Old 02-28-2016, 09:22 PM   #1
SLfun
2006 ION Red Line
Default re seal 97 DOHC motor?
So I took the motor out of my 97 SL2 parts car to put into my 98 SL1.
It's sitting on a work bench so we can do the timing chain and clutch...
Anything else we should do while it's out of the car? I was thinking oil pan re seal, valve cover gasket, and crank pulley seal.
Should we also do the intake gasket? Rear main seal? Are they known to leak?
Motor has 150 k on it, ran strong, compression around 180 right across.
DOHC valve seal R&R caveeagle S-Series Tech 8 12-15-2013 06:12 PM
99 SL2 Dohc motor change with 98 Dohc donor jmerk S-Series Tech 10 03-22-2012 03:08 PM
Valve seal puller for DOHC RobertGary1 S-Series Tech 4 04-26-2011 01:29 AM
Will a 96 DOHC tranny bolt up to a 95 DOHC motor? lnmrmn S-Series Tech 7 12-04-2009 09:09 PM
02 dohc real main seal billison S-Series Tech 6 01-02-2007 08:44 AM
