Old 04-19-2008, 10:55 PM   #1
jcw
jcw is on a distinguished road
Default SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket?
Hi all,
As a newcomer to this forum, I'm very impressed with the quality and amount of good information you provide - many thanks for that!
I just purchased a 2000 SW2 with 82K miles, drove it home (28 miles) and discovered, when changing the plugs, that the number 1 cylinder is wet with coolant. The car does not smoke, the coolant temperature and appearance is normal, no service lights, and the only thing I can detect is a little hesitation when accelerating from idle and a slight coolant smell under the hood. Also, don't see any oil on coolant reservoir and the oil on the dipstick looks normal.
My questions are:
If a compression test on number 1 cylinder comes clean, is it safe to conclude the problem is the intake manifold or intake manifold gasket? Is there any other route for the coolant to get in?
If the culprit is the intake manifold, is there any possibility of replacing it, or its gasket, by just taking the bolts out, dislodging the old one out and positioning the new one in without taking the whole thing apart? What about trying to tightening the bolts?
Also, about the compression test, Is there any extender I can get to reach the deep well threads?
Thanks, John
jcw is offline   Reply With Quote
Old 04-20-2008, 07:56 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket?
My compression tester actually has a quick disconnect on it. However to test on a Saturn, the only way to do it is to use the end that you have to hold in yourself. I've been thinking about building my own leakdown tester. There are instructions here. Except I'd use a piece of straight pip instead of the hose. That way I could use for both compression and leakdown tests.
Old 04-24-2008, 09:59 PM   #3
jcw
BarnOwl,
Thanks for the link. I decided I'll make my compression tester hose rigid by inserting it in a metal tube and fill the tube with epoxy. In that way I'm not messing with the total volume seen by the meter.
I still would love to get some answers to my other questions - guess I should rephrase the thread with a HELP! kind of title...
Thanks, John
Old 05-08-2008, 08:49 PM   #4
jcw
Just an update on my problem.
I flushed the coolant and replaced it adding 2 Saturn sealer (ginger) tablets (1 crushed and one whole). No more leaks.
Old 05-09-2008, 03:42 AM   #5
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
If compression was ok, my bet would be the IM gasket.
That sealant might last forever or it might be a short term fix.
I hope the leak doesn't come back. I hate coolant leaks.
2000 SL2 5-speed turbo
MSnS-E fuel & spark controlled @ 17-20 psi (methanol injected)
Fully forged, P&P head and manifolds, FSR turbo cams, balanced to 9k RPM
http://www.cardomain.com/ride/3070918
plastic torpedo is offline   Reply With Quote
1.9 SOHC Cylinder Head/Head Gasket..... Coolant Leak BRIAN41920 S-Series Tech 12 01-21-2014 03:40 PM
Head Gasket or Intake gasket? danbrwn S-Series Tech 1 11-26-2008 01:56 PM
Exhaust Manifold/Head Gasket TomM96 S-Series Tech 2 11-07-2008 04:20 PM
Intake Manifold gasket...HOW MUCH??!! Mr. Bill S-Series Tech 16 03-29-2008 06:29 PM
Intake manifold gasket leftyskikass555 S-Series Tech 3 05-31-2007 11:16 AM
