Old 08-09-2016, 06:12 AM   #1
VentureForth
VentureForth has a spectacular aura aboutVentureForth has a spectacular aura aboutVentureForth has a spectacular aura about
VentureForth's Avatar
2006 ION-3 Sedan
Dizzy 2006 Transmission (?) Issue
Out of the blue, my transmission began shifting hard on my '06 Ion-3. Concurrently, my engine started running rough, and I shouted get a TRAC OFF message. I also got a P507 code. I noticed a leaky gasket, but not too bad. Added 1/2 quart and it ran fine for a day. Next day, rinse and repeat. Finally, I knew I wasn't leaking add much as I was putting in. I have a new gasket on order, but I'm thinking that isn't the issue. Without adding fluid, it started and shifted fine again. I'm not ready to take it on the road until I fix the issue.
Of note, I recently removed and cleaned the throttle body. The wiring harness protective coil was brittle and busted. Maybe I didn't close off the system adequately from ambient air. Maybe the harness is in a bad way. I know this doesn't sound intuitive, but I read where another guy had similar issues when his cam position sensor went out.
Any ideas?
VentureForth is offline   Reply With Quote
Old 08-09-2016, 08:18 AM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: 2006 Transmission (?) Issue
First, fix the leak. Then double check everything you touched for the tb.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 08-13-2016, 02:06 PM   #3
VentureForth
2006 ION-3 Sedan
Okay, so the answer may surprise those who are not familiar with fly-by-wire vehicles. It turns out that whenever I removed the air and lit from the throttle body to clean the throttle body I opened the butterfly valve with my fingers. The throttle bodies are pretty sensitive. Buy adjusting it manually, I messed up the calibration. Here are the steps to recalibrate your throttle body if it isn't messed up. Turn the key to the on position without starting it. Do not press the accelerator, do not start the engine for at least 30 seconds. That's all I needed to do, and it's working fine now.
Old 08-13-2016, 03:58 PM   #4
billysvue
I thought the "relearn" procedure is a minute?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 08-13-2016, 04:05 PM   #5
VentureForth
2006 ION-3 Sedan
I read 29 seconds. I waited a full minute...
Old 08-14-2016, 06:25 AM   #6
VentureForth
2006 ION-3 Sedan
It's is still acting up. The key reset keeps working, but I'm sure I screwed up my TPS.
Repair issue 2006 Vue Rvasaturn Vue General 6 02-19-2016 03:51 PM
2006 3.5L Misfire Issue infinitewisdumb Vue Tech 9 08-18-2015 11:28 AM
2006 Saturn Vue ECM issue APDwife Vue Tech 3 10-05-2012 12:54 PM
2006 ion wiper issue krull1755 Ion Tech 1 12-13-2011 12:33 PM
2006 Starting Issue, HELP Taz GTO Vue General 2 01-11-2010 11:29 PM
