Old 05-27-2010, 10:06 AM   #1
Absberg2k
Absberg2k is on a distinguished road
Default Key Fob battery problem
Can anyone help me with replacing the battery in my key fob? I've done it about a hundred times (literally) but each time I put it back together it lasts for a day or so and then the battery and its retainer clip come loose. It's starting to drive me crazy.
The battery itself is fine. Its the retainer clip (or whatever its called) that seems to be causing the problem. It has little prongs that insert into the circuit board but not very far. Any serious bumping or jostling of the key fob will cause the clip and battery to come loose again.
Maybe I'm just doing it wrong? Any help or guidance would be greatly appreciated.
Absberg2k is offline   Reply With Quote
Old 05-27-2010, 11:17 AM   #2
Redline09
Redline09 is on a distinguished road
2007 ION-3 Quad Coupe
Default Re: Key Fob battery problem
I have a solution for you. Take a small peice of thin foam tape, placing sticky sides together and place between the back of the battery and the back of the cover. This will hold it in place so it wont come loose. Just make sure the clip is where it is suppose to be. My girlfriends colbolt key fob did the same thing... Also, you may just try using the second fob, and use this as the back up, just to help...
Hope this helps.
Redline09 is offline   Reply With Quote
Old 05-27-2010, 12:02 PM   #3
metgol
metgol is on a distinguished road
metgol's Avatar
2007 AURA XE
1998 SW2
I and others have had the problem. The solder is weak or not enough for the clip to the circuit board. Take it out and solder the pin back on the board and you'll be good.
98 SW2 214000miles
07 Aura 19500miles
/////Alpine inside!
metgol is offline   Reply With Quote
Old 05-27-2010, 01:04 PM   #4
Absberg2k
Hope this helps.
Thanks for the prompt responses. I will try the foam tape trick (as I am not real handy with solder).
I did try the second key fob and am having the exact same problem with it.
Thanks again to both of you.
Old 05-28-2010, 05:14 PM   #5
wcarroll
wcarroll is on a distinguished road
wcarroll's Avatar
2007 AURA XE
I had the same problem with mine. Had to resolder the battery clip to the circuit board. In fact, I've done this twice now to repair it. Poor design!
wcarroll is offline   Reply With Quote
Old 05-29-2010, 01:14 AM   #6
99SL2_Modder
99SL2_Modder is on a distinguished road
2009 AURA XR
Ditto on the solder.
I resoldered both of my fobs and had to do my sisters older Mali-poo fob as well.
99SL2_Modder is offline   Reply With Quote
Old 05-29-2010, 06:12 AM   #7
khansen30
khansen30 is on a distinguished road
khansen30's Avatar
2008 AURA XR
GMC dealer replaced my wifes fob under warranty.
2009 GMC SLT2 Acadia (Mine)
Quicksilver - Titanium Leather
Everything
2008 Aura XR (Wifes)
Red Jewel - Tan Leather
Advanced Audio - Sunroof
khansen30 is offline   Reply With Quote
03 Battery problem? AssPhalt Vue Tech 7 03-09-2010 05:25 PM
Yet another battery problem mr weather Aura General 19 09-28-2008 07:00 PM
L 300 Battery Problem lightstarcom L-Series Tech 1 06-28-2008 07:48 PM
Battery Problem epicurus4 Vue General 5 06-28-2007 05:13 PM
Battery problem? JDub99SL2 S-Series Tech 2 08-09-2003 08:19 AM
