![]() Join Date: Jul 2007
Ever since we purchased our Outlook in 2007 we have been bringing it back to the dealer on a frequent basis due to leaks caused by clogged roof drains (we have the sun & moon roofs on our XR). After our last visit this past fall I tried a temporary fix which seems to be holding (it's been at 3+ months since our last leak so I'm hopeful). I taped over the gap that goes all around the moon glass (totally closing it over). It seems to have done the trick of preventing the debris from our white pine from getting into the drain pipes (so far).
I haven't notice any detrimental effects from water not being able to drain off from the moon roof. I do, however, see moisture that remains in the gap between the glass and the roof. I would think that over time this would be a rust hazard. My thinking is that if I don't develop any leaks within the next 2 months that sealing off this gap is a good thing. If this is the case I am considering making this permanent with a silicon sealant. Anybody have any experience or thoughts on this approach? Thank you for your feedback. |
2008 AURA XR
If there is still moister in the gap as you say and you put silicon in you could develop even more rust. This happened to me on a previous car.
I have never had a problem with the clogs coming from the moon roof. I had 3 clogs with my 07 Outlook and they came from me leaving the sunroof open when parked. On my Acadia I have not left the sunroof opened when parked and have not had any clogs in the year that I have had it (more rain and snow in the last year than the almost 2 years I had the Outlook.
2009 GMC SLT2 Acadia (Mine) Quicksilver - Titanium Leather Everything 2008 Aura XR (Wifes) Red Jewel - Tan Leather Advanced Audio - Sunroof |
![]() Join Date: Oct 2005
2007 Outlook XR
I have an appointment with the closest Saturn dealer remaining, Kings Auto Mall in Cincinnati Thursday morning. The sun roof on our 07 Outlook leaked this past weekend, the first time ever. It does sit outside yet we don't really use the roof that often, not since last summer, and I never leave it open when I am not in the vehicle. So disappointed with the situation yet I guess we are lucky as it is still under warranty.
#4 | |
Hope this helps in your decision |
#5 |
2007 Outlook XR
Well they could not reproduce the leak and they cleaned the headliner. Since there is a wiper motor replacement on order I will have to go back. I forgot to mention that our drive way tilts and the Outlook sits with the front lower than the back.
When I go back to have the replacement part replaced I will have to remember to mention this and see if they can reproduce the leak at that time. ![]() |
2007 Outlook XR
#7 |
2008 AURA XR
Have them check the seams and bolts on the roof racks. Some had leaks from there as well, my 07 did.
#8 | |
2007 Outlook XR
I did and I am back home AND NO LUCK!!!!!!!! I am believing that THEY do not want to fool with my Saturn. Want to guess why I have that thought? The service tech stated that I should "take my Outlook to a GM dealer who has been certified to work on Saturn's because even if they would have found the leak they, Saturn of Kings Auto Mall, could not get approval to replace roof liner" which is now stained for the SECOND TIME! ![]() ![]() SSSSOOOO now I will have to contact a GM dealer CERTIFIED to work on my Outlook. That means it will be "Jake Sweeney Tri-County". ANOTHER road trip to Cincinnati is in my immediate future. Do you think I need to contact GM first? |
#9 |
2008 AURA XR
So let me see if I got this right;
Your Saturn dealer is no longer a certified GM repair center? If so, get out of there. Yes I would call GM and let them know. Most Chevy dealers and GMC dealer can do the work as the set up is the same on all the Lambda's. They will have to order parts which might take a while (like the headliner) but everything else not seen should be the same. When a place refers me to a competitor I don't hesitate to get out, that means they don't care and will not do good work.
#10 |
2007 Outlook XR
The dealer is still classified as a "Saturn" dealership with the "Saturn" sign and all that crap.
So now I will have to contact the GM dealership who is classified as a Saturn repair service center in hopes that they finish what a "Saturn dealership" could not do. Let me think..........perhaps if I change my tune and say how much I just LOVE GM and that we are considering purchasing a new Camaro do you think................ Fix my Outlook and a new Camaro will be in our garage AFTER the repair is completed............. ![]() |
#11 |
![]() Join Date: Dec 2009
2007 Outlook XR
Wow...absolutely ridiculous for you to be going through this. Sounds like the GM Regional Rep needs to be involved in this issue.
