Old 04-10-2012, 01:02 AM   #1
cristian1090
cristian1090 is on a distinguished road
2006 VUE Red Line
2006 ION-3 Sedan
Default lugnuts coming loose??
i have a 06 saturn vue red line with factory rims and my i been noticing that my lug nuts get loose between every 2 weeks or so, could the aluminum wheels be the cause of it? getting hot and cold,(meaning how aluminum expands when hot and shrink when cold)does anybody else has this problem or just somebody wants me dead!!! lol
cristian1090 is offline   Reply With Quote
Old 04-10-2012, 09:18 AM   #2
Tom92SCm
Tom92SCm has a spectacular aura aboutTom92SCm has a spectacular aura about
Tom92SCm's Avatar
Default Re: lugnuts coming loose??
How are you tightening them (ie with the vehicle on the ground or while the vehicle is in the air)? Are you torquing them? If so, to what?
In short, aluminum wheels can have a tendency to loosen the lug nuts due to the heating as you described. But usually not to the point of being noticeably loose- they just loosen by 15-20 ft-lbs or so and retorquing them once should be good.
Not a Saturn.
Tom92SCm is offline   Reply With Quote
Old 04-10-2012, 06:49 PM   #3
cristian1090
2006 VUE Red Line
2006 ION-3 Sedan
im just using a 4 way on the ground, no torque wrench im not sure whats the torque rating at....
Old 04-10-2012, 10:26 PM   #4
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
I believe it's 100 ft-lbs.
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
RedGeminiPA is offline   Reply With Quote
Old 04-10-2012, 10:54 PM   #5
far2grumpy
far2grumpy's Avatar
RGPA - spot-on ... according to service manual the torque is 100 ft pd - tightened in a star pattern - if they loosen again after being torqued - the lug-nuts should probably be replaced (don't even want to think about the studs).
Old 04-11-2012, 09:52 AM   #6
Tom92SCm
Tom92SCm's Avatar
And it's a really good idea to mount the wheel and tighten all the lug nuts while the vehicle is in the air. I don't torque them in the air, but I can usually wedge my foot under the tire enough to keep it from spinning too much while I tighten the lugs- in a star pattern. And when I do set it on the ground and do the final torqueing, I'm usually no more than 1/2 turn away from the torque spec.
Not a Saturn.
Old 04-11-2012, 08:26 PM   #7
cristian1090
2006 VUE Red Line
2006 ION-3 Sedan
thanks for the info everybody...
Bumper Coming Loose sl1driver S-Series General 12 08-28-2009 01:57 AM
Heat shield coming loose. harley2003 S-Series General 9 11-22-2008 09:15 AM
Lettering coming loose? ToledoEngineer Sky General 11 07-03-2008 05:19 PM
Batter cables keep coming loose. oldgoat S-Series General 5 12-15-2005 11:43 PM
Door Panel Coming Loose wfyoung3 S-Series General 2 10-15-2005 12:40 AM
