Old 08-01-2016, 09:19 PM   #1
that1man
that1man is just really nicethat1man is just really nicethat1man is just really nicethat1man is just really nicethat1man is just really nice
2006 RELAY-2
2007 ION-2 Sedan
Default Interior lights randomly turning on/off
I just noticed it an hour ago. I hope I didn't do It trying to fix my cig lighter ports, which I did
I'm not sure what is causing this but it killed my battery overnight. I watched the behavior of the lights and they turn off and on very randomly. Sometimes they stay on for a while and turn off then flicker a little and turn off etc.
I tried opening and closing each door and messing with the lights themselves, lightly tapping them, Also, putting the car in drive, reverse, neutral etc. My guess is loose wiring somewhere
Anyone have any idea how to troubleshoot this?
that1man is offline   Reply With Quote
Old 08-01-2016, 09:42 PM   #2
that1man
2006 RELAY-2
2007 ION-2 Sedan
Default Re: Interior lights randomly turning on/off
Also, this is a 2007 Saturn Ion if that helps
Old 08-03-2016, 11:42 AM   #3
that1man
2006 RELAY-2
2007 ION-2 Sedan
Can someone please help?! My car battery is dying every night
Old 08-03-2016, 01:39 PM   #4
1-When you repaired the power outlets, were they restored back to original function, fused and switched by the ignition switch or are they live all the time (ignition off)?
If one or both power outlets are live, any connection to outlets must be disconnected before leaving the car or ensuring the power switch to devices are turned OFF to prevent draining battery power.
2-How old is the battery? In general, car batteries last around 5 or 6 years (for good batteries) before croaking. Either recharge the battery using a wall charger or visit your favorite auto store for a free battery check.
3-What's the condition of battery cables? Loose connections, corrosion, poor repairs can affect power for supplying as well as recharging. With a battery in the trunk, chassis serves as ground with a long red positive cable from trunk to main engine fuse box, branching off to feed power to the starter. The "Remote Start' terminal is a stud next to the engine fuse box to connect a jumper cable (red) when jump starting a dead battery. This stud, marked in red, sometimes loosens and prevents battery power to the fuse box and starter. If loose, the electrical system may not work and the alternator will have difficulty recharging the battery. Check to be sure the battery and fuse connections to this stud is securely fastened.
4-A battery needs to be recharged after every engine start. The drive belt should be tight and not loose otherwise the alternator can't supply all the power a car needs while recharging the battery.
Old 08-03-2016, 03:01 PM   #5
that1man
2006 RELAY-2
2007 ION-2 Sedan
Thanks for the reply but I think you might have misread what the issue was.
My problem is the interior light are flickering randomly which is the battery is dying overnight or whenever. It just started happening a few days ago. I checked all the doors. I tried wiggling wires where the cig lighter in the front is connected and other stuff but I can't seem to pinpoint what's making them flicker. sometimes they stay off for a minute maybe sometimes they stay on for the same amount of time and all in between, just randomly
Old 08-03-2016, 03:46 PM   #6
Well, are these lights switched on manually or do they turn on by themselves. Describing problems can be misleading unless described in more detail. Is this about the dome lights or instrument panel lights?
Old 08-03-2016, 05:20 PM   #7
that1man
2006 RELAY-2
2007 ION-2 Sedan
The lights on the ceiling that turn on when the car doors open. there's 3 of them.. 2 in the front side by side and one in the middle/towards the back
Here is a video of what it is doing
https://youtu.be/t1MOXBhDbM0
Old 08-03-2016, 08:01 PM   #8
ruley73
ruley73's Avatar
My guess is that one of your door ajar switches is bad. Most likely the switch for the driver's door, but it could be one of the others. The BCM cuts off power to those three lights when the vehicle is moving, but not when the vehicle is parked. This may explain why the lights turn on/off by themselves. It is unfortunate that the domelight switch doesn't also disable the map lights when it is in the OFF position.