For what it's worth, I just bought the Alldata subscription for my wife's 07 Outlook (we bought the car used). So far I've had the following issues: sway bar end link noise--FIXED in my driveway--bad bushing. Replaced driver side endlink Steering wheel noise--sounds like you're scratching your fingernails on a screen when you turn the steering wheel and the engine is warm..very odd. I'm trying to track down the issue via Google. This apparently happens on some of the Outlooks and noone can come up with a long term solution. If I figure it out I'll post on this site Water leaking from the front light dome into the console--We purposely avoided buying an Outlook due to hearing about issues with the leaky Sunroof, and yet we still have leaks!! I'm digging into this one over the weekend. I've got a feeling it's coming from the luggage rack rails. I'll update here. |
#12 |
![]() ![]() ![]() ![]() Join Date: Apr 2006
2006 VUE Red Line
2007 SKY
http://www.lemonlaw.com/wordpress/wa...aturn-outlook/
You are not alone with this problem...
2006 Black VUE Red Line - Now running iOS 11 |
#13 |
2007 Outlook XR
#14 |
2007 Outlook XR
Just picked up my Outlook this afternoon. Let me think four weeks four trips to Cincinnati the last two of those trips for them to replace drain hoses.
Yes last week they replaced a hose and said all was fine. Monday night rain rain rain and Tuesday morning "leak" back in the exact same place. So took the Outlook to Cincinnati that day and they found a SECOND drain hose to replace. WTF! Now here is the fun part. The headliner needs to be replaced and they have one on order and should be in next week. So......what will this be next week....my fifth trip to Cincinnati in five weeks. I sure wish it would rain this weekend because when they replace the headliner and it rains and it leaks..............the wrath of a really ticked off female is something they do not want to experience.
2003 Red VUE - LOVE IT! 2007 Silver Outlook - SIGHHH! Traded 2/11 for a 2011 Enclave 2005 Gray Nissan 350Z - FUN FUN FUN warm weather only with the top down |
#15 | |
2007 Outlook XR
As a sidenote, I looked at our Outlook roof this afternoon, and lo and behold, under the rubber trim that runs from the luggage rack rails on each side up to the windshield, what did I find? Silicone! Looks like the dealer tried to repair it previously. ![]() Good luck MMarlin! Hope they finally fixed it! |
#16 |
2007 Outlook XR
Thank you "PSmith"!
I have collected all the information on our Outlook. The DOB was 5/27/2007 and the day we bought it was 12/01/2007. I thought it odd that there was only 8 miles on the odometer that day. Anyway back to what I was going to mention. I have been able to identify six times the Outlook had work on the "drain lines". Once in August 2007, before our purchase, there is a notation that the extension to the drain lines work was performed. Then in 2008 we received notice to take the Outlook in for a re-call on the drain lines to have drain line extensions added. So now along comes my trips back and forth over the past four weeks. Which if my addition is correct makes it a total of "six" times for work on the drain lines???? "BobbyP" thanks for the link pertaining to the lemon law my husband will be considering this especially if the "leak" reappears.
Colant Leak - Small leak turned into a big one | Raysp30 | S-Series Tech | 3 | 03-02-2009 07:25 PM |
Driver side leak & sunroof leak-common? | Miss Holly | S-Series Tech | 3 | 01-06-2008 02:01 AM |
Outlook/Acadia Review Roundup - a list of all Outlook and Acadia Reviews | ffballid | Outlook General | 25 | 04-07-2007 10:41 AM |
will the outlook in teaser brochure be "the Outlook" | SaturngirlSc2 | Outlook General | 13 | 09-15-2006 04:19 PM |
evaporator core leak -- opinions on 'stop leak' products? | brenspin | S-Series Tech | 12 | 01-31-2006 12:29 AM |
