Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 06-21-2011, 06:24 PM   #1
atikovi
Default Just bought a 2007 Redline, what I need to know?
A black on black FWD with 140K. What should I check and service with those miles? Does it have a timing belt or chain? What is the HP compared to a regular Vue?
Old 06-21-2011, 09:12 PM   #2
XRL
XRL's Avatar
2004 VUE Red Line
Default Re: Just bought a 2007 Redline, what I need to know?
It has a timing belt that should have been done at 100k. Along with the water pump and definitely transmission fluids.
Holy crap that's a lot of miles! I hope they gave you service records with it, otherwise you might be looking at a very expensive set of maintenance things that should have been done a long time ago.
The RL has 250hp (or is it 245?), same as the normal Honda powered V6 Vues. The RL adds suspension and handling tuning mostly.
Old 06-21-2011, 09:58 PM   #3
atikovi
This is a FWD Vue. What is the weight difference between a RL? -1000 lb at least? Vue should be quite a bit quicker?
Old 06-21-2011, 10:24 PM   #4
XRL
XRL's Avatar
2004 VUE Red Line
Nah, any theoretical weight differences would be made up for by the tiny aerodynamic differences and better tires.
If an RL weight 100 pounds more I'd be surprised. Plastic bumpers don't weigh much, and the larger wheels are offset by smaller tires.
Realistically, there's a negligible difference in speed between a V6 Vue and an RL. Unless there's turns involved, in which case the RL will just walk all over the normal Vue.
Old 06-21-2011, 10:36 PM   #5
atikovi
OK, checked the new car guide for 2007. RL RTX is 4513 pounds, Vue V6 FWD is 3534 pounds.
Old 06-21-2011, 11:55 PM   #6
Vue in Ontario
Vue in Ontario is on a distinguished road
2006 VUE Red Line
2007 AURA XE
?????? 1000 pounds?
Vue in Ontario is offline   Reply With Quote
Old 06-22-2011, 12:09 AM   #7
Vue in Ontario
2006 VUE Red Line
2007 AURA XE
Does 140k mean 140,000 kilometres or 140,000 miles, big difference.
Old 06-22-2011, 12:48 AM   #8
Vue in Ontario
2006 VUE Red Line
2007 AURA XE
Here's some weight info I found for 2006......
2006 Saturn Vue Specifications
Engine Location Front
Drive Type Front Wheel (standard), AWD
Weight 3279 lbs | 1487.329 kg
MPG City 23
MPG Highway 29
2006 Saturn Vue Redline Specifications
Weight 3299 lbs | 1496.401 kg
MPG City 20
MPG Highway 28
Old 06-22-2011, 07:00 PM   #9
XRL
XRL's Avatar
2004 VUE Red Line
I figured it out. By RL he means Honda Ridgeline, not Vue Redline.
That explains the confusion. RL means Redline here.
Old 06-22-2011, 07:12 PM   #10
atikovi
Post Re: Just bought a 2007 Redline, what I need to know?
Yep, my bad. Had a Ridgeline once and it goes by RL too so it was on my mind. So I was really asking how much quicker does the 1000 pound lighter Vue feel next to the Ridgeline with the same engine.
Old 06-22-2011, 07:49 PM   #11
XRL
XRL's Avatar
2004 VUE Red Line
Personally, I think it should be more of a difference, but GM handicaps every vehicle they sell with excessive TM that slow the vehicles down. Plus they totally neutered 1st gear in the Vue.
Just bought a berry red 2007 XE!! pbmax Aura General 4 04-24-2011 07:24 PM
Bought a used Saturn Aura XE 2007. rununix Aura General 0 05-22-2008 09:41 PM
Just bought a 2007 Aura XR on Friday...have questions. Phil Henry Aura General 7 04-02-2008 01:55 PM
Bought a 2007 Outlook XR Ruger01 Outlook General 1 06-18-2007 12:35 AM
Bought Vue 2007 V6 and needed battery boost the day after! riller Vue Tech 4 04-24-2007 02:22 PM