2007 Chevy Equinox LT 211K miles
2018 Chrysler Pacifica Touring L 85K miles
Old 08-03-2016, 08:36 PM   #9
that1man
2006 RELAY-2
2007 ION-2 Sedan
I tried playing with the ajar switch on the driver side but other than pushing it in as much as I could i don't know what else to look for
Is there a fuse that I can unplug to turn at least the map lights until I figure out what the problem is? Looking at the manual I don't know which fuse it is
Thanks
Old 08-03-2016, 10:52 PM   #10
bern
2006 ION-2 Sedan
I did a test on my own 06 Ion. Locked the doors (with the switch or fob) while holding the door pin switch in. Waited for the security light to blink. Then I released the door pin switch and the dome light lit but also the horn started to beep.
If the you don't get security sounding the horn even thou my 1st suspect was the door pin switch I going with my 2nd suspect switch in the center dome light.
The center dome light is sold as an assemble. Be careful the mount tabs break off easy.
Old 08-04-2016, 07:48 PM   #11
2006 ion2
2007 ION-2 Sedan
When my sunroof leaked into my door switches, my car did this. Did it while driving, too. I also think door switch. A multimeter will tell you everything.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 08-04-2016, 07:53 PM   #12
that1man
2006 RELAY-2
2007 ION-2 Sedan
My Ion is not equipped with an alarm. I just disconnected the bulbs from the map light and turned the dome light to the "off always" position until I figure it out. might go to a dealer or something to have it checked out. Until then, hope someone can help me find the issue
Thanks
Old 08-04-2016, 08:13 PM   #13
that1man
2006 RELAY-2
2007 ION-2 Sedan
I have a multimeter! I'm No sure what to do with it. Can you guide?
Old 08-04-2016, 08:50 PM   #14
2006 ion2
2007 ION-2 Sedan
http://bfy.tw/74Zu
2007 Saturn Ion 2
Old 08-05-2016, 11:51 AM   #15
that1man
2006 RELAY-2
2007 ION-2 Sedan
If I disconnect all the door switches should the lights stay on or off? I' trying to figure out a way to pinpoint and the only reason I use a multimeter is to check batteries.
So what I'm asking is, if I disconnect a door switch and the lights are still flickering, could it still be that same door switch that I disconnected, but just in the wire or something? Was going to disconnect them all to see what happens.
I have this multimeter set to the wifi icon...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-05-2016, 02:27 PM   #16
2006 ion2
2007 ION-2 Sedan
:facepalm: multimeters don't have wifi, at least not that one. The setting I use is the ohm setting (omega symbol) 0 ohms is closed (allows current) a lot is open. Each switch should have an open position and a closed one. With a defined switching point and no change in the reading with the switch in a given position. And no back and forth readings as the switch moves.
2007 Saturn Ion 2
Old 08-06-2016, 12:22 AM   #17
ruley73
ruley73's Avatar
Per the service manual, the door ajar switch closes the circuit when the door is opened and opens the circuit when the door is closed. Unplugging the switches would be the functional equivalent of never opening the doors.
Old 11-17-2016, 03:43 PM   #18
that1man
2006 RELAY-2
2007 ION-2 Sedan
Forgot to say that i replaced the door jam switch and that fixed it... Then it started again a few days later. Turned out to be the other side too lol. Found the parts pretty cheap on Amazon. Thanks for the help!
97 Manual SL1 Dash and Headlights Randomly Turning Off meagans S-Series Tech 0 02-13-2016 01:54 PM
Car alarm goes off randomly/Interior domelight stays on t2oo5 Vue Tech 2 01-11-2010 11:32 PM
2004 L300 V4 antitheft lights randomly, no start jonus311 L-Series Tech 1 09-16-2009 11:53 AM
Fog lights not turning on... Jinjo S-Series Tech 6 07-19-2007 07:36 PM
Problem with engine turning on then turning off, everything is on radio, lights, air fatimaknapp Ion Tech 6 12-28-2006 05:02 PM
