2003 09:47 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
