Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky General
Old 06-29-2018, 06:26 PM   #1
KEP3
KEP3 is on a distinguished road
2007 AURA XE
Default Sky Trunk is open warning
Well, I bought a 2008 Sky Red Line. I found one problem. No matter how hard I push down on the top when it's down, the trunk does not want to latch. At least according to the warning light on speedo. And if I try driving, HOO-BOY, does that make the car mad. It starts screaming like bells of St Mary. What gives?
Add to KEP3's Reputation
Rate the quality of this post and help KEP3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KEP3 is offline   Reply With Quote
Old 07-06-2018, 04:18 PM   #2
m1super90
m1super90 will become famous soon enough
m1super90's Avatar
Default Re: Sky Trunk is open warning
Two things at work here. The sensor for it being closed, and the latch itself. The latch has two bolts that can be loosened. You can then move it up and down as needed to get the tightness you want.
The sensor may be part of the latch. I don't know, so you'll need to check that out.
Add to m1super90's Reputation
Rate the quality of this post and help m1super90 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
m1super90 is offline   Reply With Quote
Old 07-06-2018, 09:02 PM   #3
KEP3
2007 AURA XE
Solved the problem. One has to practically stand on the center of the roof to compress it enuff for the boot to fully close. Forget that from my 2007. Now to get the windscreen latch adjusted si I don't need to us a screwdriver to push the hook down.
Old 07-11-2018, 10:27 PM   #4
KEP3
2007 AURA XE
Mad Re: Sky Trunk is open warning
Well, I thought I solved the problem. Today the trunk refused to latch correctly. I practically stood on the top. The only thin I think of is since the temp was 90+F, the kit expanded enough to keep it from fitting.
Old 07-16-2018, 10:15 AM   #5
m1super90
m1super90's Avatar
Yeah, you're going to have to get into the latch area, loosen those two bolts, and slide it up a tad. Should be easy to do though.
Old 07-16-2018, 08:30 PM   #6
KEP3
2007 AURA XE
Please clarify. Where are the bolts?
Old 07-17-2018, 07:40 AM   #7
m1super90
m1super90's Avatar
Open the trunk and locate the latching ring on the lid. Use it to locate the locking latch inside the car. If necessary, pull the carpet back from the latch. You should see two bolts which attach the latch to the car. The bolts go through slotted holes to allow for some amount of up and down movement of the latch. If you loosen the bolts you can move the latch up a bit to make locking the lid easier.
Let me know if you'd like me to locate this in my factory service manual. I can send you the diagram and, importantly, the torque spec of those bolts.
Old 07-17-2018, 09:04 PM   #8
KEP3
2007 AURA XE
I found this article the links to a shop manual. https://onedrive.live.com/?authkey=r...2A13A1DEE88176
Is the latch in this file? If not, may I have a copy of the info from your manual?
Old 07-17-2018, 09:41 PM   #9
m1super90
m1super90's Avatar
Didn't see it in your file set, but I'm attaching the page from my manual. One shot shows the location of the two bolts. The other shows the torque spec for them.
I've never actually adjusted the latch myself, but have been told by others that this is where the tightness of closing is set. I assume the bolts go through slotted holes. Let us know how it works!
Old 07-19-2018, 10:22 PM   #10
KEP3
2007 AURA XE
Thank you much.
Old 07-19-2018, 10:41 PM   #11
m1super90
m1super90's Avatar
You're welcome!
trunk will not open Roger2006 Aura General 9 04-24-2014 03:55 PM
Trunk open warning light fredwig S-Series Tech 1 08-15-2010 07:00 PM
How to seal a trunk + disble the trunk open light? lopoetve S-Series Tech 13 08-20-2008 04:13 AM
Trunk won't open quiksc2 S-Series Tech 7 10-04-2007 04:26 PM
Help! Can't open trunk! cris_thomas S-Series General 0 06-16-2007 08:47 PM
