Old 05-18-2007, 10:24 AM   #1
DecayingOmega
DecayingOmega is on a distinguished road
Default Temp Gauge Dead, ECTS Replacement?
My engine temperature gauge is dead, is this just an indication of a dead ECTS?
Add to DecayingOmega's Reputation
Rate the quality of this post and help DecayingOmega reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DecayingOmega is offline   Reply With Quote
Old 05-18-2007, 11:22 AM   #2
aperseghin
aperseghin is on a distinguished road
aperseghin's Avatar
Default Re: Temp Gauge Dead, ECTS Replacement?
Probably.. if its stock ECTS i'd change it anyway.. mine took literaly 10 min to do myself...
~~~~~~~~~~http://www.yourlastrites.com/saturn~~~~~~~~~~~~
1999 SC2 3- Door Coupe.
DIY Custom Short Ram Intake.
69,000 miles
Add to aperseghin's Reputation
Rate the quality of this post and help aperseghin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aperseghin is offline   Reply With Quote
Old 05-18-2007, 11:46 AM   #3
BarnOwl
BarnOwl's Avatar
If it's the '99 SL2 in your profile, actually no. When the ECTS goes completely the PCM goes into open loop and the gauge will read right in the center. The fan will run full time too. I'm not sure what your problem is. However, if you still have the original ECTS, I strongly advise you to replace.
Add to BarnOwl's Reputation
Old 05-18-2007, 12:01 PM   #4
DecayingOmega
No, I had the ECTS replaced when I got the car, which was at 107k miles, it now has almost 131k on it.
Old 05-19-2007, 08:26 AM   #5
DecayingOmega
bump
Old 05-19-2007, 10:24 AM   #6
yazhere
yazhere is on a distinguished road
yazhere's Avatar
As advised by BarnOwl, focus on the ECTS and its connector. If it is unhooked, the gauge should be in the center. If it is reading all the way to the left, there must be a loosen connection giving improper data or the ECTS may have broken.
Add to yazhere's Reputation
Rate the quality of this post and help yazhere reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yazhere is offline   Reply With Quote
New ECTS...still have Hot Temp Gauge 2NDSOUT S-Series Tech 6 05-22-2008 09:20 AM
ECTS and Temp Gauge Sensor Wiring WingsOfSaturn S-Series Tech 7 10-22-2005 09:45 PM
dead temp gauge, hesitation The_Lizard S-Series Tech 2 10-02-2005 03:05 PM
Replaced ECTS... Still runs under 1/4 on temp gauge??? jessicabreck S-Series Tech 13 01-10-2005 11:19 AM
Temp Gauge Dead w/ SES Light YELO_SC2 Miscellaneous Tech 9 02-12-2004 10:58 PM
